Making control cables.
Riejufixing
PostPosted: 22:19 - 20 Sep 2019    Post subject: Making control cables. Reply with quote
Any good sources for parts (inner 19 &/or 7x7, outer, nipples, fittings etc.)? Ebay? Venhill? Somewhere else?
PostPosted: 22:27 - 20 Sep 2019    Post subject: Reply with quote
Vehicle wiring products do a fair few cable parts.
bikenut
PostPosted: 15:33 - 23 Sep 2019    Post subject: cables Reply with quote
As above, but get some tinmans and bakers fluid, also a really good wire cutter and soldering iron, old school.........
Remember its the inner cable "mushroom" and solder that hold the inner in the nipple, not just the solder.
nuts about bikes
PostPosted: 16:06 - 23 Sep 2019    Post subject: Reply with quote
I've started doing it by dipping them in flux then a solder pot rather than using a soldering iron.
https://lh3.googleusercontent.com/dkNmNYcmpnlEME_goU1wWAALrZ00YRy86GwJXp_gzzXOij1bnAQbNHrodA0MW9ad4EGrf72ZlvysL5vPhZ6r5R2XhfUBmks2iuTXGYgzuEGBJyUo1oxpUf5drpLVDQjT5pc5JzQOnQ=w1335-h1002-no
https://lh3.googleusercontent.com/DkBXoJV3aNUmfGzOxDqK00ASfBYHHr1OHQu1o_56qiBlSqC0kqUV2XJUPhQ7FZPdCV59TWLXPMLAxp9S60gyzQQDalj3TgTHnULVLCKJFjmVwcw_G9tHitSVzIHnnRXoKM4W5_KILg=w1335-h1002-no
Riejufixing
PostPosted: 17:10 - 23 Sep 2019    Post subject: Re: Making control cables. Reply with quote
I used Laco flux and cut the inner on a bench grinder (tie it with thin copper wire before cutting), and a gas flame, carefully, for heat since it's only a throttle cable. I didn't have the correct nipples at the weekend, so made one from a scrap of brass (1mm drill forthe cable, 4mm for the burred end). I like Laco flux, it's pH neutral and washes off easily.
Crap pic:
The last post was made 7 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.55 - MySQL Queries: 16 - Page Size: 46.44 Kb
