a way to improve mirrors on a cbr600 and similar
trevor saxe-coburg-gotha
PostPosted: 14:53 - 22 Jan 2020    Post subject: a way to improve mirrors on a cbr600 and similar Reply with quote
Has anyone ever tried to improve the view and degree of adjustment on their mirrors? For a certain kind of fastening method I came across a really simple method - have a look at this:
https://www.motorcyclenews.com/new-rider/choosing-kit/2012/march/mar1412-how-to-improve-honda-cbr600s-mirrors-/
I'd be into trying this but I can't suss out what to use for that "8mm black PVC" stuff. I searched on eBay but the materials that came up in the results were too much like foam, or were two very thin sheets sandwiching an all but hollow centre. In short they just weren't the right thing.
Riejufixing
PostPosted: 15:32 - 22 Jan 2020    Post subject: Re: a way to improve mirrors on a cbr600 and similar Reply with quote
It's just a spacer. You could use a piece of plastic chopping board, or stick pieces of ABS sheet together, or use some fibreglass, or aluminium, or melt some polythene into a block to cut down, or ....
JackButler
PostPosted: 15:45 - 22 Jan 2020    Post subject: Reply with quote
I thought MCN had dissapeared up its own arsehole 15yrs ago. Does anyone still buy that arsewipe rag???
Mirror extenders have been around since . . . Oooh, mirrors were first invented.
They make the difference between a good view of your elbows to a good view of your shoulders.
I clean my guns with the tears of the snivelling, left wing scum.
PostPosted: 16:25 - 22 Jan 2020    Post subject: Reply with quote
Use delrin/acetyl sheet (cuts/machines like a dream) or aluminium plate.
ThatDippyTwat
PostPosted: 17:47 - 22 Jan 2020    Post subject: Reply with quote
You can also 3D print them these days.
Easy-X
PostPosted: 18:10 - 22 Jan 2020    Post subject: Reply with quote
Mock it up in wood. If it works then plenty of time to find a material you like Smile
PostPosted: 18:50 - 22 Jan 2020    Post subject: Reply with quote
cheers - i was scrounging around for some decently thick alu plate but a small chunk of acetyl sheet's what I'd prefer
PostPosted: 18:55 - 22 Jan 2020    Post subject: Reply with quote
I can't really think that there's any need for a WEEKLY bike publication in this day and age but it's little more than glorified advertising at this point. And what they advertise isn't bikes so much as PCP.
PostPosted: 18:57 - 22 Jan 2020    Post subject: Re: a way to improve mirrors on a cbr600 and similar Reply with quote
Riejufixing wrote:
stick pieces of ABS sheet together, ....
this was more my least preferred method just because i can't quite be arsed
redeem ouzzer
PostPosted: 19:06 - 22 Jan 2020    Post subject: Reply with quote
Don’t need mirrors for MOT.
Be a REAL MAN!
Kawasaki Jimbo
PostPosted: 20:20 - 22 Jan 2020    Post subject: Reply with quote
He’s extended the reach of the mirrors for much improved field of vision.
With 8mm?
PostPosted: 20:34 - 22 Jan 2020    Post subject: Reply with quote
or just use the wood. It's incredibly strong in compression. Epoxy over it and it'll be weather proof.
Ply will work fine or you could find an offcut of something fancy for "detail" like a luxury car door inlay. Maybe two 3mm sections of burr walnut with a thin layer of brass in the middle.
PostPosted: 21:25 - 22 Jan 2020    Post subject: Reply with quote
With 8mm?
i know - i do think it would make a bit of a difference though
sickpup
Old Timer
PostPosted: 00:34 - 23 Jan 2020    Post subject: Reply with quote
Could even go on ebay and buy a set for around £15 if you're feeling Lazy. Look for CBR600 mirror extenders.
Riejufixing
PostPosted: 01:06 - 23 Jan 2020    Post subject: Reply with quote
With 8mm?
Nothing to stop you using long set bolts or studding and nuts to see what happens. You could at least see what would happen with vatious "thicknesses" of spacer.
Confusion
PostPosted: 21:53 - 24 Jan 2020    Post subject: Re: a way to improve mirrors on a cbr600 and similar Reply with quote
Has anyone ever tried to improve the view and degree of adjustment on their mirrors.
I put some spacers/extenders on the mirrors of my Bandit S.
Something similar to this: https://www.justbandits.com/mirror-wideners.html
Mine cost a bit less on eBay. They are a big improvement over the
standard setup.
Bandit 650SA, ZZ-R1100
The last post was made 6 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.05 - MySQL Queries: 13 - Page Size: 89.97 Kb
