Slightely above the max notch
Oil level above the max notch
Leave it as is
50%
 50%  [ 9 ]
Suck the excess out
11%
 11%  [ 2 ]
It's gonna explode any minute now
16%
 16%  [ 3 ]
I love polls and clicking stuff online
22%
 22%  [ 4 ]
Total Votes : 18
RhynoCZ
PostPosted: 23:08 - 26 Oct 2019    Post subject: Slightely above the max notch Reply with quote
Today I changed the oil of my XBR. I filled the oil tank up, started the engine, after that I checked the oil level and it was alright. Then I had a ride and now the oil is slightly, perhaps a millimeter, above the max notch on the dipstick. Do I bother sucking that extra excess out or just leave it to be burned away?
PostPosted: 23:14 - 26 Oct 2019    Post subject: Reply with quote
For christ sake don't lean the bike round any corners or it'll go up to 2mm.
RhynoCZ
PostPosted: 23:17 - 26 Oct 2019    Post subject: Reply with quote
Off to the garage...
https://media1.giphy.com/media/11NybLJG6LsHx6/source.gif
jaffa90
PostPosted: 01:20 - 27 Oct 2019    Post subject: Reply with quote
You have a major problem, don`t get married and have kids. Shocked
ThatDippyTwat
PostPosted: 06:33 - 27 Oct 2019    Post subject: Reply with quote
While overfilling can cause issues, that's not a problematic level, that's well within margins of error. Silicone tubing dunked in to the filler hole, a finger over then end, remove tubing into receptacle, remove finger, repeat, works well, if slowly, and avoids dumping the lot out. I used 6mm aquarium airline, as that's what I had kicking about. Adding a blunt/mixing syringe to that would greatly speed up the process.
For instance, a YBR125 does not like being overfilled. Changed oil out after buying it and instead of ~1L, it was almost 2. All gearbox clunkiness (other than being a YBR) went away with that. Once I overfilled it by about 100ml, and the clunkiness partially came back.
doggone
PostPosted: 08:32 - 27 Oct 2019    Post subject: Reply with quote
I sold a bike to a neighbour and he topped the oil up with about five litres because he thought it was supposed to be up to the filler cap.
Then it wouldn't turn over ...
No harm done when drained back to normal.
RhynoCZ
PostPosted: 10:15 - 27 Oct 2019    Post subject: Reply with quote
I only ask as now I can hear sort of a hissing sound from the left hand side part of the engine when under load. Thinking
I'm not sure if the sound was there before though and there's no hiss when in neutral. Could be the gearbox, but could as well be nothing.
TbirdX
PostPosted: 10:23 - 27 Oct 2019    Post subject: Reply with quote
is that the clutch basket side? Most likely that if it disappears when the clutch is pulled in.
VFR800X - CFMoto 450MT - TTR250
RhynoCZ
PostPosted: 10:27 - 27 Oct 2019    Post subject: Reply with quote
Nope, it's the stator and starter clutch assembly side. I recently changed the stator, but as said, if it was that it would grind/hiss in neutral as well.
PostPosted: 13:49 - 27 Oct 2019    Post subject: Reply with quote
Useless nuggets of information....
No 1. - BMC B series diesel engines must not be filled above the max line as they have a tendency to blow the crank shaft oil seal if overfilled.
No 2. - BMC B series diesel engines were supplied with dipsticks with no marks on because when used in marine and industrial applications the engines might be mounted on the slant. You were meant to pop mark the dipstick with a centre punch to allow for your mounting arrangement. Work that one out!
HTH Thumbs Up
Triumph Trophy Launch Edition
The last post was made 6 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.68 - MySQL Queries: 18 - Page Size: 70.04 Kb
