Author |
A100man |
A100man World Chat Champion
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
steve the grease |
Back to top |
stinkwheel |
Posted: 13:52 - 31 Mar 2021 Post subject: |
Swap the condensers round and see if the arcing changes to the other set.
The old test used to be to set the points to closed with the ignition off. Turn it on then seperate the points with something non-conductive. If a spark arcs across, the condenser is probably toast. Of course, this doesn't work if it's a self-exciting ignition.
Make sure the voltages match if you are using componants off different motors (not sure if the GT is 6V). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
Easy-X |
Easy-X Super Spammer
Back to top |
stinkwheel |
Back to top |
Easy-X |
Back to top |
A100man |
Posted: 15:48 - 31 Mar 2021 Post subject: |
stinkwheel wrote: |
I did this - one set arced the other did not - spark at plug as intermittent on arcing side. GT is a manly 12V system. Going to try the beetle condensor called my local motor factors and they stock them. ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
Back to top |
jeffyjeff |
jeffyjeff World Chat Champion
Back to top |
WD Forte |
WD Forte World Chat Champion
Back to top |
A100man |
Posted: 10:16 - 05 Apr 2021 Post subject: |
Hmm,Beetle condensor didn't seem to work too well.. points on that pot still arcing. Went for a ride anyway, at the end of about 15 miles misfire, nursed it home.
Maybe points/condensor or non charging battery. More investigation needed, as usual.. ____________________ Now: A100, GT250A, XJ598, FZ750
Back to top |
pepperami |
pepperami Super Spammer
Posted: 10:31 - 05 Apr 2021 Post subject: |
A100man wrote: | Hmm,Beetle condensor didn't seem to work too well.. points on that pot still arcing. Went for a ride anyway, at the end of about 15 miles misfire, nursed it home.
Maybe points/condensor or non charging battery. More investigation needed, as usual.. |
On one of my GT250’s many years ago I had a similar problem.
One brand new battery, new points, new plugs, new condensers, it was still happening.
Another set of coils that I knew were good and it was still happening.
It turned out to be the charging system.
Just my .
Thank your lucky stars you’re not working on a Yamaha XS250, my experience of them was that they are/were a lot worse .
They had a mind of thier own/determination for running on one cylinder.
F*gking sh*theaps. ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
Back to top |
WD Forte |
Back to top |
bikenut |
bikenut World Chat Champion
Back to top |
A100man |
Posted: 16:02 - 05 Apr 2021 Post subject: |
Fired it up again this morning and it's running nicely. The retrofit reg/rec I fitted lat years also seems to be working as I'm going from 12.5 up to 13-14 with a few revs (the original GT250 only has a rec no reg...)..
Couldn't see much arcing either during running but I can when I test it 'statically' opening the points with my thumb and check for spark with a spare plug.
To wire up the beetle condenser I had to common the single green wire to both points and source. I'll order a proper replacement anyway. Will re-read WDs post to see if I can understand the check procedure too
TTFN ____________________ Now: A100, GT250A, XJ598, FZ750
Back to top |
bikenut |
Back to top |
A100man |
Posted: 23:47 - 05 Apr 2021 Post subject: Re: T |
bikenut wrote: | You do realise there should be 2 condensers/ capacitors, one for each set of points, 2 seperate indipendent systems but with a common 12v to the ignition coils ? |
Yes..thanks. only replaced one with the bodge. ____________________ Now: A100, GT250A, XJ598, FZ750
Back to top |
Islander |
Islander World Chat Champion
Back to top |
The last post was made 3 years, 14 days ago. Instead of replying here, would creating a new thread be more useful? |
