Help! Unloading Motolug Trailer?
jimster
PostPosted: 04:32 - 20 Aug 2020    Post subject: Help! Unloading Motolug Trailer? Reply with quote
Hi all,
I have a motolug folding trailer (the heavy duty 500kg one) for my fairly heavy (240kg plus 30kg of fuel plus large side panniers) bike. I tried unloading it for the first time at the weekend and it was impossible for me to get it off the trailer by myself - I just couldn't do it, due to the mounting bracket that grabs the front wheel and then pivots forward, holding the bike in place. Although this makes LOADING the bike really easy for 1 person, moving it backwards off the trailer requires lifting the bike up so that the front wheel bracket pivots backwards. Extremely hard when the bike weighs about 1/3rd of a ton and you're standing at a fairly awkward angle.
Any suggestions for how to safely unload this trailer by myself? Do I bounce the bike on the suspension somehow to get it to move up and backwards? Is there a way of removing the bracket to avoid lifting the front wheel over it? Should I just accept that when in billy-no-mates mode I can't unload the bike? Am I going to get pinned beetle-like under the bike?
I've watched all the videos I can find - they show the bike being loaded, but not the unloading. The instructions say "you can do it with 1 person, but we don't recommend it". Hmm.
Current: Yamaha Diversion XJ900
Previous: Yamaha Diversion 600cc, Piaggio Zip 50cc, Honda CG125-W, Siamoto Caddy 50cc moped
jeffyjeff
PostPosted: 05:41 - 20 Aug 2020    Post subject: Reply with quote
Took a quick look at one of the YouTube videos on the motolug trailer.
It appears to have a hitch pin with a hairclip cotter that holds the wheel bracket in place. Seems it would be possible to remove the cotter and slide out the pin to enable bracket removal. If it was that easy, you probably would have tried that before posting, though.
I do not recommend bouncing the bike to try to clear the bracket. Too easy to lose control, and a heavy motorcycle in motion could easily overpower you (and, as you mused, pin you under the bike like a beetle).
c_dug
PostPosted: 09:29 - 20 Aug 2020    Post subject: Reply with quote
I helped load a GS onto one of these the other week, I'm fairly sure it's exactly as jeffyjeff describes, you can knock the pin out of the back clamp and should be able to roll off of the trailer. It's designed that way so as you can accommodate different wheel diameters.
I'd still want two people personally, but I'm sure it can be done by one if you're in a real stick.
Edit: just to clarify, I doubt you're meant to knock that pin out with the weight of a bike holding the rear clamp in place.
Riejufixing
PostPosted: 10:14 - 20 Aug 2020    Post subject: Re: Help! Unloading Motolug Trailer? Reply with quote
Perhaps you can use ratchet straps to aid stability and restrain the machine from rolling off, while you attend to getting the front wheel over the "bump"? Then you can let it off in stages, and when over the bump, just hold it on the brakes then unstrap it and roll off. It seems a fraught process even loading, wthether you've got a helper or not. One slip and you're in trouble.
steve the grease
PostPosted: 11:01 - 20 Aug 2020    Post subject: Reply with quote
Yeah. I've ended up on the deck with the bike half on top of me and I don't recommend it. Motorcycles are in an unstable state when upright and unless some force acts upon it, the machine will try and achieve a stable equilibrium ( ie fall over) Thanks Mr Newton. They are in a stable equilibrium when lying on their side. Pulling the bike over the hump is only the first problem.- now its moving it will tend to carry on moving , often defying your attempts to control where that might be! A mate is very helpful at this point, your Misses pointing out that it's all going wrong and you need help less so.
Difficult one this . Ratchet straps down to the trailer base or ground like tent guylines don't really help, as the thing goes over they lose their tension ( how do I know this?) really you need to brace it into something above you , a couple of ratchet straps onto the carport or garage roof might help control what happens. I've also considered a very cheap electric winch off ebay to help load and gently lower the bike off the trailer, at least it would be under control in one plane. That just leaves falling over sideways to contend with.
My experience is a bit like this: Loosen ratchet straps> bike leans alarmingly> pull bike over hump> bike now moving continues down ramp> I can't keep up and bike goes over. Unloading on a slope is not recommended ( how do I know this). To those who say - 'just pull on the brake' my response ' it can all happen rather quickly'.
I now make sure that when I pull the bike over the hump that the stand is up, that I'm holding the brake and I'm in a sure footed stance anticipating that it will keep rolling and that I need to step backwards at the same speed as the bike ( a step or block at half height between trailer and ground helps here to step back onto) until it's on the deck.
Best of luck.
PostPosted: 13:32 - 20 Aug 2020    Post subject: Reply with quote
When manouvering a bike on ramps, i always leave them in gear and pull the clutch to roll them, this acts as a brake so if you let og of the lever, it stops.
sickpup
Old Timer
PostPosted: 06:24 - 22 Aug 2020    Post subject: Re: Help! Unloading Motolug Trailer? Reply with quote
Trailers that use this arrangement used to have a foot lever on the pivot to overcome this problem, seems strange that they no longer do.
MCN
PostPosted: 20:35 - 25 Aug 2020    Post subject: Reply with quote
I load and unload my K1300 on/off a motolug.
Its a practice thing.
Best have another body to help for the first time.
It also depends on your height and weight and physical ability.
The bike should roll out of the front socket thing just by letting it roll back with a slight bit of assistance.
Motolug weak points.
The spring loaded locator pins that help raise and lower the ramp rust and can shear.
The powder coating flakes off.
The tyres wear out real fast or burst. (Cheap to replace).
Bin the lights that come with it and buy LEDs.
Jon-W
PostPosted: 22:02 - 31 Aug 2020    Post subject: Re: Help! Unloading Motolug Trailer? Reply with quote
jimster wrote:
Hi all,
I find leaving the rear wheel chock in place is a must if unloading from my motolug myself. Having said that I'm only unloading a 600! I'd say it will be a two person job, and you'll have to remove the rear wheel chock.
The last post was made 5 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.02 - MySQL Queries: 16 - Page Size: 69.06 Kb
