| Cookiemonster... |
 Cookiemonster... Renault 5 Driver
 Posted: 08:54 - 02 Sep 2019 Post subject: Buying and Selling motorbikes |
Can I make a living doing this? I want to make a decent amount of money doing this on the side at least. I've got a lots and lots of tools- more than enough for working with bikes(abba equipment and all that) but I only have experience as an amateur mechanic working on my own.
I was thinking of getting bikes from auctions like Copart. I've seen as an example this Africa Twin which is a cat B and 26k miles and front end damage. https://www.copart.co.uk/lot/44627479
It says the retail value is 7000 but I know it won't reach that. It looks like the front end is bent. Say I don't know how to fix it and have to go to a professional mechanic, how much profit do you think I can make?
I would please appreciate some advice on this specific example, how I should choose a bike, good mechanics to go to if I can't do something myself and just doing this whole thing in general whether it's a good idea or not.
Edit: What about for parts? how many times more valuable is a bike in parts as opposed to whole? |
| Shaft |
 Shaft World Chat Champion
 Posted: 09:48 - 02 Sep 2019 Post subject: |
The first thing to note is that Cat B is a breaker, ie it shoudn't go back on the road. - the ad indicates there is no V5 and the DVLA have become much more switched on to not issuing V5s for Cat A/B vehicles, so I would assume you aren't going to get one.
Next it says unless it specifically states otherwise (and it doesn't) assume it's a non runner - if you can't get it running, that makes the single most valuable part of the bike virtually worthless.
That's potentially a big project for someone asking the sort of questions you are, I would be giving that a big swerve and starting with something more straightforward. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 09:58 - 02 Sep 2019 Post subject: |
The thought occurs, 'NO' simply.
Reasoning goes something like, if you are buying from auction, anything you 'win' will have first, only got to auction after a fair few folk with much more know how and a lot better contacts have deemed it Beyond Economical Repair... and b) you will have had to pay not just more than they would but also more than a lot of more clued up optimists that hope to get a 'cheap' fixer-upper....
Defeatist idea that if anything is beyond you, taking it to a pai9d pro, then adds more weight to the idea you dont have enough know-how to either spot candidates you coule more likely fix up, or fix them more cheaply...
But then the 'Paddy' argument that 'other folk' can and do if not make a living, at least make a profitable hobby from it, over=rides that and chucks you back in the frey on wing and a preyer of chance...
In short.. Yes and No... nut the business plan needs more work....
I wouldn't stake the day job on it, though.... and I dont have one! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Cookiemonster... |
| Ste |
 Ste Not Work Safe
 Posted: 11:42 - 02 Sep 2019 Post subject: |
For breaking to sell for parts, IMO you'd be better off buying second hand bikes in good condition rather than write offs.
Use eBay to work out what the parts from a particular bike should sell for. Complete set of undamaged fairings, tank, footpeg hangers, engine, frame with v5, forks, front brakes, subframe, clipons and the wheels with discs are all parts which will sell quickly and easily for popular sports bikes. Expect to have things like the swingarm kicking around in your garage for a while.
"There are plenty of CatN's at auction and they run more than fine with only structural damage and they surely can't be uneconomical"
I wouldn't count on it.  |
| Rob Fzs |
 Rob Fzs World Chat Champion
| MarJay |
 MarJay But it's British!
| Bhud |
 Bhud World Chat Champion
 Posted: 13:25 - 02 Sep 2019 Post subject: |
I think it can be done, although not if you're a straight-down-the-middle sort of guy.
Take that Africa Twin, for example. Before I even clicked the ad, I assumed people were bidding silly money for an old wreck (the way "salvage" basket cases often sell for more than intact bikes on Ebay, perhaps because of bulk buyers and shill bidders). I look and check, and yes, someone has apparently bid £1300 for that bike. It will probably go much higher. But why?
As others have stated, a Cat B cannot go back on the road. Or can it? The bike could be broken for parts, the parts being stored in someone's garage and sold piece by piece over years. That's one way to profit, but it's no way to "run a business". The other is to put it back on the road. How? Well, find a bare frame with V5 (set aside at least £250 for this) and for some broken parts such as fork work, mudguard, etc. (set aside another £250 for these).
That's a lot of work and time and expense, and you're going in blind. You might not even find a 2017 Africa Twin bare frame with V5 for sale.
Just speculating here, but the realistic way to turn that bike into profit must be to strip it down, make good use of an angle grinder and welder to get rid of the VIN, get a fake frame stamp made up in an EU country, and then re-register it here as an "import" even though it never left these shores. Something along those lines. Criminal stuff. |
| Stalk |
 Stalk Brolly Dolly
| Cookiemonster... |
| Ste |
 Ste Not Work Safe
| Cookiemonster... |
| Bhud |
 Posted: 13:45 - 02 Sep 2019 Post subject: |
People could be buying them because they want a project bike, or because they do periodic bulk buys and take them over to Europe, e.g. once a month in a truck (not with criminal intent, but simply because people can fix them up and re-register them cheaply there).
I have heard of Polish people (in the early days, when they first started coming here) doing cheap work in people's houses, outfitting bathrooms, etc. and taking the (used!) toilets, basins and baths in their vans back to Poland. They used to tell the homeowner that they were going to dump these items, but no, they either installed them in their own homes in Poland, or sold them in Poland. They were always going across the Channel so it made sense to do this. Now those guys are rich. I don't think VAT ever hoved into their view on the way there.
There's always a grey area in business though. I've never heard of anyone who makes a living buying and fixing crapped-out bikes and then selling them for a profit. However, I know of mechanics who don't ask questions (e.g. "do you really own this moped") and who prefer to be paid in cash. |
| Ste |
 Ste Not Work Safe
| Riejufixing |
 Riejufixing World Chat Champion
 Posted: 13:53 - 02 Sep 2019 Post subject: Re: Buying and Selling motorbikes |
| Cookiemonster14 wrote: | Can I make a living doing this?
Make a living? If you go into it bike-shop style, maybe, if it's a sideline, I very, very much doubt it, but I should think you will get something.
Re that particular bike, as has been said, you cannot put it back on the road. You'd have to buy it, strip it, cut up the frame and dispose of it, and tell DVLA that you have broken it up and scrapped it or they will send you something nasty that will eat into your profit.
So if you fancy a punt, do your research first. Look to see what other people are charging for used parts to calculate what you can pay with expenses taken into account and any margin of profit you want. Be realistic about the value of parts. You won't want to have a load of stuff hanging around that you can't get shot of 'till the year after next, so you will need to undercut other vendors for a quick turnover.
Edit: some good points in this thread for you to think about! |
| P.addy |
 P.addy Red Rocket
| SirFallalot |
 SirFallalot Trackday Trickster
 Posted: 14:44 - 02 Sep 2019 Post subject: |
| Bhud wrote: |
I know someone who's outfitted their own house with a lot of things from a job at a "upper" class house. From kitchen cabinets and appliances to bathroom and carpets, the house was bough and nothing was old/boken, but the new owners wanted wanted a make over.
For more run of the mill things, he keeps and offers it to the lower end customers with broken things who can't afford new things for a fair price or puts them on ebay, essentially turning waste he needed to dispose of into profit.
As for the bike business, there's 10 other people like you looking into the auction thinking the same thing, it's not worth your time and money believe me. Only way you could do this is if you got it locally, but as soon as it's on an online auction site, you're gonna pay more than what would make it profitable, because:
1.There is probably a pro looking at it, and he knows how much he can pay for it until it becomes close to breakeven, thus not worth it.
2.win you need to outbid him.
3.If you've outbid him ,it means your chances of profit are either slim or not worth the time you'll spend on it.
Don't forget, it doesn't matter if you've bought a bike for 100, spent 500 on it, and sold it for 2000. If that takes over a full time week, then you might as well have gone to work instead with less risk![/list] ____________________
Lexmoto Valiant 125; 94 CB400; 96 CB750F2; 81 CB750 (restoring, lol not gonna happen); 2001 ZX9R(It's about to go :c); 2012 R1200R; 2015 R1200RS |
| Cookiemonster... |
 Posted: 15:34 - 02 Sep 2019 Post subject: |
£4k investment on the 2006 new model R6 gives a £1500 profit on my excel spreadsheet. I can take the whole bike apart in a day but all the bits and bobs will all sell over a matter of months so I can't reinvest that in more bikes sad times
1.5k profit per bike is not too bad though. I think I may go for the older model of all these sportsbikes... the older parts are the first to be listed and more of them and the initial purchase is way lower.
that would be a 5.5k profit and no investment if I just nicked the damn thing though. I see why people steal bikes now
I was watching police interceptors and one of them from the traffic unit said for a really expensive audi that was stolen by car thieves I think worth 50k+ : they steal them and they sell the parts for 10x original value so 500k+. surely he must be talking total shit? That must be too good to be true right? That can't happen for any vehicle?? otherwise you'd just steal two or three initially and then go legit wouldn't you so no more risk on your part and only slightly less profit at 9x (minus the inital legit investment)
anything more insightful perhaps?
| Ste |
 Ste Not Work Safe
| Riejufixing |
| Riejufixing |
 Posted: 16:32 - 02 Sep 2019 Post subject: |
| Bhud |
 Posted: 16:41 - 02 Sep 2019 Post subject: |
| TheWhiteBaron wrote: | As for the bike business, there's 10 other people like you looking into the auction thinking the same thing, |
Not like me. I am not the guy considering this as a business. I did my research, visited the salvage warehouse in Egham, etc. years ago. The numbers don't work out, as I said in my original post. Those wrecks often sell for even more than perfectly intact equivalent bikes. Thinking out of the box, it could work if you're constantly taking a van or truck to or from eastern Europe, where there are people who could put bikes back in working order for peanuts, and where you could re-register them without having to worry about insurance cats. Alternatively, going the all-out criminal route, ringing the frame, sticking a fake European VIN badge on it, then re-registering it as an "import" here.
I don't have much truck with either option, I have quite a few used bike parts on the bay (from old projects and bikes I've owned in the past), and they've been sitting there for months. I don't need to fill my garage with even more junk, either. |
| 1198 |
 1198 World Chat Champion
| SirFallalot |
| adam277 |
 adam277 Spanner Monkey
The last post was made 7 years, 49 days ago. Instead of replying here, would creating a new thread be more useful? |
