Author |
KyleL1403 |
KyleL1403 Derestricted Danger
Back to top |
Nobby the Bastard |
Back to top |
KyleL1403 |
Back to top |
Nobby the Bastard |
Back to top |
KyleL1403 |
Back to top |
Nobby the Bastard |
Back to top |
KyleL1403 |
Back to top |
bugeye_bob |
Back to top |
KyleL1403 |
Back to top |
Pete. |
Posted: 19:57 - 14 Sep 2020 Post subject: |
As Nobby said the ignition is killed by shorting the black/white wire to earth (or the frame). If you un-plugged the ignition switch completely the engine would start and run and you would have no ancilliaries, just like you say.
Since you say that you have power at the bulb holder but no light from a working bulb that suggests that the battery negative or loom earth is not connected. Look around the frame for a ring connector with the wire broken off, or just not connected. ____________________ a.k.a 'Geri'
Back to top |
Nobby the Bastard |
Back to top |
Pete. |
Posted: 20:35 - 14 Sep 2020 Post subject: |
Un-plug the black/white wire from the switch harness and start the engine. Touch that wire on the engine, it should stop. If it does, touch it on the frame. If it stops the engine again your switch is faulty, if not you have a loom earth fault. ____________________ a.k.a 'Geri'
Back to top |
KyleL1403 |
Back to top |
Nobby the Bastard |
Back to top |
Pete. |
Posted: 20:52 - 14 Sep 2020 Post subject: |
OK I steered you wrong a little. The ingition wire is a black wire, not black and white. Black and white is the loom earth.
If you look at the attached snip you'll se that the black wire comes from the magneto directly to the coil. You'll also see that it has a double-connector which branches off the black wire to the switch. Earthing this wire is what makes the engine stop. ____________________ a.k.a 'Geri'
Back to top |
KyleL1403 |
Back to top |
KyleL1403 |
Back to top |
KyleL1403 |
Back to top |
Nobby the Bastard |
Back to top |
KyleL1403 |
Back to top |
The last post was made 3 years, 230 days ago. Instead of replying here, would creating a new thread be more useful? |
