bike clicking on ignition
White Noise
Mr Dudwee
PostPosted: 23:08 - 03 Apr 2005    Post subject: bike clicking on ignition Reply with quote
Hi all,
Wonder if anyone can help me, i have a small query. when i first put the ignition on i can hear clicking coming from the bike, it sounds like some relays clicking, i just want to know what is actually going on, my guess is that its something to build up voltage for the starter motor or spark plugs.
Anyone got any answers?
WN
R4nger
PostPosted: 23:09 - 03 Apr 2005    Post subject: Reply with quote
Most likely.. Dead battery.
Davo
Davo To The Rescue!
PostPosted: 23:10 - 03 Apr 2005    Post subject: Reply with quote
No the bike starts fine first time (I'm assuming your asking about my bike), assuming it's either the ignition coil, or as you say a relay.
White Noise
Mr Dudwee
Nope, it starts fine off the starter motor, the clicking stops after about 10 secs
Davo both our bikes do it, could be just a Yam thing
simon1221
PostPosted: 23:12 - 03 Apr 2005    Post subject: Reply with quote
Any electrical parts that are supposed to move, like my Pv opens/closes on start up
PostPosted: 23:23 - 03 Apr 2005    Post subject: Reply with quote
Relays that can click when you switch on that I know of:
Ignition relay that sends power to the loom from the fuse box.
Any number of relays in the immobaliser.
Headlamp relay (if on).
Idiot switch starter button lockout (connected to the clutch and kickstand).
There are bound to be more, fuse boxes are full of the little buggers these days.
beast rider
PostPosted: 01:19 - 04 Apr 2005    Post subject: Reply with quote
Just a thought is your bike fuel injected or carbs ? If its injected then it probably just the injectors charging.
White Noise
Mr Dudwee
PostPosted: 01:23 - 04 Apr 2005    Post subject: Reply with quote
Nope its a 96' divvy 600 so its carbs, nothing fancy just a plain workhorse
Edit: strange thing is i have noticed it on my bike and Davo's R6, so must be a fairly common thing
Tarmacsurfer
PostPosted: 02:18 - 04 Apr 2005    Post subject: Reply with quote
Fuel pump? Unsure of the engine/carb layout on the divvies, but I'd guess the R6 has one.
I'm immortal. Well, so far.
Ric
PostPosted: 03:33 - 04 Apr 2005    Post subject: Reply with quote
of Fuses surely Rolling Eyes couldnt help myself
Gracie Jones
PostPosted: 16:48 - 04 Apr 2005    Post subject: Reply with quote
my fazer does it sometimes. Yam thing maybe you're right.
Luke
Phoenix
Twisted Firestarter
PostPosted: 16:52 - 04 Apr 2005    Post subject: Reply with quote
Would imagine it's the fuel pump, assuming the Diversion has one. Though it's not usually a clicking noise, more of a winding noise, I've not heard relays click until you atually push the starter (with a low battery).
base
PostPosted: 16:57 - 04 Apr 2005    Post subject: Reply with quote
i am pretty sure the xj has a fuel pump, i would put my money being this that you can hear.........nothing to worry about if it is
NY_Sniper
PostPosted: 18:11 - 04 Apr 2005    Post subject: Reply with quote
or possibly the starter moter engaging , but the teeth not lining up straight away ??
That Dot On The Horizon .... Its Me
> Kawasaki ZX7R (Betty Jnr) <> Suzuki GS500e in pieces (Bitch) <> Suzuki GS500e (Martha) <>
White Noise
Mr Dudwee
PostPosted: 19:52 - 04 Apr 2005    Post subject: Reply with quote
its when i put the key in an turn it, and do nothing more. I'm not worried just got a curious mind!
WN
Phoenix
Twisted Firestarter
PostPosted: 20:28 - 04 Apr 2005    Post subject: Reply with quote
As soon as u turn the ignition on the pump activates to make sure there's fuel in the system.
ppeaster
PostPosted: 13:25 - 05 Apr 2005    Post subject: Reply with quote
My thundercat does this as well - sounds like it's a Yamaha trait.
Robin
PostPosted: 16:36 - 05 Apr 2005    Post subject: Reply with quote
My Yam XJ650 used to do that, turned out that it was the fuel pump.
BFG
PostPosted: 16:41 - 05 Apr 2005    Post subject: Reply with quote
Petrol pixies.
They psych each other up like american footballers by smacking each other over the head. They wear hard hats, whicvh creates the clicking sound you hear.
The last post was made 21 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.53 - MySQL Queries: 16 - Page Size: 103.85 Kb
