| A100man |
 A100man World Chat Champion
 Posted: 17:00 - 20 Aug 2019 Post subject: Mapp Torch brazing - experiences? |
Might need to repair a crack in an exhaust flange.
Haven't ever brazed before (a bit of MIG work only) and I don't have any kit. I see though you can buy cheap Mapp compatible torches from ebay and the gas form toolstation.
Anyone done similar? and what filler rod did you use??
Cheers ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
| Riejufixing |
| ThatDippyTwat |
| Hong Kong Phooey |
| A100man |
 Posted: 12:56 - 22 Aug 2019 Post subject: |
Thanks chaps - I guess we're not talking plumbers flux here are we?
This kind of stuff perhaps..
https://www.ebay.co.uk/itm/SILVER-BRAZING-SOLDER-FLUX-KIT-55-silver-Just-add-heat-5-x-200mm-rods/183864842166
Crack is in downpipe/flange not a casting so not sure about hole drilling ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
| bikenut |
 bikenut World Chat Champion
| Robby |
 Robby Dirty Old Man
| Riejufixing |
 Posted: 17:56 - 22 Aug 2019 Post subject: |
Your link shows silver solder, but you want bronze brazing rods which have a higher melting point and give a stronger joint. One brand used to be SIF; Sifbronze rods, Sifbronze flux.
If your flange is cracked, can't it be welded? |
| Hong Kong Phooey |
| Riejufixing |
| A100man |
 Posted: 23:45 - 22 Aug 2019 Post subject: |
Yes it's steel. Wire feed is buggered on my Sealey Mig (well the one I have access too) I replaced the torch liner but still no dice so I've sidelined it - in any case I'd probably just have blown a hole in it
Thought brazing my prove an interesting thing to try and can be used to mess about with push bike frames too I'm told.
Will look out for sibronze rods then..
| Hong Kong Phooey |
| bikenut |
| Hong Kong Phooey |
| A100man |
 Posted: 08:41 - 24 Aug 2019 Post subject: |
Its a while since I had it apart but i think it was still gash without a tip. I was suspecting the rollers/roller tension.. bit visually they look OK. probably worth a punt as it's not a bad tool when 'on song'. It was inherited from my dad but is kept at my brothers place..
..meanwhile brazing seems a compact solution for light jobs. ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
The last post was made 6 years, 301 days ago. Instead of replying here, would creating a new thread be more useful? |
