Author |
Falco |
Falco Traffic Copper
Back to top |
jaffa90 |
jaffa90 World Chat Champion
Back to top |
ThunderGuts |
Back to top |
WD Forte |
WD Forte World Chat Champion
Back to top |
stinkwheel |
Back to top |
kawakid |
kawakid World Chat Champion
Back to top |
Falco |
Posted: 13:55 - 10 Sep 2019 Post subject: |
I ran through this flowchat this morning: PDF
Everything checked out fine (minor exception was theVac test on the stator. At 5K rpm the readings between stator wires were 41.6/41.5/41.1 Vac. The chat states less than 50 Vac indicates stator fault but that seems pretty close (and all the values are pretty close to each other).
It's looking like the reg/rec. The RR has 3 yellow(stator) wires, a red/white (battery +ve) and a green (battery -ve).
ThunderGuts wrote: | If it's that intermittent, could it be a dodgy ground somewhere that's shaking loose occasionally? |
WD Forte wrote: | CB500?
If the RR has a Black sense wire as well as a Red/White and Green
output wires, I d say it's probably got a poor sense connection.
If this black wire 'floats' the output voltage will rise and I've seen this issue quite a few times.
I alway strap my Black sense wire to the battery positive on these
older type RRs and never have any overcharging issues.
If it only has 2 output wires then it's internal sensing type
so ignore what I just wrote
and as Thunderguts says, I'd suspect an intermittent ground |
stinkwheel wrote: | I'd go with a bad earth too. Or the reg/rec breaking down when hot.
If all the connections are good, then suspect the reg/rec. |
No sense wire as far as I can tell, just the 2 outputs. Dodgy ground seems to be likely culprit. Are there any I should specifically check (beyond the main one the RR sits on itself)
kawakid wrote: | I noticed the reg/rec on mine after the bulbs started to blow.
Be careful, if your bike has an ECU it could blow it. |
The lights could be a good warning sign and I'm going to give the main earth a good clean. ____________________ I tell you what, mathematically, I'm having it
Back to top |
stinkwheel |
Back to top |
ZebraDriver |
ZebraDriver Scooby Slapper
Back to top |
Falco |
Posted: 22:58 - 10 Sep 2019 Post subject: |
stinkwheel wrote: | Any green wire from reg/rec goes to earth somewhere. |
I was hoping it would earth on the frame where the RR bolts on (with the additional green wires attached via a ring terminal).
I don't suppose you happen to know where the other earth points are on the CB500S from your time with Mrs Stinkwheel's CB500? I don't recall coming across other earths, though there must be some.
ZebraDriver wrote: | Not talking bikes but I have seen a similar thing on cars twice. Both intermittent and both caused the voltage to rise (lights suddenly get brighter, heater fan speeds up etc). In addition the cars would not start occasionally, but would start 20 minutes later.
After a lot of pissing about, trying to catch the fault when I could test things I discovered that the fault on both occasions was the battery. It was disconnecting itself internally and then, when left alone for 20 minutes or so would quietly re connect itself and the fault would go away for a couple of days.
Not saying that this is your fault, but worth bearing in mind
ZD |
I'll keep an eye on the battery, it was day time when the spikes happened so I don't know if the lights got any brighter. No issues starting (well, beyond the usual complaints when the temp is below 10C) ____________________ I tell you what, mathematically, I'm having it |
Back to top |
Falco |
Posted: 14:00 - 14 Sep 2019 Post subject: |
This is starting to get on my nerves.
Out on a ride yesterday and it spiked to 18V for ~5 minutes before returning to normal (Rising from idle at 12.4V, to 14.5V at 4K RPM, then dropping to 13.5V above that). Rode it slowly around backstreets to overheat the bike but it topped out at 14.8V.
Checked everything again this morning. Stator gives 0.6 Ohms between all 3 wires (haynes puts resistance specs between 0.18-0.20 Ohms but I've seen almost everywhere else say anything less than 1 Ohm is fine. Is Haynes being conservative or is the stator a bit wonky?), 11Vac @ idle, 41Vac @ 5K, 45Vac @ 6K. Not sure what to make of those since it's supposed to be >50Vac @ 5K RPM, but they are all pretty close to each other.
RR checks out fine (of course). Earth terminal (and surrounding area behind RR was cleared of rust and crap). Idled the bike and tried pulling all the bits of the harness I could get to (to simulate bad earth/bad connection) with no change of voltage at the battery.
Kind of pulling my hair out with this one. Supposed to be going on a trip back home next week, but the idea of being stuck on the motorway at 8K with the battery seeing 18V+ makes me nervous. What are the odds it is the RR as I can get a SH693-12 replacement (with fins!) by tuesday or wednesday if pull my finger out, but replacing random parts and hoping is not my prefered method of repair. ____________________ I tell you what, mathematically, I'm having it |
Back to top |
Kawasaki Jimbo |
Back to top |
Nobby the Bastard |
Back to top |
Triton Thrasher |
Triton Thrasher Could Be A Chat Bot
Back to top |
stinkwheel |
Back to top |
The last post was made 4 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
