Thinking on an exhaust for the Rebel
Easy-X
PostPosted: 16:02 - 27 Jan 2020    Post subject: Thinking on an exhaust for the Rebel Reply with quote
The stock exhaust on the CMX500 is a bit of a lump:
https://www.honda.co.uk/content/dam/central/motorcycles/colour-picker/street/cmx500_rebel/cmx500_rebel_nv_2019/nh-303m_matteaxisgreymetallic/cmx500_rebel_nv_2019_nh-303m_matteaxisgreymetallic.png/jcr:content/renditions/c4.png
It's so wide it actually goes beyond the foot pegs and is the biggest "sticky-out-bit" on the bike (beyond the handlebars.) I don't like it Sad
There are a few Rebel-specific exhausts that mostly look like Chinese crap with an extra bit of pipe welded to them and totally overpriced. Instead I'm considered a link pipe but the only one I've found is the Lextek:
https://www.lextekproducts.com/img/125100185_300.jpg
Which is okay but it doesn't have those loops for springs. Are those really needed? Is it hard to weld them onto stainless steel?
redeem ouzzer
PostPosted: 18:07 - 27 Jan 2020    Post subject: Reply with quote
Just leave it stock. Anyone who fits an exhaust for reasons other than dyno proven power gains should be killed.
Be a REAL MAN!
PostPosted: 19:17 - 27 Jan 2020    Post subject: Reply with quote
Yes, welding to stainless steel is hard unless you have the correct TIG setup.
Silver soldering, not so hard, providing you have an appropriately strong source of heat.
WD Forte
PostPosted: 19:22 - 27 Jan 2020    Post subject: Reply with quote
Sod the zorst, I'd be after a proper front mudguard
(anna mudflap too)
bikers smell of wee
Easy-X
PostPosted: 19:58 - 27 Jan 2020    Post subject: Reply with quote
(anna mudflap too)
That's on the list Thumbs Up
Fair enough an exhaust isn't an essential but it annoys me twice a day when I try and get in and out of my front gate. Aesthetics and practicality, not so interested in performance or sound.
<addendum> rear view:
https://cdp.azureedge.net/products/USA/HO/2019/MC/CRUISER/REBEL_500/49/CANDY_ORANGE/2000000005_480px.jpg
WD Forte
PostPosted: 20:19 - 27 Jan 2020    Post subject: Reply with quote
Just widen the gate then!
I'd be after something like an SR1168 for it too
( JFGI Laughing )
bikers smell of wee
Easy-X
PostPosted: 20:25 - 27 Jan 2020    Post subject: Reply with quote
( JFGI Laughing )
Top box? Already taken off the pillion seat and got that Smile
Gate pillars are made of brick Sad
stevo as b4
PostPosted: 20:30 - 27 Jan 2020    Post subject: Reply with quote
^ This x1000!
I've always said changing exhausts, air box's, filters should only ever be done for engine tuning reasons. This could be as a result of engine tuning needing aftermarket or custom pipework/induction to get the benefits of the work done.
Or it could be done in its own right to improve engine performance through better breathing.
Sadly performance is usually the least favourite reason these days for people changing exhaust systems. Looks, individuality and then sound are top of most peoples reasons for wanting to change exhausts.
They fail to see how much work and development that the manufacturers put into OEM stuff, and are prepared to screw up performance for a garish looking burnt tip fancy exit look at my pipe abomination.
ThatDippyTwat
PostPosted: 20:35 - 27 Jan 2020    Post subject: Reply with quote
Weight loss. Some modern cans weigh a fucking ton. Easily a 5KG difference between my Delkevic and a standard can, if you can find one, on the VFR750, and I imagine a modern bike is probably worse.
PostPosted: 20:56 - 27 Jan 2020    Post subject: Reply with quote
I primarily changed the one on my VFR so I can get the back wheel out without removing the exhaust.
Also because micron.
WD Forte
PostPosted: 21:20 - 27 Jan 2020    Post subject: Reply with quote
Back the car into it
job done
bikers smell of wee
Bhud
PostPosted: 21:26 - 27 Jan 2020    Post subject: Reply with quote
If you see a 1980s Kawasaki on the road, chances are high it will have a complete aftermarket exhaust system. The originals are very rare now, and command a high price if they're pristine. Exhausts rot, badly, over time. Motad's business model relied heavily on that. They used to boast that their exhaust systems were not only fully compliant with whatever noise limits were applicable to a particular bike under C&U regs, but that their systems were plug-and-play, and didn't require rejetting.
Easy-X
PostPosted: 22:28 - 27 Jan 2020    Post subject: Reply with quote
Mmm... I can't use a standard paddock stand because of the fat exhaust.
redeem ouzzer
PostPosted: 22:33 - 27 Jan 2020    Post subject: Reply with quote
I don’t think weight is an issue here, it’s a fucking 500 rebel. Unless you cut half of it off and chuck it in the skip it’s never going to be light.
Be a REAL MAN!
PostPosted: 00:43 - 28 Jan 2020    Post subject: Reply with quote
Aye. Tell that to the hundreds of GPZ500s up and down the country with holes melted in the right hand side of their belly pan. Wink
Sister Sledge
PostPosted: 09:13 - 28 Jan 2020    Post subject: Reply with quote
You can also stick weld stainless but it can be a 'sticky' faffle on. It's also thin metal so just don't. Tig is the answer.
As mentioned by others just stay with the exhaust. It can get complex because performance will be affected.
CCM 404 DS
Easy-X
PostPosted: 11:43 - 28 Jan 2020    Post subject: Reply with quote
Point taken on stainless. If I do ever get into welding it'd probably be a cheap MIG to start with so that says mild steel I guess.
Of course unless one is approaching mods in entirely the wrong fashion the whole point is if you don't like it you put the original parts back on Smile
I shall think on it, thank you all for your advice Thumbs Up
xX-Alex-Xx
PostPosted: 21:17 - 28 Jan 2020    Post subject: Reply with quote
How about taking 5-10kg off the side of the bike, and not having to worry about burning tailpacks etc if you switch to carbon cans? Thumbs Up
DILLIGAF
The last post was made 6 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.81 - MySQL Queries: 16 - Page Size: 104.46 Kb
