| Genseric3D |
 Genseric3D L Plate Warrior
 Posted: 12:20 - 02 May 2021 Post subject: Advice wanted, clutch, air filter, adjustment ? |
Greetings to all BCF members .'
| Quote: | 'Ask in the Workshop section'' MarJay advice |
Joined just. I don't know where to start, so I decided on this topic. A few years ago I was forced to give up my beloved hobby which was downhill and generally fast cycling [my knees refused to obey during one of the downhill runs on Cannock Chase] I decided to change the bike for another two wheels , my partner was mad at me for 2 years - Motorbike? Are you f^>"n6 mad !! Whatever now. In the last two days I changed the rear tire, brake pads, breaks fluid , engine oil , spark plug . I renewed the outer shell of the whole engine, the paint that was covered the engine started to peel off and crack after 4 years of riding wired . I used high-heat resistant paint for BBQ
Effect is awesome whole unit in black matt. In the morning I decided to go for a 2-hour ride - check the paint heat resistant for the bbq Now I will ask the main question. While riding , after 20 minutes, the engine began to lose power. Gear change and when I twist the throttle to accelerate quickly (in any gear) I hear the engine sound increasing in pitch by a lot more than I'm used to hearing, but the motorcycle doesn't seem to respond and performance is very poor, full throttle after gear change and just sound like engine stopped on the highest torque. I was forced to back home. Are any of you , experienced riders can help me with your advice? I am afraid that this is a clutch failure, but at the same time I know that the air filter has not been replaced since 2016. Thank you very much for your help Mart  ____________________ When all of this is over , the world won't be the same |
| Bhud |
 Bhud World Chat Champion
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| Genseric3D |
| doggone |
 doggone World Chat Champion
| Islander |
 Islander World Chat Champion
 Posted: 18:22 - 02 May 2021 Post subject: |
Before you delve into the guts of the clutch, worry about oil, etc. Just try adjusting the thing - that may well be all that's needed.  |
| xX-Alex-Xx |
| Pete. |
 Pete. Super Spammer
 Posted: 23:02 - 02 May 2021 Post subject: |
If it's a cable clutch then first thing to do is check the clutch cable. The fact that you have had to re-finish the engine paint suggests that the bike has been ridden in poor weather. If that is the case then the cable might be all gummed up and binding. Disconnect the engine end and push-pull the inner cable. If you can't flap the lever about easily the cable needs clean and lube. ____________________ a.k.a 'Geri'
| Genseric3D |
 Posted: 00:08 - 09 May 2021 Post subject: |
Checked engine oil purchased 2016-21 and is not Motul , used from 2016 ''Castrol 15043E Power1 4T 10w-40 and K&N oil filter KN-140 ''
Bought just in case new air filter by HiFlo Filto , new set of Clutch Friction Plate Kit made in UK by EBC. Just no rain please and I will start from clutch cable. Thanks for reply xx-Alex-Xx , Pete. , Islander , Bhud , doggone ____________________ When all of this is over , the world won't be the same |
| Genseric3D |
| Genseric3D |
The last post was made 5 years, 28 days ago. Instead of replying here, would creating a new thread be more useful? |
