Men at work
panhead51
PostPosted: 13:50 - 15 Jan 2021    Post subject: Men at work Reply with quote
In 8 years, I have come a long way.
With will, we can do great things.
I had come a few years ago and my reception was not good.
But I didn't have a problem with that, I'm coming back.
panhead51
PostPosted: 13:55 - 15 Jan 2021    Post subject: Reply with quote
Here you see, the low engine that I ended up putting together. it took a long time to assemble the crankcases with the crankshaft and then break in the cam cover for the assembly to turn.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:08 - 15 Jan 2021    Post subject: Reply with quote
Expect a load of butt pain if you ask for money again.
Triumph Sprint ST 1050
panhead51
PostPosted: 15:33 - 15 Jan 2021    Post subject: Reply with quote
I understood well.
No, that's not my goal.
I'm just showing what I've done.
panhead51
PostPosted: 15:37 - 15 Jan 2021    Post subject: Reply with quote
to align the crankshaft and then tighten it.
It had to be removed from the machine several times.
Easy-X
PostPosted: 17:33 - 15 Jan 2021    Post subject: Reply with quote
Better off in the Show & Tell section really.
xX-Alex-Xx
PostPosted: 21:23 - 15 Jan 2021    Post subject: Reply with quote
On the John Deere forums too. Laughing
DILLIGAF
defblade
PostPosted: 09:49 - 16 Jan 2021    Post subject: Reply with quote
Argh. I mean, ffs, if you're OCD enough to make that board in the first place...
Tankie
PostPosted: 10:00 - 16 Jan 2021    Post subject: Reply with quote
Panhead i think they are just jealous Laughing There are not many people who can do such tasks, it is hard to try to educate stupid.
Riejufixing
PostPosted: 10:43 - 16 Jan 2021    Post subject: Reply with quote
That's a massive yet spindly crankshaft. Is it something IMZ-Ural?
panhead51
PostPosted: 23:02 - 21 Jan 2021    Post subject: Reply with quote
The important thing here is to share, and to finish my project.
It's a lot of research because I don't have a Panhead model in front of me and we have to imagine solutions.
I build this model because we find all the parts in the catalog.
I do not belong to any motorcycle club, in fact, I like mechanics.
I like all types of motorcycles.
Nobody knows me, it's normal that people are suspicious.
panhead51
PostPosted: 23:06 - 21 Jan 2021    Post subject: Reply with quote
Sometimes people don't put tools back in the right place.
Since I left my job, I no longer have access to the workshop.
Easy-X
PostPosted: 23:28 - 21 Jan 2021    Post subject: Reply with quote
I have a feeling there's a larger story I've no business knowing anything about.
panhead51
PostPosted: 09:09 - 22 Jan 2021    Post subject: Reply with quote
I'm just a guy who's taken on a crazy project and is hoping to finish it.
I am living my dream despite all the difficulties I encounter.
panhead51
PostPosted: 09:21 - 22 Jan 2021    Post subject: Reply with quote
Changing the fork bushings was a big time because Herve made me a tool.
I understand why people refuse to change them.
panhead51
PostPosted: 09:32 - 22 Jan 2021    Post subject: Reply with quote
Sometimes you have to be equipped to do simple things, here is an example for risers.
Hervé machine the inner ring with the lathe.
What remains of the ring to the left.
Right, what remains of the bush was full, he also had to remove the bushing.
On the last photo, we see the silent blocks which will be inserted using a hydraulic press.
panhead51
PostPosted: 09:36 - 22 Jan 2021    Post subject: Reply with quote
I show you some pictures of some amateur work, just passionate people, I imagine other person's forum is doing more important things.
My work is unpretentious, for me it's just a dream that I'm trying to achieve.
panhead51
PostPosted: 09:45 - 22 Jan 2021    Post subject: Reply with quote
In fact it's simple, the heavier the crankshaft, the more torque there is at low speed with limited power.
In current engines, we look for a square stroke with the least weight to go up in the towers, to seek more power with a high compression ratio.
Let us not forget that the internal combustion engine has been empirical since its invention.
I am always fascinated by the research of engineers from the beginning.
redeem ouzzer
PostPosted: 15:03 - 22 Jan 2021    Post subject: Reply with quote
Fuck off Wankie. Judging by the dirge you spout in the workshop section it's not like you are exactly a mechanical genius either.
Be a REAL MAN!
Nobby the Bastard
Harley Gaydar
PostPosted: 17:27 - 22 Jan 2021    Post subject: Reply with quote
More a case that rebuilding a crank is a specialist task that cannot be done without the correct tooling.
Unless, of course, you don't care about your bearings failing within 2K miles. To be honest you wouldn't notice the difference with a hardley because of the vibrations.
Tankie
PostPosted: 18:55 - 22 Jan 2021    Post subject: Reply with quote
And who are you judge!
HD cranks can be built on a bench and trued up quite easily if there are no major faults. i have done machines from the 1920's through to the 1980's
Nobby the Bastard
Harley Gaydar
PostPosted: 19:42 - 22 Jan 2021    Post subject: Reply with quote
Not really something that would be considered engineering these days.
Its a bit like the kits to make an electric engine that people give to their kids for crimbo.
panhead51
PostPosted: 16:42 - 04 Feb 2021    Post subject: Reply with quote
I'm now on Twitter: #PanheadfaconPuzzle
Everything is simple but I keep my blog for the technical part.
bikenut
PostPosted: 11:28 - 05 Feb 2021    Post subject: Thread Reply with quote
Ignition the morons if you can dude.
Keep posting as some of us find this of interest.
You seem to have a good workshop, big lathe at any rate.
I too make "special tools" when I have to, a hammer and chisel do have there uses from time to time, but a purpose made tool can make a problem job a joy.
For those not in the know, hd used to list 100thou oversized pistons and rings, a 100thou, made to last then.
nuts about bikes
bikenut
PostPosted: 11:31 - 05 Feb 2021    Post subject: Ignition Reply with quote
Ignition the morons, yep, bring some "spark" into their miserable lives 🤩
Should read ignore, dam phone and predictive dum text.
nuts about bikes
The last post was made 5 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.58 - MySQL Queries: 16 - Page Size: 129.42 Kb
