Author |
Wr125Help |
Wr125Help Borekit Bruiser
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
Wr125Help |
Back to top |
Wr125Help |
Back to top |
Riejufixing |
Riejufixing World Chat Champion
Back to top |
Wr125Help |
Back to top |
P. |
P. Red Rocket
Back to top |
Riejufixing |
Back to top |
Riejufixing |
Back to top |
Wr125Help |
Back to top |
Riejufixing |
Posted: 13:40 - 20 Sep 2020 Post subject: |
Wr125Help wrote: | Just bought the one you posted, why is my battery not the same as the one on their website? The bike is 10 years old so is the battery I have the original battery? |
It's very hard to say.
It could be the original battery, but I very much doubt it, 'cos OE seems to be Yuasa (althoiugh that may not be), and 10 years is a long time for this size battery.
It could be a knock-off of the BS one.
It could be that BS changed the look and spec. of that battery.
Whatever, the Motobatt one should be much better.
Look after it. Don't let it go flat, being flat kills batteries. If it goes flat, charge it up PDQ, and investigate the charging system because it's not working properly, OR you left the lights on for a long while without the engine running, or similar. |
Back to top |
Nobby the Bastard |
Back to top |
Wr125Help |
Posted: 13:57 - 20 Sep 2020 Post subject: |
Riejufixing wrote: | Wr125Help wrote: | Just bought the one you posted, why is my battery not the same as the one on their website? The bike is 10 years old so is the battery I have the original battery? |
Well, I'm hoping it's the battery.. but what happens if I fit this new battery and it does absolutely nothing? |
Back to top |
Wr125Help |
Back to top |
Wr125Help |
Back to top |
Riejufixing |
Back to top |
Wr125Help |
Back to top |
1198 |
1198 World Chat Champion
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
Wr125Help |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
Wr125Help |
Posted: 08:32 - 27 Sep 2020 Post subject: |
Robby wrote: | I assume you had drained the old coolant out first? And you're pouring it into the rad filler slowly.
I can't remember if this is the bike that had silicone sealant everywhere - lots of moderately fucked 125s on this forum.
Anyway, best thing to do is some investigation. Knocking from the water pump is unusual, but I reckon you're somehow dropped a pebble or a nut in there. Get the pump off and have a look for something being caught in it.
Filling - does the thermostat have a small hole drilled in the metal plate? It should, this allows a small amount of coolant through so you can fill the system without having the thermostat open.
Total system capacity is probably only a litre. Make sure everything is clean and properly assembled, slowly fill the rad, then start the engine with the rad cap off and let it warm up. This takes bloody ages.
Eventually the thermostat will open and the water level will drop. Turn it off, top up the rad, put the rad cap back on. Then top up the expansion bottle to the correct level and you're done. Check the level in the bottle after the first couple of rides. |
Drained the old coolant using the drainage plug, but there was literally only drips in the whole system.. despite the fact of me filling it up a few days prior, I’ve taken out the thermostat but haven’t looked at the water pump yet, when I fitted the start motor and it was running again, I could just hear a knocking/vibrating, so put a screwdriver to a few places and listened and it’s definitely coming from inside the water pump |
Back to top |
Wr125Help |
Posted: 09:52 - 27 Sep 2020 Post subject: |
This is just getting worse and worse, now it looks like there’s oil in the radiator coolant, dipped my finger in and it comes out black, smells just like oil, could this be due to a broken water pump? Or is it possibly head gasket? |
Back to top |
Robby |
Robby Dirty Old Man
Posted: 13:53 - 27 Sep 2020 Post subject: |
I had a similar-ish problem on an SV650 years ago. The water pump was built into the crankcase cover, and relied on the crankcase cover gasket to keep the oil and water from mixing. This gasket had failed, so I had coolant in my oil. You may have the same problem, or vice versa.
First off, don't ride it until it is fixed. Second, order a new, genuine crankcase cover gasket for whatever side has the water pump. Pattern gaskets are rarely very accurate.
Check the oil level, to see if it has gone up. If so, chances are you have water in the oil, and it needs draining. You'll have to drop the oil anyway to change the gasket. Also look under the oil filler plug for mayonnaise - although you only get this if the engine has been running long enough to churn the oil and water into an emulsion.
Bear in mind this is speculation because I don't have the bike in front of me, but I would be doing the following:
1. Drop the oil. Look for water in the oil - usually the water will drain out first, looking watery, followed by the oil, looking a bit lumpy.
2. Remove the crankcase cover that has the water pump on it. Carefully examine the gasket where it seals around the water pump to see if it is broken.
3. Remove the old gasket, then scrape off all traces of gasket and goop. It will take ages and be a messy job. Try to avoid getting any of the crap inside the engine.
4. Check over the water pump as much as you can, in case something is broken in there or the impeller blade are worn.
5. Reassemble the crankcase cover with a new gasket.
6. Remove the radiator from the bike. Flush it through with a hose pipe. If some oily crap comes out, it needs some detergent and a soak. My preference is to plug off the bottom somehow, fill it with a mix of warm water and Daz, and let it soak. Flush with a hose, repeat soaking with detergent until it seems clean.
Finally, when all of the bits appear to be clean and properly assembled, fill it with plain tap water and go through the normal filling process. Let it run until warm, then drain this stuff off. It should remove enough of the crap from the system. Refill with proper coolant and you're done.
In short, getting oil in the cooling system is a pain in the arse. |
Back to top |
Wr125Help |
Posted: 18:19 - 27 Sep 2020 Post subject: |
Robby wrote: | I had a similar-ish problem on an SV650 years ago. The water pump was built into the crankcase cover, and relied on the crankcase cover gasket to keep the oil and water from mixing. This gasket had failed, so I had coolant in my oil. You may have the same problem, or vice versa.
So would you say it’s likely that the head gasket is gone? Or would you say it’s more to do with the water pump being broken (which it is) and has allowed oil into the coolant that way |
Back to top |
The last post was made 3 years, 210 days ago. Instead of replying here, would creating a new thread be more useful? |
