Author |
Easy-X |
 Easy-X Super Spammer
Back to top |
hellkat |
 hellkat Super Spammer
 Posted: 21:11 - 09 Nov 2020 Post subject: |
I flew home on it.
Lockdown means Less Traffic.
 ____________________ Not nearly as interesting in real life. |
Back to top |
hellkat |
Back to top |
recman |
 recman World Chat Champion
Back to top |
hellkat |
Back to top |
hellkat |
 Posted: 21:37 - 09 Nov 2020 Post subject: |
oh look, it worked that time
He likes a bit of black, flames and skulls, does that one. ____________________ Not nearly as interesting in real life.
Back to top |
hellkat |
 Posted: 19:29 - 14 Nov 2020 Post subject: |
Bit windy out there today, chaps.
Rode down to Maidstone, then to Hastings = by car - then home via Rochester by mistake, oh well I'm going the scenic route again.
More raindrops dodged.
Back to top |
blurredman |
 blurredman World Chat Champion
 Posted: 21:41 - 14 Nov 2020 Post subject: |
I have been having a mis-fire which occured at traffic lights or at idle rpm speed. It never occured when at anything above 1,500 rpm so running to work and back I just keep the throttle on a little bit. Otherwise there was no issues.
I was looking for a while for possible causes, first being the fact that my battery was not being charged- but I threw on a spare voltage regulator and assumed the mis-fire was due to the battery being low (DC powered system). But it was still there...
It seemed odd but I could never re-create... it only occured when out and about, but I could have the bike idling in the garage with full electrical load without any issues.
I went through some of the ignition system last week, putting on new spade connectors where there were stressed wires, and layed two new wires to the generator. One was the signal wire to the stator from the regulator, and the other was the negative to the coil from the condensor - This wire was actually freyed a bit like it had been crushed and copper was showing. I'm pretty sure at the vibey idle that potentially the wire from condensor to coil may have been earthing by touching the engine casing.
Since then.. absolutely no problems which i'm very happy about.
I will be re-wiring the engine loom in the near future however, esspecially the three wires leading from the stator to the rectifier, as they took A LOT of heat and solder for the solder to eventually soak in to one of those wires for a new spade connector to be soldererd on. They were pretty poor. But I suppose I should expect that from 33 year old wiring. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 50k. |
Back to top |
ThatDippyTwat |
 ThatDippyTwat World Chat Champion
Back to top |
MarJay |
 MarJay But it's British!
 Posted: 08:45 - 16 Nov 2020 Post subject: |
Yesterday I had a productive day doing a job on the CBR track bike that I've been dreading.
I did a trackday back in August and then afterwards took the bike and trailer up to my Sister in law's house to stay with her and her hubby for a few days. During this time, the rain chucked down in a way that can only happen in the Summer in the UK.
Sadly the cheapo cap head bolts holding on my beautiful carbon fibre mudguard rusted during this rain stint, and I decided to swap them out for stainless a few weeks ago. I got most of them out...?
Two on the left hand side were so f*cked I had to dremel off the heads and then try to use a chuck style stud extractor on my air impact wrench to remove the remains. This worked on one, on the other my impact wrench just twisted the remainder of the bolt apart and I ended up with a stub stuck in the fork bottom.
Fast forward again to this weekend just gone. I had to drill out said bolt, and was not looking forward to it. Instead of doing it in situ and potentially causing all sorts of bodgery, I decided to remove the fork leg and use the pillar drill to drill out the bolt.
https://cdn.bcf.44bytes.net/files/img_5084.jpg
I was very concerned about the accuracy of my drilling, as a couple of degrees off here or there could mean I end up damaging the fork leg, or drilling the hole out of line causing me endless problems. I need not have worried. The bolt is an M6 and I used a 4.5mm drill bit to attack it.
https://cdn.bcf.44bytes.net/files/img_5085.jpg
Here's the remains of the bolt - I'm pretty happy with that!
Just to be sure I ended up drilling it out and helicoiling it anyway but I did not want any pilot hole I created to be out of line, as the helicoil would be hard to get in line again.
Here's a shot of the front end going back together:
https://cdn.bcf.44bytes.net/files/img_5086.jpg
And here she is back in her resting spot after I gave her a bit of a clean for the winter. She was covered in flies and there was furry mould growing on some of the more fly encrusted areas. I think I need weather strips and a dehumidifier for my garage...
https://cdn.bcf.44bytes.net/files/img_5087.jpg ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
Back to top |
hellkat |
 Posted: 12:23 - 19 Nov 2020 Post subject: |
I just rode the Snarley back up from Maidstone. It was dry there when I left, but by the time I got to the M2 junction, I was wet through to the socks.
Intrepid ride back into town, spray from tyres of big lorries, etc., I really could have done with some kind of visor-related hardware to clear the rain off my glasses cos I are got no visor... but could I find one, I could not.
I've not had an adventure ride like that for a while.
Had to peel my jeans off my legs when I got back indoors.
It's definitely energising.
Makes you remember how it feels to be alive.
Back to top |
Easy-X |
Back to top |
hellkat |
 Posted: 20:21 - 19 Nov 2020 Post subject: |
You utter sicko
Flitted across to Ladbroke Grove after that.
Earned 50 quid for 20 minutes, then popped over to my ex for a cup-o coffee and a sarnie.
Then buzzed home.
Awesome ride, stayed dry.
Rush hour wasn't nearly as cluttered as it normally is.
Life is GOOD right now. ____________________ Not nearly as interesting in real life. |
Back to top |
Robby |
 Robby Dirty Old Man
Back to top |
hellkat |
 Posted: 21:35 - 19 Nov 2020 Post subject: |
I did.
But it wasn't that game  ____________________ Not nearly as interesting in real life. |
Back to top |
ThatDippyTwat |
Back to top |
Bhud |
 Bhud World Chat Champion
 Posted: 19:09 - 24 Nov 2020 Post subject: |
Fitted an LED headlight bulb. Advertised as "hi-lo beam" but only works on full beam. Haven't ridden it around at night yet to test it out, but I will. Looks like it will be an improvement.
Bar-end mirrors removed. I like them but they're twisting about too much now, and I can't get new rubbers. Fitted a generic right-hand side mirror.
Project bike still on hold pending arrival of rare magic part from the East. |
Back to top |
Easy-X |
 Posted: 14:16 - 25 Nov 2020 Post subject: |
Bhud wrote: | Fitted an LED headlight bulb. Advertised as "hi-lo beam" but only works on full beam.  Haven't ridden it around at night yet to test it out, but I will. Looks like it will be an improvement.
From what I recall changing the Superlight to a "daymaker" (knockoff, obs) there are a lot of these billed as "headlights" but in actual fact are spotlights (in the sense of auxiliary uncertified lights.) ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
ThatDippyTwat |
Back to top |
hellkat |
 Posted: 16:01 - 27 Nov 2020 Post subject: |
Rode down to check that Maggie and Ralphie are okay  ____________________ Not nearly as interesting in real life. |
Back to top |
Weisse Schlange |
 Weisse Schlange Spanner Monkey
 Posted: 16:35 - 27 Nov 2020 Post subject: |
Pulled the back end off the Zed (well 300 miles on it now so it needs modifying)
Waiting on my J-Tech tail tidy to get rid of the wheelie bin that Kwack fitted as standard.
The walked dugs, in a muddy field, in preparation for lighting the fire, cracking a beer, and burning myself silly with an Indian curry.
Edit to add, it arrived. Crappy pic but hey, curry and beer etc etc.
[url]https://i.ibb.co/JK6V18F/DSC-0556.jpg[/url] ____________________ Hing Oan |
Back to top |
Tdibs |
 Tdibs Traffic Copper
 Posted: 15:04 - 28 Nov 2020 Post subject: |
Doing valves on the DR,
Was convinced I was being retarded and kept getting Exhaust TDC as I could feel no lash in the rockers at any point. Turns out they just had no clearance, I could just get my smallest feeler in there way below the 0.08mm service limit. Guessing its been this way for quite a while too, little worried of a impending valve drop at some point after finding this but will have to see I guess. Weighing up inspecting the valves and seats.
https://puu.sh/GS7rO.jpg
https://puu.sh/GS7rB.jpg ____________________ Previous : 09 Vanvan 125| 02' Sv650s || Current: 1999 Xj600n | 1992 DR650 RSE | 2005 Fazer 1000 |
Back to top |
wr6133 |
 wr6133 World Chat Champion
Back to top |
hellkat |
 Posted: 13:50 - 29 Nov 2020 Post subject: |
Rode it round a bit  ____________________ Not nearly as interesting in real life. |
Back to top |
bikefun98 |
 bikefun98 L Plate Warrior
Back to top |
The last post was made 4 years, 220 days ago. Instead of replying here, would creating a new thread be more useful? |
