Honda NSR 125 left crankcase leak
Simon13245
PostPosted: 18:55 - 25 Jul 2021    Post subject: Honda NSR 125 left crankcase leak Reply with quote
Hello guys.
Another day, another issue with my NSR.
So, today I noticed a leak coming from a left crankcase. I think it's coolant, it has the same color. I am not sure if the coolant should be there? Pardon my lack of knowledge.
Today I also noticed, that I'm missing a bolt? Look at the pictures that I attached. Is it a matter of a missing bolt or is the gasket faulty?
I swear I had a bolt there before...
Here are the pics: https://imgur.com/a/38PsDQI
Honda NSR 125R (1999)
Nobby the Bastard
Harley Gaydar
PostPosted: 19:25 - 25 Jul 2021    Post subject: Reply with quote
That missing bolt looks to be missing a mount for the exhaust.
And thats not coolent, it looks like oil to me.
Oh, the third 'difficult' hole. Yes, thats means your gasket can't work properly because it's missing.
(Mouth and pussy is easy, convincing them to put out up the bum is where it requires persuasion.)
Triumph Sprint ST 1050
Simon13245
PostPosted: 19:35 - 25 Jul 2021    Post subject: Reply with quote
Emm, sorry I have no idea what your last line means Razz
What do you mean difficult?
Yeah, I think that the gasket is not working as intended cause it's missing this "pressure" point.
Are you sure it's the oil? It's dirty in the pic, but I managed to get few drops on the rag, and the color is greenish. Also, the viscosity doesn't seem right for the oil.
Sorry if I'm asking obvious questions.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:41 - 25 Jul 2021    Post subject: Reply with quote
Thats where the stator plate will be. There won't be any coolant in there. What color is your 2t oil?
Nobby the Bastard
Harley Gaydar
PostPosted: 19:43 - 25 Jul 2021    Post subject: Reply with quote
It was more focused on the third bit. If you look at your pictures there are 3 threaded holes visible.
Simon13245
PostPosted: 19:56 - 25 Jul 2021    Post subject: Reply with quote
The 2t oil is red. I don't think there should be any 2t oil. If it's oil then it should be transmission oil?
Yeah you are right, I should have marked the 'hole' I was talking about. Under the crankcase is the starter.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:08 - 25 Jul 2021    Post subject: Reply with quote
If it's coolant it won't be leaking from there. There's a water jacket around the cylinder and a pump on the rhs. No coolant there.
Simon13245
PostPosted: 20:13 - 25 Jul 2021    Post subject: Reply with quote
Then it's definitely not coolant. Everything around (and above) is completely dry.
Simon13245
PostPosted: 14:45 - 26 Jul 2021    Post subject: Reply with quote
So you were right, it was oil. Today I managed to get a new screw, but even after I installed a new screw the oil is still leaking. Not so much but it's "sweating".
I guess it's time for a new gasket Sad
Nobby the Bastard
Harley Gaydar
PostPosted: 15:17 - 26 Jul 2021    Post subject: Reply with quote
Bolt, not screw. Screws have a pointy end...
I'm not convinced that oil should even be in there but I'm not an NSR expert.
Simon13245
PostPosted: 15:24 - 26 Jul 2021    Post subject: Reply with quote
Yeah, there shouldn't be any oil inside. It seems it's leaking from the crankshaft. I'm going to remove the cover and see what's inside.
A100man
PostPosted: 15:48 - 26 Jul 2021    Post subject: Reply with quote
Could be a failed crank-shaft oil seal (steady now Nobby). If so hopefully it could be changed in situ.
Simon13245
PostPosted: 16:13 - 26 Jul 2021    Post subject: Reply with quote
You may be right. I will try to resolve this issue.
Once again thank you all for your time, I highly appreciate your expertise. A noob has learned few new things.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:15 - 26 Jul 2021    Post subject: Reply with quote
This is exactly what I was thinking bnut I don't know enough about those engines.
steve the grease
PostPosted: 18:30 - 26 Jul 2021    Post subject: Reply with quote
Looks to me like there is a screw missing out of the outer casing , to the left of the hex headed screw in pic 3 and the centre of pic 4 . in pic 3 some oil can be seen on the casing hanging down starting to drip, never mind the boss with no bolt , missing casing screws are never a good idea.
The last post was made 4 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 3.82 - MySQL Queries: 16 - Page Size: 91.23 Kb
