Duke 2019 30 amp blowing
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2
uberkron
PostPosted: 05:35 - 31 Aug 2021    Post subject: Reply with quote
I repair motor vehicles for a living.
If you're too stupid/lazy to check oil I just assume you can afford new engines.
I check mine each morning, people think it's over the top but I don't lose engines at random either.
The shit for brains that tow in a shitbox car that's been run out of oil that start crying when they learn they are now fucked, it's hard but I can fap to it.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
Easy-X
PostPosted: 11:22 - 31 Aug 2021    Post subject: Reply with quote
Just for the argument...
If you don't notice some spots of oil on the ground before you ride a bike and you don't notice a load of smoke as you're riding along where could the oil go? Into the cooling system? On that would the expansion bottle (if present) show a noticeable colour change?
Nobby the Bastard
Harley Gaydar
PostPosted: 11:25 - 31 Aug 2021    Post subject: Reply with quote
You wouldn't necessarily get masses of smoke with oil burning.
It wasn't that noticable with either the FZ or the exup valdes and they are notorious for using up oil.
Sprint ST 1050
xX-Alex-Xx
PostPosted: 12:46 - 31 Aug 2021    Post subject: Reply with quote
I remember Honda saying 1 litre per 1000 miles of oil burn was acceptable on CBR1000s at one point. They're not the only manufacturer to say similar either. Some bikes just eat oil.
DILLIGAF
weasley
PostPosted: 13:26 - 31 Aug 2021    Post subject: Reply with quote
Indeed, and these engines don't hold a lot of oil so it doesn't take long at "acceptable oil consumption" rates to burn through it all.
Alternatively, after the service, was there the right amount of oil in it? In order to stay on top of oil top-up, you need to have a starting point that YOU have determined, not assume that someone else put the right amount in it.
Also, do you have a detailed description of the engine damage? I'd be surprised if it has "dropped" all of the valves or that the valves have dropped as well as the piston having seized or rings worn out. Usually there is one catastrophic failure that leads to secondary damage. Dropping a valve could damage the piston but I wouldn't see this wrecking the rings. Seizing the piston could cause multiple valve damage if it seized at/near TDC (not sure if this is a 2- or 4-valve head?).
FKX
PostPosted: 13:54 - 05 Sep 2021    Post subject: Reply with quote
I did once a week with no signs that it was getting low. In addition to the oil level light for the level and pressure never coming on I assumed it was okay.
I have now come accoss other people owning the Duke and RC variant of the 125's and it does appear engines hit this catastrophic failure at 2 years of age. Expected cost of repairs being £2500 parts and labour.
A 2 year old new KTM Duke 125 19 plate written off due to mechanical failure at no fault of my own. In addition it seems KTM fail to keep customers wanting to come back. Of course if they can do something I will report back on it as it's only fair.
With the electronic side happening after a year the total cost of repairs of a £4000 125 come to £2500 engine failure and £900 on electronic issues. If KTM cover this then great but as it stands I can not in good faith recommend anyone buys these bikes.
FKX
PostPosted: 13:57 - 05 Sep 2021    Post subject: Reply with quote
The garage confirm no fault of my own. Valves dropped, piston burnt and damaged and rings gone. No oil leaks at all and as for it being at home prior I can definitely confirm no oil leaks at all. It would definitely show up on the driveway and would leave marks for a good month or two
The last post was made 2 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.29 - MySQL Queries: 17 - Page Size: 54.95 Kb
