Author |
m4z3r4ti |
m4z3r4ti L Plate Warrior
Posted: 22:02 - 22 Jun 2021 Post subject: Honda CB125F MM 2021: Where's the rev counter?!? |
Proud owner of a 2021 Honda CB125F MM with the LCD dash. Honda proudly talks of it's high performance for the range, power output at blah revs but as far as I can find there is no rev counter! Honda own goal or secret button combination?
Have attached the owner's manual from here:
https://www.honda.co.uk/motorcycles/my-bike/honda-motorcycles-owners-manuals.html
No mention of a rev counter
Anyone any ideas?
Maz. ____________________ Honda CB125F MM 2021 |
Back to top |
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
Posted: 22:42 - 22 Jun 2021 Post subject: |
Keep twisting the throttle until it makes an EEEEEEEEEEEEEEEEEE!!!!!! noise, then change up. Repeat. Eventually it'll be going as fast as it can. No rev counter needed. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Back to top |
Holdawayt |
Holdawayt Trackday Trickster
Back to top |
xX-Alex-Xx |
xX-Alex-Xx World Chat Champion
Back to top |
Robby |
Robby Dirty Old Man
Posted: 13:11 - 24 Jun 2021 Post subject: |
That does seem a bit shitty. On a big bike a rev counter may be less important (although I still prefer to have one). As a learner, and new to the world of bikes, with the associated paranoia of breaking it, it's a very useful thing to have.
OP - it's a new fuel injected bike, so you don't have to worry about setting the idle speed or anything like that, the bike does it itself. Once you have the first 500 miles or so under your belt, you can abuse the bike once the engine is warmed up. Lots of revs are good, and necessary. You will not damage it, the rev limiter will kick in at whatever point Honda deemed safe.
It is better to use low gear, high revs then high gear, low revs. If in doubt, change down and open the throttle. To get any performance out of a 125 you need to work it hard. |
Back to top |
There is a gap of 335 days between these two posts... |
urbanfireblad... |
This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
urbanfireblad... L Plate Warrior
Posted: 19:08 - 25 May 2022 Post subject: |
I have the same bike and no there isn't a rev counter!
You can look on ebay for a simple digital rev counter which works by wrapping the wire around the HT lead to the spark plug, i had one on my Honda Innova 125 and although there was about a 1 second delay it will give you a digital readout of the rpm.
Search "Digital LCD Engine Hour Meter Inductive Tachometer Gauge For Car Boat Motorcycle"
or here is the direct link while the listing is current
https://www.ebay.co.uk/itm/154321796750 |
Back to top |
Bikeroo |
Bikeroo L Plate Warrior
Posted: 17:13 - 30 Oct 2022 Post subject: Re: Honda CB125F MM 2021: Where's the rev counter?!? |
m4z3r4ti wrote: | Hi
Anyone any ideas?
Maz. |
You can have rev counter and read all sensors live with the app torque on your smartphone. You need Bluetooth diagnostic device cost around 30 quid and cable adapter obd to six pins honda euro 5 about 12 quid and your smartphone with handle bar mount. You find the obd plug just above the battery tucked inside small cavity. Pull it up and remove the dust cover then plug your obd scanner and tuck it over the air intake pipe under the seat. Turn your ignition on then open your torque app. Make sure your Bluetooth is on and location for the gps. You can custom all the dials for every sensors as you like on your phone. Speaking of which I did fault scan today and i got crankshaft position sensor fault lol the bike runs fine though no issues. |
Back to top |
Nobby the Bastard |
Back to top |
The last post was made 1 year, 179 days ago. Instead of replying here, would creating a new thread be more useful? |
