| ThunderGuts |
| chickenstrip |
 chickenstrip Super Spammer
 Posted: 19:29 - 18 Jun 2020 Post subject: |
Could be a bit of O ring. Had the same on mine. I wouldn't say it's time to bin the chain if it is otherwise ok though. Remember, not all chains have o rings anyway. With mine, I just kept an eye on it, kept it well cleaned and lubed, regularly checked for stiff links. Had no problems yet (although not riding now, so I don't know how it'd go if I kept putting on the miles - not concerned though). ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
| Nobby the Bastard |
| Confusion |
 Confusion Scooby Slapper
 Posted: 23:08 - 18 Jun 2020 Post subject: Re: Rubber strand |
| ThunderGuts wrote: | Just cleaning my chain and noticed a little bit Of rubber poking out. Obviously my concern is it’s part of the O ring... |
It is a sliver of the O-ring. It's on the rivet link which suggests the
plate may not have been pressed on correctly when it was installed.
| Quote: |
only has 7k miles on it. |
A Japanese made DID should have plenty of mileage left in
it at 7k. Made in Thailand DID could be getting towards end of life
at that mileage.
| Quote: | What do we think? New chain time or can I get away with monitoring until/if the link gets stiff then replace?
Measure the chain length for 20 links. If it is well within spec,
you can: Keep it well oiled and check it regularly
or
remove the rivet link and fit a new one.
| Quote: | I did notice it in one other place too but pulled that little sliver off (again it was attached but it snapped out quite easily and didn’t take the O ring with it). |
If the O-rings are starting to fall apart, you will probably need a new chain
soon. I would suggest you spend some time inspecting the condition
of all the other O-rings, measure chain length and inspect the sprockets.
You will then be in a better position to decide whether you should
continue using it for another while or whether you need a new C&S set now. ____________________ Bandit 650SA, ZZ-R1100 |
| kramdra |
 kramdra World Chat Champion
| MCN |
 MCN Super Spammer
| Polarbear |
 Polarbear Super Spammer
| ThunderGuts |
| Ayrton |
 Ayrton World Chat Champion
| ThunderGuts |
| chickenstrip |
 Posted: 12:46 - 19 Jun 2020 Post subject: |
I will have to whip the cover off and look at the front sprocket, but if it's in similar condition (and the chain is still not showing any stretch) I might be tempted to just change the chain and leave the sprockets (I know it goes against conventional wisdom, but if they're not worn at all and the chain isn't stretched either, may as well save the agro). |
Bottom line for me is money. Sure, if money is no object, replace the chain. I know I'm not replacing mine because of this same thing. If it then got to a point where it was likely to be a real issue, then I'd replace it. But while it's still perfectly functional throughout the range of use it would get, I'll keep the money in the bank. Meanwhile, just keep an eye on things. That's no extra work to me, because the chain is the thing that gets the most regular attention on my bike anyway, what with cleaning, lubing and adjusting. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
| ThunderGuts |
| chickenstrip |
 Posted: 13:04 - 19 Jun 2020 Post subject: |
Because of how much attention my chain gets, I'm likely to spot signs of wear pretty quickly, and so catch it before the sprockets really start to go. If the chain started to get noisy, or there was more vibration than usual not attributable to anything else, I'd think about replacing it. But if it is just a thin bit on the outside of the x ring, there's no saying it will get worse or wear quicker anyway. It might. It might not. In any case, I'd be confident I could catch it before any expense was caused. I'm allergic to expense  ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
| ThunderGuts |
 Posted: 13:13 - 19 Jun 2020 Post subject: |
| MCN |
 MCN Super Spammer
| ThunderGuts |
| chickenstrip |
 Posted: 13:35 - 19 Jun 2020 Post subject: |
| MCN wrote: | O-ring chains do not stretch like non-o-ring chains.
The sealed Pin and Bush assembly prevents pin and bush wear thats a problem in non-o-ring chains.
The sprocket teeth wear and side-plates may get a bit rusty.
'Pitch Extension' is where the wear between pins and bushes are accumulated to provide a measurable dimension. Normally over 5 pins. (Distance between the centres of pins in one link times 5.)
A new chain should be almost zero.
A worn chain will be more. |
What is this sorcery? Begone oh evil one, and let us not consider the quantum effects of chain wear! ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
| Tdibs |
 Tdibs Traffic Copper
| ThunderGuts |
| FretGrinder |
 FretGrinder World Chat Champion
| MCN |
 MCN Super Spammer
| chickenstrip |
 Posted: 10:06 - 20 Jun 2020 Post subject: |
| FretGrinder wrote: | | Nobby the Bastard wrote: | It's an o-ring.
I wouldn't write of the chain immediately but it will wear at that point. |
Lies, it's a powerband.
You can tell it's the fast one because it's black. |
I always thought the power band strapped around the pistons to pull them up and down  ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
| MCN |
 MCN Super Spammer
The last post was made 6 years, 99 days ago. Instead of replying here, would creating a new thread be more useful? |
