Author |
Kawasaki Jimbo |
Kawasaki Jimbo World Chat Champion
Back to top |
stevo as b4 |
Back to top |
Easy-X |
Easy-X Super Spammer
Posted: 12:00 - 13 Oct 2019 Post subject: |
stevo as b4 wrote: | Yes you should if you have a skimmed and flowed cylinder head, and you run on super unleaded or race fuel.
In essence it does nothing for peak power on a std engine, just moves the torque delivery around favouring low down response. If you run high octane fuel then advancing the part throttle timing might get you something worth having. But an ignition advancer rotor is old school and vastly inferior to a fully programmable ignition. The thing on a four stroke bike is that unless you've been into the engine for serious tuning, then a tunable ignition map won't really make much difference to performance on a std bike. Your better off just messing with fueling for exhaust and intake modifications IMO. |
Purely for educational purposes, what does advancing the timing do, as a general concept? ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
Riejufixing |
Riejufixing World Chat Champion
Back to top |
Bhud |
Bhud World Chat Champion
Back to top |
weasley |
weasley World Chat Champion
Back to top |
Riejufixing |
Back to top |
Easy-X |
Posted: 18:17 - 13 Oct 2019 Post subject: |
Um, so firing at TDC would only be "okay" if the flame front moves at high speed, e.g. Hydrogen. For petrol it takes a little longer so you spark a touch earlier so the point of highest pressure, i.e. the flame front has got to the sides of the cylinder, is just on the downstroke. Have I got that right?
Advancing the timing is sparking earlier and retarding the timing is later?
And where does knock and high octane fuel come into the equation? ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
misscrabstick |
misscrabstick Crazy Courier
Back to top |
Nobby the Bastard |
Posted: 18:58 - 13 Oct 2019 Post subject: |
weasley wrote: |
If by “earlier” you meant “later”, then spot on.
The spark normally goes off some time before top-dead-centre (TDC), meaning that the the combustion starts as the piston is still moving up. This means that the first little bit of effort put out by the combustion is actually working against the engine, but eventually the piston moves past TDC and the bulk of the combustion happens during the down-stroke.
If you have a higher compression and use more knock-resistant fuel (higher RON) you can get away with advancing the spark so it happens later, meaning more of the ‘bang’ goes into pushing the piston down rather than slowing it down. |
Actually, advancing the ignition means the spark happens earlier.
Most ignitions have a method of advancing the ignition as the engine revs incre|se because the bang needs time to propgate. Typically, the spark actually happens before the piston is at tdc. As the engine speed increases the spark has to be earlier as that the propogation of the compustion takes the same length of time . if it wasn't earlier, the bang would happen progressivly after tdc as revs increase, costing power.
most rev limiters actually work by retarding the igntion, stopping the engine from overrevving. If they just cut the spark entirely , fuel mixture would just go down the exhaust and go bang really loudly every time you hit the rev limiter. ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Sprint ST 1050 |
Back to top |
Riejufixing |
Back to top |
Riejufixing |
Back to top |
weasley |
Back to top |
The last post was made 4 years, 194 days ago. Instead of replying here, would creating a new thread be more useful? |
