Author |
stablepeach |
stablepeach Derestricted Danger
Posted: 21:29 - 04 Aug 2020 Post subject: Gn250 Clean up for rebuild |
Hi everyone, this is my first post and apologies it's likely to be a long one...
TL:DR I've acquired a GN250 in poor shape, is it salvageable?
Background:
It's been 10 years now since I last had a bike, I was quite comfortable tinkering and doing maintenance on it (XJ600N) nothing significant but I did things like replace/repair the exhaust, dismantle and repair starter motor, replace chain, remove wheels etc. All pretty simple stuff I suppose.
I've been struggling with the urge to get a new bike for a long time, mainly due to money constraints and family... I'm now in a position where I'm looking for something to do in my spare time (hobbies seemed to dissappear with babies) and I have a little bit of spare money so that I can afford to gradually buy bits etc.
As such I've come to acquire very cheaply (and I imagine with very good reason) an old GN250.
My intent is to strip it down, clean it up and put it back together again. For two specific reasons - 1 - I'd like to clean it up, remove all the rust and crap and make it look a bit more presentable. but more importantly 2... I've always wanted to do this. I couldn't do this when I relied on the bike as a commuting vehicle and never had the time or money at any other point. I want to get under the bike and understand how it's all put together and put it back again.
I am well aware of my limitations and also that there is a reasonable chance I will fail. I guess that's why I've specifically not invested too much money up front. I'm keen where possible to clean up and reuse the original part.
So I've done the easy bit... I've stripped it down to the different components and started to try and clean them all up... the frame seems to be in reasonable condition - there's surface rust but this cleans up pretty nicely with a wire brush on an angle grinder. The spokes are rusty but again, seem to come up good without too much work and the rims appear in pretty good stead.
The forks look fine apart from rusty nuts on the bottom, I'm not sure at the moment I intend to do anything, maybe just a bit of paint for the look of it.
The swingarm was pretty pitted and has a few small holes (see pictures) I imagine this needs fixing before painting - I've heard of metal epoxy would this be suitable for this type of hole or would I need to get something welded over the top?
The exhausts are really badly eaten into where they met the engine (more pics)... Sand paper and angle grinder have made a difference but given this is into the metal I'm worried that I'll just thin the metal and weaken the exhausts - are these save-able? Am I on the right path or do these need chucking and replacing?
The tank looks to be in ok condition, two small dents I intend to fill and then paint over.
The Engine is a sorry affair, the plating appears to be flaking off, it also looks like someone in the past may have painted it which has also started to peel off. I'm intending to go at this with a brass brush/dremmel tool to see if I can at least clean this down to see what I'm dealing with. I had hoped to leave this bare metal but now I'm not sure if the finish is going to be horrendous.
I drained the oil out as I wasn't sure what state it was in... I'm assuming it would be advisable to refill it even with the engine sitting unconnected?
I guess it's also worth noting that when I got the bike the engine would turn over - so it seems ok in that respects...
My final question for today - Painting vs powder coating...
Originally my intent was to prime and paint this mysefl, however I've been recommended powder coating. When I then read up on a few places I see that many will do the removal of paint and rust and the rust treatment as part of the service. I'm assuming this comes at a cost but suspect they will do an infinitely better job of it than I would - so I just wondered if anyone had done this and whether this would be a better way of achieving the desired result. This is the type of thing I've seen... https://windridge.co.uk/index.php/non-architectural/motorbikes/prepare-frame
I'm sure some will think I'm an idiot and I probably am way in over my head - but that's kind of the point... I want to learn and try things out that I couldn't on a bike I relied on.
Any help and advice is gratefully received and I'm sure that this won't be the last post on this topic...
Thanks a million,
Matt ____________________ StablePeach
Back to top |
Nobby the Bastard |
Back to top |
stinkwheel |
Posted: 22:12 - 04 Aug 2020 Post subject: |
Powder coat is great, they usually media blast it and prep but make sure it's someone used to doing motorbike frames so the mask/plug the bits you do not want coating.
Be aware that media blasting is also great for finding rusted-out parts so don't have a go at them if it comes back looking like a colander.
Pics of swingarm aren't showing for me but if it's rusted to the point it has holes in, I'd suspect it is scrap or would need attention from a good welder with an awareness of structural soundness.
Give the engine a good clean down with paraffin and a stiff paintbrush to get all that crap off it, then hot soapy water, then cold water. Then make a decision.
Others may think different but I personally wouldn't do anything cosmetic until I was happy I had a running motorcycle. I'd want to hear the thing running, even if it's a total lash-up or at least be confident it is going to run. Imagine powder coating the frame, painting the motor, welding the swingarm then finding the crank's fucked?
If it's being styored somewhere reasonably dry, I wouldn't worry too much about the oil but it'll do no harm to bung some in there. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
stinkwheel |
Back to top |
Bhud |
Bhud World Chat Champion
Back to top |
jeffyjeff |
jeffyjeff World Chat Champion
Back to top |
A100man |
A100man World Chat Champion
Posted: 22:35 - 04 Aug 2020 Post subject: |
It was cheap I reckon as they are a deeply undesirable bike, but these days practically every dog has its day and there seems to be a following to convert GN250s into 'street scramblers' . That said I'm not sure the semi-cruiser style model we had with a tear-drop tank and slightly stepped seat is the same at the one used for those (youtube) projects... ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
Back to top |
pepperami |
pepperami Super Spammer
Posted: 00:11 - 05 Aug 2020 Post subject: |
As soon as I read brat/scrambler in your post , I lost all interest. ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
Back to top |
stablepeach |
Back to top |
A100man |
Back to top |
pepperami |
Back to top |
KiwiBob |
KiwiBob Borekit Bruiser
Back to top |
jeffyjeff |
Posted: 14:36 - 05 Aug 2020 Post subject: |
The exhaust headers look sound. Why don't you consider wrapping them? https://br.pinterest.com/pin/739786676270144973/
BTW your scrambler idea is cool to me. Turning some old POS into a roadworthy motorcycle is a worthwhile endeavor. Have you heard of the "Dirtbag Challenge?" It is a bike build competition in San Francisco for homebuilt custom motorcycles. Check this out for some inspiration. https://www.youtube.com/watch?v=m6GB-s1ib5g ____________________ History shows again and again how nature points out the folly of men - BOC |
Back to top |
A100man |
Posted: 13:13 - 06 Aug 2020 Post subject: |
Don't listen to him he's 'murican..
Seriously though I watched that video and to my knowledge that bike scene doesn't exist over here.. What you get is the hipster sanitised version.. No-one ever said 'I blacked out and the hoped I had a good time' at the hipster Shoredicth HQ TheBikeShed.cc
e.g. from their Rule Book...
Behaviour
We expect the same gentlemanly behaviour we get at all our meets and events, so the club is not a place to show of your stunting skills, or how loud your new exhaust pipe is. It’s also not a place for stag parties or binge-drinking nights out with the lads. We have residential neighbours and are in a high pressure area for public nuisance and disorder, so it’s up to us to show that bikers are a cool but considerate community. If you wanna rev hard, showboat your skills or demonstrate how long you you can hold it on the back wheel that’s up to you, but please do it somewhere else. If you think this is naff or lame, please don’t join. If you get us in trouble with neighbours or the law we’ll have to ask you to leave the club. ____________________ Now: A100, GT250A, XJ598, FZ750
Back to top |
jeffyjeff |
Posted: 13:50 - 06 Aug 2020 Post subject: |
After reading the brat bikes post in "general bike chat", I see your point. Seems that in SF they are resurrecting bikes from the scrap heap and returning them to the road (though I won't go so far as to say roadworthy). But in the UK, people are taking roadworthy machines and relegating them to the scrap heap, or very near it. Sad. No wonder the term "brat bike" makes so many of you fighting mad.
BTW, don't piss all over the 'murican just because of where I'm from. I'm well aware that we have become the laughing stock of the world. no need to rub it in. Hopefully better days ahead.
At least we can all agree about Steve McQueen, right? ____________________ History shows again and again how nature points out the folly of men - BOC
Back to top |
A100man |
Posted: 14:57 - 06 Aug 2020 Post subject: |
jeffyjeff wrote: |
BTW, don't piss all over the 'murican just because of where I'm from. |
Hell no, JJ - your posts have been proper. Sure you're not related to Steve somewhere down the line? ____________________ Now: A100, GT250A, XJ598, FZ750
Back to top |
jeffyjeff |
Back to top |
stablepeach |
Back to top |
jeffyjeff |
Back to top |
pepperami |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
KiwiBob |
Posted: 16:06 - 07 Aug 2020 Post subject: |
Robby wrote: | The swingarm rust is concerning.
They tend to rust from the inside out - so all the bit around the rust holes is likely to be extremely thin. To fix it properly, you need to cut out all of the rusty and very thin metal and replace with new metal.
Luckily, it's a simple swingarm so not difficult to weld in fresh metal. Get some plate for the flat bit, and appropriately sized round tube for the round bits. Cut out repair pieces with a dremel. If you can the repair section exactly the same size/shape as the bit you cut out, you should be fine brazing it at home. Easier to pick up than welding, and far cheaper tools - just a mapp gas torch and some flux-coated brazing rods.
The tricky bit of the whole process is removing the old metal and cutting repair patches of the right size. |
No to brazing!
"Gas brazing, soldering, adhesive bonding, fibre reinforcement and body filler are bonding processes and are not regarded as strong enough for repairs to load bearing members, although they are normally adequate for other repair work.
Brazing, bonding and riveting are only acceptable when used by the motorcycle manufacturer. The standard of any such repair must be comparable to the original strength of the component".
https://www.gov.uk/guidance/mot-inspection-manual-for-motorcycles/appendix-a-structural-integrity-and-corrosion |
Back to top |
stablepeach |
Back to top |
A100man |
Posted: 13:11 - 24 Aug 2020 Post subject: |
stablepeach wrote: |
I've heard that GS and GN bikes are very similar and that the parts are interchangeable, a quick look and the parts do look pretty close.
You can often cross reference part numbers on CMSNL web site. ____________________ Now: A100, GT250A, XJ598, FZ750
Back to top |
stablepeach |
Back to top |
The last post was made 3 years, 234 days ago. Instead of replying here, would creating a new thread be more useful? |
