Kawasaki z800 clicking feeling/sound?
Samuel2524
PostPosted: 19:21 - 10 Feb 2020    Post subject: Kawasaki z800 clicking feeling/sound? Reply with quote
Please move if in wrong topic.
Lately out of nowhere my z800 has started clicking when (typically) in first gear. Sometimes second or other gears also I think.
It’s almost like the chain is slipping ? Or a gear slipping or something. It happens before transition. And it jolts like fuck. Sometimes feels like it’s gonna throw me off.
Any ideas what this is or how to fix it pls ? Did I over grease my chain or something (not that mechanically sound)
Thanks in advance
PostPosted: 19:27 - 10 Feb 2020    Post subject: Reply with quote
This should probably be in the workshop section... It would be better to choose the right section from the start rather than relying on the overworked mod who still actually moderates this forum!
Anyways, what is your chain tension like? What do your sprockets look like? can you post a photo of your front and rear sprockets? In the middle of the lower run of the chain, how far can you move the chain up from resting before it's taut?
doggone
PostPosted: 19:29 - 10 Feb 2020    Post subject: Reply with quote
It might just be the chain near the end of its life.
Have you been adjusting it as it wears, how much more adjustment is available.
Samuel2524
Anyways, what is your chain tension like? What do your sprockets look like? can you post a photo of your front and rear sprockets? In the middle of the lower run of the chain, how far can you move the chain up from resting before it's taught?
Sorry mate. I wasn’t sure where to put it tbh.
I’ll grab some pics when I get home !
Samuel2524
PostPosted: 19:35 - 10 Feb 2020    Post subject: Reply with quote
I havent touched it mate. It had its MOT in summer idk if they would’ve checked that. Will get pics ASAP !
Samuel2524
PostPosted: 21:50 - 10 Feb 2020    Post subject: Reply with quote
Kinda embarrassed I didn’t look at the chain before posting this but here we are lol. It’s clearly loose / knackered.
Should I tighten it or get a new chain? What’s the next step , could I do either of those easily enough or is it a garage job?
Thanks
Nobby the Bastard
Harley Gaydar
PostPosted: 22:06 - 10 Feb 2020    Post subject: Reply with quote
Thanks
https://www.bikechatforums.com/download.php?id=103110
Fuck me, that's knackered.
Triumph Sprint ST 1050
doggone
PostPosted: 22:31 - 10 Feb 2020    Post subject: Reply with quote
You can see some of the links aren't in line, the pivot points are partially seized.
Chuffin Nora
PostPosted: 02:04 - 11 Feb 2020    Post subject: Reply with quote
Nobby the Bastard wrote:
Thinking Maybe so, but not so knackered that it couldn't manage to get the bike half-way up the wall. Shocked Thumbs Up
Besides, more pressing that (as the rest of BCF will, I'm sure, agree -- albeit doubtless putting the willies right up OP's mechanical unsoundness) the subframe's bent. Neutral
There. Said it.
Ipso someone'll be, before long, along with tree-fiddy in their pocket.
There's a fine line between integrity
Samuel2524
PostPosted: 02:46 - 11 Feb 2020    Post subject: Reply with quote
There. Said it.
In quite a few less words. What’s the sub frame.
Nobby the Bastard
Harley Gaydar
PostPosted: 07:44 - 11 Feb 2020    Post subject: Reply with quote
How the fuck did you get to the point of riding an 800 cc bike without learning chain maintenance?
trevor saxe-coburg-gotha
PostPosted: 07:51 - 11 Feb 2020    Post subject: Reply with quote
Thanks
gr8 b8 m8
Easy-X
PostPosted: 11:01 - 11 Feb 2020    Post subject: Reply with quote
And where's their registered carer in all of this? Thinking
Samuel2524
PostPosted: 14:07 - 11 Feb 2020    Post subject: Reply with quote
I just went out and bought one. You’ll love how I learned to ride too. Went out and bought a bike no licence or lessons when lived in Asia. No helmet too. T shirt and shorts bro
Fisty
PostPosted: 17:34 - 12 Feb 2020    Post subject: Reply with quote
The name fits the level of retardation.
Fatter and faster than Fret
Samuel2524
PostPosted: 18:00 - 12 Feb 2020    Post subject: Reply with quote
Ok, ‘fisty’
bhinso
PostPosted: 18:11 - 12 Feb 2020    Post subject: Reply with quote
In the year 2524...
Dance!
Nobby the Bastard
Harley Gaydar
PostPosted: 18:32 - 12 Feb 2020    Post subject: Reply with quote
One wonders what other horrors lurk on that bike if something as obvious and visible as the chain has been allowed to get into that condition.
Riejufixing
PostPosted: 22:15 - 12 Feb 2020    Post subject: Reply with quote
Take a side-on photo of the rear sprocket, showing the teeth, and the front one too, post them. Whatever you do, assuming you're going to use it before you replace at least the chain, you should at least adjust the tension and oil the chain properly, "every little helps". I would say it's chain & sprockets time though.
Edit: https://www.youtube.com/watch?v=Sym2BLy6lVE
PostPosted: 09:11 - 13 Feb 2020    Post subject: Reply with quote
Take it to a competent trusted motorcycle mechanic/garage and get them to replace the chain and sprockets. At the same time get them to safety check the whole bike. Just on the chain alone that is nearly a deathtrap, so I dread to see what the brakes and suspension look like... Shocked
PostPosted: 09:12 - 13 Feb 2020    Post subject: Reply with quote
A side note, how apt is it that the OP couldn't find the 'workshop' area of the forum, when his bike has clearly never been near a workshop itself!!
ZRX61
Victor Meldrew
PostPosted: 11:27 - 13 Feb 2020    Post subject: Reply with quote
MarJay wrote:
Take it to a competent trusted motorcycle mechanic/garage....
I'd tell him to bugger off & came back after he's cleaned the bike.
How the hell is he supposed to notice anything is wrong is he doesn't clean it at least once a month... Can't believe the amount of people who never clean their bike & then wonder WTF is going on when a problem comes up. It's basic maint 101 Smile
Even if they are mechanically useless as least they should have enough brain power to notice something different from the last time they cleaned it.
They're not one night stands, they're auditions.
Riejufixing
PostPosted: 11:31 - 13 Feb 2020    Post subject: Reply with quote
PostPosted: 11:37 - 13 Feb 2020    Post subject: Reply with quote
I've seen dirtier, but the issue is the chain more than anything. My commuter for example, is currently completely filthy. However, I do clean and lube the chain regularly and I did treat the bike with ACF50 before the winter, so the dirt in that case is deceptive. Not everyone has a place where they can wash a bike, and not everyone has the option of not using the bike.
However, to let the chain get that bad, and then wonder why there are funny noises coming from the bike? That's pretty unforgivable I think.
Nobby the Bastard
Harley Gaydar
PostPosted: 12:17 - 13 Feb 2020    Post subject: Reply with quote
The strumpet hasnt been washed for about a year and is as filthy as Mrs Bastard.....
The last post was made 6 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.88 - MySQL Queries: 16 - Page Size: 134.96 Kb
