| justpoc |
 justpoc L Plate Warrior
 Posted: 23:24 - 02 Feb 2021 Post subject: Sinnis apache 125cc not starting |
Hi all, decided to turn for help to forum, probably missing something obvious and hopeing i can be pushed towards right direction.
Sooo, tried to help out a fellow rider with jump starting the bike with no luck. Only to notice a day later that my bike is not starting.
Tried jump starting from a car with no luck. Bump start seemed to work only once (did not think of it much and was happy it started once). Decided to change battery as it was already quite old and thought I probably killed it. Bike started seemed to run nicely, after a mile or so and few misfires at the end it just died on the road. Managed to start a few more times, each time just for a few meters of ride until it completely switched off.
As I was about to start looking for issues, decided to fix few small issues and do a part of service as it was about time anyway.
New spark plug, generates healthy spark.
New carburettor (changed it as old one had an issue affecting throttle and was just in a queue for a repair anyway). Checked the fuel and it comes clear, even drained and replaced with a new as bike stood for few weeks without moving. Carburettor should be operating as it is supposed to I guess.
New starter motor (accidentally damaged it when disconnected to clean it. Located in front of engine and was covered in thick dirt.. please do not ask why did I bother at all... )
Checked compression and according to manual all fine.[/list]
That leaves timing, I guess. As it happened after jump starting, my best guess is of course electrical part... The only part I can think off is CDI unit malfunctioning. Now don't want to start changing components when no idea what is wrong nor digging deeper into potential mechanical faults as it just does not make sense.
The question I have is whether it is somehow possible to check if CDI unit is performing as it is supposed to or potentially I should be investigating something else too?
Sorry for the very long text but wanted to paint the situation how I experienced and understand it. Silly thing to play with jump starting when not fully aware of correct procedures... A lesson to learn. |
| Easy-X |
 Easy-X Super Spammer
| justpoc |
| Easy-X |
 Posted: 19:16 - 03 Feb 2021 Post subject: |
| justpoc wrote: | | Easy-X wrote: | You say the battery is old. Why not start there and replace it? |
I did. After I replaced, bike started for a 1 mile journey. This was the 1st thing I replaced and it does not seem to work even when recharged. New battery works fine |
Whoops! Sorry, I read that as charged the battery for some reason Alcohol induced dyslexia
Anyhoo, it might be worth checking the battery voltage with a multimeter: before starting, while idling and if/when it dies. The battery and charging/regulation system is the base for the rest of the electrics. If it's anything like other Chinese 125s then the magneto charges the battery and the battery in turn powers the ignition system.
Also worth having a look at the side stand switch and kill switch just to discount them from the equation. After that: loose connections / bad earths, CDI unit and the ignition coil.
tl;dr get a multimeter + wiring diagram, e.g. something like:
https://dealers.lexmoto.com/downloads/125_motorcycle_ac_wiring_diagram.pdf ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| bikenut |
 bikenut World Chat Champion
 Posted: 21:02 - 03 Feb 2021 Post subject: Sinnis |
As above, also research red neon plug caps that flash as they pass thru HT, the spark.
Cheap effective hassle free but you may have to make an adaptor so it fits hassle free between plug in engine and existing plug cap.
When it dies does it stop flashing ?
If/when it misfires does it stop flashing in time with the misfire.
With a good clean correctly gapped plug and neon fitted and engine idling, does the flashing go brighter with revs ?
It's a bit of cheap test kit, not a real cool flashing but of bling for your bike.
You should be able to see the flashes if you are riding bike, particularly at night.
An other low tech test, with front of bike by a wall, engine idling and headlights on, do the headlight grow brighter if you rev engine to say 4 to 5 k revs ? Yes ? Good. No, bad. !
What year your Sinnis ? Post wiring diagram so we can see...
Is it edit or carb version, and goto sinnismotorcycles.co.uk or what ever it is, for the parts diagrams, exact model,vso we know what's on it...etc. ____________________ nuts about bikes |
| justpoc |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 23:06 - 04 Feb 2021 Post subject: |
that diagram suggests the side stand switch dumps the pulse signals to ground to stop the motor
( as does the stop and ignition switch, test those too)
try disconnecting it as they been known to play up
https://www.bikechatforums.com/download.php?id=104375 ____________________ bikers smell of wee |
| bikenut |
| bikenut |
| wr6133 |
 wr6133 World Chat Champion
| bikenut |
 Posted: 13:49 - 05 Feb 2021 Post subject: Neons |
They are not the be all and end all, and could be a problem in a deeply recessed plug, and on a bike with a fairing, but they work for me.
An adapter would have to be made for a deeply recessed plug, L shaped possibly, and an adapter made so it fits inline and easily using the bikes original plug cap, but that's down to the application ( cx500, kwak gpz750, the one that the engine will run with the cam cover off ).
They work for me and have done for years and years.
Wasted spark ?
When the misfire happens and no flash, then no HT.
Yes, is it fuel, is it a coil breaking down under load, going up hill ?
A visual indication would help, unless you have lots of hair.
You could always stick your finger in the plug cap, bit difficult when riding I think.
Do you check your mirror and is your fairing welded on ?
You will not know of there usefullness untill you try them, they dont Cost a fortune.
Dim flash at cranking, brighter flash with revs...dim flash when at idle, intermittent flash when intermitant misfire starts at 4 to 5 k revs, is it fuel ?
Of course there may be a fuel problem as well....
But you need one really long lead for a scope, unless you have one of those battery powered ones, or one in a laptop....there's always your finger up the plug cap 🤩🤩 ____________________ nuts about bikes |
| bikenut |
The last post was made 5 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
