CB750f2 damage pistons
jo007
PostPosted: 16:45 - 12 Apr 2020    Post subject: CB750f2 damage pistons Reply with quote
HI all
I am a newbie here and in desperate need of help.
I have taken the engine off my CB750f2 and the pistons are clearly damaged, what I dont seem to be able to work out is how to take the Cylinder block off in order to replace the pistons.
https://photos.app.goo.gl/qZawh4X78DwDd5ab6
I have, in the last picture, highlighted in yellow the part I am trying to remove although I am opened to suggestions from those more mechanically oriented.
Any help would be greatly appreciated.
Thanks
Evil Hans
PostPosted: 17:02 - 12 Apr 2020    Post subject: Reply with quote
I can't see any of those photos apart from he second-to-last.
Teflon-Mike
tl;dr
PostPosted: 17:23 - 12 Apr 2020    Post subject: Reply with quote
Which CB750?
FII is very different beast to an F2....
Also erorr 404 file not found when I click the links, too.
PostPosted: 20:25 - 12 Apr 2020    Post subject: Reply with quote
If you want to share photos from google photos either bung all the ones you want to share in an album, click on that album then click the "share" icom (three blobs linked by two lines) and post the share URL on here.
OR if you want to do individual hyperlinks or embed the images you need to navigate to the album they are in, click on the share icon, copy the share link/URL then open that in a PRIVATE browser window (if you are logged in, only you will be able to see the pictures). Click on the picture you want to share and use the URL for that picture (either ffrom the address bar or right click and copy image address). You can then post that link to the forum or wrap it in IMG tags.
Like this:
Code:
 [img]https://lh3.googleusercontent.com/pDNnhbIV9SX15uoGIjfoJxmZANMElsCaE9Wu04pjV8jImPOuHE6PdNhq3MDV6uPUdJgfWPDofQREUGqDgZBwXj6_-AyH2yI2xUCuco8tuiDlyy6XrKUgfLdid3g0p1UmAok8fxOu3A=w578-h866-no[/img]
Will give you:
or
Code:
 [url=https://lh3.googleusercontent.com/pDNnhbIV9SX15uoGIjfoJxmZANMElsCaE9Wu04pjV8jImPOuHE6PdNhq3MDV6uPUdJgfWPDofQREUGqDgZBwXj6_-AyH2yI2xUCuco8tuiDlyy6XrKUgfLdid3g0p1UmAok8fxOu3A=w578-h866-no]stinkwheel riding trials bike[/url]
will give:
jo007
PostPosted: 02:24 - 13 Apr 2020    Post subject: Reply with quote
Hi guys
Thank you all for highlighting the issues with the pics!
Hopefully all working now.
PostPosted: 02:47 - 13 Apr 2020    Post subject: Reply with quote
Are the pistons all moving? I'm not sure what damage you're seeing there? Not immediately obvious on the pictures. Maybe a tad black like it's been running rich or burning some oil.
This is more general advice. Double and triple check for any nuts/bolts you may have missed. They do like to hide the odd one here and there. Look round the back, look down the camchain tunnel. Use a torch and mirtror if necessary.
Then all that can really be holding it is the base gasket sealant or corrosion round the studs.
I sometimes find removing the studs gives you some extra wiggle-room, you ought to be able to unscrew the studs in most engines from this point by locking a couple of nuts together on the top of them. Those two at the front in particular look problematic. Lots of corrosion around them which could be binding the alloy to the steel stud. They want feeding a load of penetrating oil then see if you can get them out or at least moving. Heat cycling and applying penetrating oil can help free them off.
Then it's a case of persistant wiggling and gentle tapping to try to break the seal on the base gasket. Be incredibly cautious. I can see you've already found how easy it is to break cooling fins. I use a rubber mallet. I'd probably try tapping upwards on those chunkier bits of plain metal in the centre of the block (but it's alloy, so be aware you can break that too).
Do not try to pry them up and off with anything. It's tempting to do so but you'll wreck the gasket faces.
jo007
PostPosted: 03:56 - 13 Apr 2020    Post subject: Reply with quote
Hi Stinkwheel
Very helpful mate, thank you. Yes all pistons moving although they have a lot of marks on the top where the valves have been tapping them and hence my reason for wanting to replace them, I will clearly have to look at the timing etc, again, more than willing to take suggestions as I would love the acquire the necessary knowledge to put it all back together properly !! it was indeed running very oil rich also. You are soooo right btw about how fragile the fins are Rolling Eyes
The studs do look like they are somehow bonding to the block, as you have rightly pointed out! I can see a lot of corrosion in them when I look through the gaps as they go through the block.
Thanks again for your help!
Easy-X
PostPosted: 10:20 - 13 Apr 2020    Post subject: Reply with quote
I've had lots of "fun" just trying to get single barrels off... best of luck Shocked
jo007
PostPosted: 10:41 - 13 Apr 2020    Post subject: Reply with quote
Hi Easy-X
Any tips? as I fear I will be having just as much fun as you!!
steve the grease
PostPosted: 10:57 - 13 Apr 2020    Post subject: Reply with quote
Me too, I truggled with my Honda single barrel for more than a week to get it off. Corrosion on the studs was binding the barrel in the holes plus initially the overall sticksion of the base gasket, spray it all with a penetrating oil ( especially down the 8 long stud holes. ) , leave it a week to loosen a bit and try to get a stanley knife blade inbetween the cases and the barrel. Eventually I made a puller that in your case would rest on top of the 4 centre studs and 4 long nuts and bolts ( or studding) through the cam chain casing bolt holes. Tightening the bolts lifts the barrel. ( maybe I should do a picture) Tread carefully. The fins are very brittle as you have already discovered.
jimspeed
PostPosted: 11:42 - 13 Apr 2020    Post subject: Reply with quote
Even zoomed in I cant really see any damage that would warrent piston removal really, recent valve contact would leave shiny marks in the cut outs and the valve stems are so tiny they would just bend out the way before doing any serious damage to the pistons.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
PostPosted: 12:07 - 13 Apr 2020    Post subject: Reply with quote
Glad it's not just me. Looks like a totally intact layer of carbon over the top of them. A valve kissing the top would have left a mark on it.
The only way valve-piston contact could really happen would be if the camchain had jumped or it had been over-revved. I'd expect it to have been much more spectacular with that being the case. Usually when a Japanese OHC motor touches a valve, it all goes to hell in a handbasket almost instantly.
If it was burning oil, I'd be looking at valve stem oil seals.
jo007
PostPosted: 12:20 - 13 Apr 2020    Post subject: Reply with quote
Well gentleman, that's music to my ears!! Very Happy Very Happy
I did say I am a newbie and I didn't just mean to the forum.
Thank you so much for your help guys!!
The last post was made 6 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.27 - MySQL Queries: 16 - Page Size: 85.66 Kb
