Author |
BanditsHigh |
BanditsHigh Worse than a woman
Back to top |
stinkwheel |
Posted: 18:17 - 10 Apr 2021 Post subject: |
If it's old oil I'd drain it down. I wouldn't use specific flushing oil, I'd just use cheap normal oil, maybe get a couple of filters at the same time so you can do a short-interval change.
Once it's oiled up, I'd give it a good turn over without fuel or spark to get all the oilways primed. You can turn them over by shorting across the starter solenoid.
I'd drain down any fuel that's stil int here, have a look in the tank with a torch and decide if you want to put fresh fuel in there ro give it a good clean out.
Evict any mice from the airbox. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
jeffyjeff |
jeffyjeff World Chat Champion
Back to top |
steve the grease |
steve the grease Crazy Courier
Posted: 18:33 - 10 Apr 2021 Post subject: |
I think I would remove the plugs and spin the engine over for a minute on the starter to hopefully ensure that there is plenty of oil where it's needed.
Drain the tank and carbs- refill with fresh petrol and, make sure the petrol is getting through by undoing one of the carb drains and see it running out.
Then put it all back together and try it , give it a few whiffs of easy start to give it a bit of encouragement. It will probably cough and splutter and eventually come in on a few cylinders before settling down- hopefully.
Once the oil has circulated a bit it will pick up all the dirt, which may have settled out whilst stood. Once its up and running - that is the best time to drain and refill, but before using the bike on the road, in my opinion.
. ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of..... |
Back to top |
virus |
virus World Chat Champion
Back to top |
jeffyjeff |
Posted: 21:37 - 10 Apr 2021 Post subject: |
No shortage of opinions on this one. Pick one and go for it. What could go wrong? ____________________ History shows again and again how nature points out the folly of men - BOC |
Back to top |
BanditsHigh |
Back to top |
Weisse Schlange |
Weisse Schlange Spanner Monkey
Back to top |
Islander |
Islander World Chat Champion
Back to top |
Shaft |
Shaft World Chat Champion
Posted: 00:27 - 11 Apr 2021 Post subject: |
virus wrote: | If it was a known good engine with no faults when it was parked and hasnt been 'open' aka inlet/spark plugs/ exhaust/ rocker cover off then I wouldnt bother with taking anything off.
Id turn the ignition on so the oil pressure light functions then short the starter solenoid to crank it without any voltage going to the sparks. once its proven oil pressure once or twice Id give it fresh oil and filter, fresh fuel and filter then give it a chance at starting. Once it fires up let it idle for 5/10 mins to warm up. |
Sort of this, except I wouldn't bother the time and money to change the oil, or short the solenoid.
Stick it in a high gear and rock it back and forth, just to make sure the rings aren't stuck, then if you can get the ignition working, its not going to start right away, at least not before it puts the pressure light out.
If you can get it to idle, good luck, just keep it running for a couple of minutes, to assess where you are (is it smoking like the Flying Scotsman or knocking worse than a barn door in a gale) then decide what to do next. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
Back to top |
bikenut |
bikenut World Chat Champion
Posted: 09:26 - 11 Apr 2021 Post subject: T |
You are aware that things can stick.
Once established all valves free and it turns over well, with a prepared sump and new oil filter, plugs out and bores lubed, turn very by hand and watch oil flow to filter, good, fit filter and keep turning.
By this stage use a racket on crank bolt and crank.
You will feel when the system starts to pressurise, keep cranking, has the oil light go e out ? Make sure engine ignition is dead via kill switch.
How many turns to put the oil light out, and to initial "oil gush ) from filter feed...
It's old, had problems before it's rest period, and it's your bike.
When it's comes to starting time, I would use some 2t in the fuel if carbed...
You can you can easy access the cams, will the engine turn over ok with them exposed...
Since the clutch will be stuck, maybe prodent to remove clutch cover for a look-see, and use any holes to internals for a low pressure flush out .
I would give it a good flush out.
Whilst it's dripping down, add some coloured fluid to the plug holes pistons mid bore.
Watch for this ...
Take your time, get it clean inside, make sure it turns over easily and puts the oil light out by hand when cold.
Check ignition( which was dead, off, killed, protected during all that rachet cranking ? Yes...
Test tank or main tank....carbs and cables...
Bike safe and on centre stand, add fuel, no overflows ? Good...
Battery good and working, if I t has a kick starter, give it a swing...
When it's started, minimum revs...check charging system, let it run low revs...computer fans for cooling...etc. ____________________ nuts about bikes |
Back to top |
bikenut |
Posted: 10:25 - 11 Apr 2021 Post subject: T |
Your bike has had a long rest in jancurs, so needs to see the light of day, or arrange so fresh is is abundant.
Engine. All free, low pressure flushed out, clutch cover off, clean internals for flush out, the clutch will be stuck so a step down and clean. New steels plates at least ?
So flushed out, clutch sorted, cover on, new gasket.
All happy engine is free, well lubed and whizzes over on starter, ignition good, fuel system serviced, air systems ready to go, no fuel leaks/overflows, she has even compressions, fire extinguisher just over there, all ready, hit the title and it gently burrbles into life, reborn....for now.
Brakes etc...
Deep service...
Mot
Enjoy...what year is she ? ____________________ nuts about bikes |
Back to top |
stinkwheel |
Back to top |
Islander |
Back to top |
BanditsHigh |
Back to top |
Pete. |
Pete. Super Spammer
Back to top |
MCN |
MCN Super Spammer
Posted: 20:01 - 11 Apr 2021 Post subject: Re: Starting an engine after many years |
BanditsHigh wrote: | My 'good' GSX1400 has been off the road for quite a few years, stored in an unheated garage ... done over 103k miles on it and only took it off the road as needing lots of work done after riding through many winters!
I know a full engine strip/rebuild would be best, but could I basically put flushing oil in (pour some over the top end as well), fresh fuel and fire her up?
Basic idea was for flushing oil, turn it over by hand a few times just to make sure nothing is stuck, then run (if it does) for a few minutes before then replacing the oil etc.
Any and all advice appreciated.
All the best ... Barry |
I work in the 'Oil Patch', the general consensus, among the non-technical there to free any stuck device is to, either dowse in in WD-40 or Soak it in Diesel (whatever is closest to hand at the time.)
I hope this helps.
Change:
Oil, and maybe oil the rocker gear if access is not a PIA, Fuel, Filter, Coolant if present (plus flush with tap water prior to refill with new coolant.)
Plugs (after you have birled it over a bit on the starter to see the oil light go out, if fitted.)
when you get it to fire/start try not to let the hoowur rev it's head off right off the bat. There may be broken something and you will lose the opperchancity to save collateral damage if it parts at 11000RPM. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Back to top |
The last post was made 3 years, 15 days ago. Instead of replying here, would creating a new thread be more useful? |
