Author |
Simon13245 |
Simon13245 Borekit Bruiser
Back to top |
MCN |
MCN Super Spammer
Back to top |
Easy-X |
Easy-X Super Spammer
Back to top |
weasley |
weasley World Chat Champion
Back to top |
Easy-X |
Back to top |
weasley |
Back to top |
Pigeon |
Pigeon World Chat Champion
Posted: 02:13 - 16 Aug 2021 Post subject: |
OIL THREAD!!!!
Balls, missed most of it.
arry wrote: |
There's a guy on here, or there was, that works in the industry and did a good job of explaining the benefits of fully synthetic over semi. |
That would be Weasley; legend, might have a man crush
Simon13245 wrote: |
You don't put car oil into a motorbike
Must. not. get triggered. Resist.
JASO test is (as Arry said) largely based on friction standards, which does not automatically exclude (or include) car oils
https://www.jalos.or.jp/onfile/pdf/4T_EV1105.pdf
Many of the accepted standards for testing are diesel/car engine oils.
https://i.imgur.com/rT46QTA.jpg
eg
https://www.oilspecifications.org/acea.php
"ACEA A1/B1 Category is removed with the ACEA 2016 Oil Sequences. From ACEA 2012: Stable, stay-in-grade oil intended for use at extended drain intervals in gasoline engines and car & light van diesel engines specifically designed to be capable of using low friction low viscosity oils with a high temperature / high shear rate viscosity of 2.6 mPa*s for xW/20 and 2.9 to 3.5 mPa.s for all other viscosity grades. These oils are unsuitable for use in some engines. Consult owner manual or handbook if in doubt.
ACEA A3/B3 Stable, stay-in-grade Engine Oil intended for use in Passenger Car & Light Duty Van Gasoline & Diesel Engines and/or for extended drain intervals where specified by the engine manufacturer, and/or for year-round use of Low Viscosity Oils, and/or for severe operating conditions as defined by the Engine Manufacturer.
ACEA A3/B4 Stable, stay-in-grade Engine Oil intended for use in Passenger Car & Light Duty Van Gasoline & DI Diesel Engines, but also suitable for applications described under A3/B3.
ACEA A5/B5 Stable, stay-in-grade Engine Oil intended for use at extended Drain Intervals in Passenger Car & Light Duty Van Gasoline & Diesel Engines designed to be capable of using Low Viscosity Oils with HTHS Viscosity of 2.9 to 3.5 mPa*s. These Oils are unsuitable for use in certain Engines - consult vehicle-OEM’s owner’s manual/handbook in case of doubt
ACEA C2 Stable, stay-in-grade Engine Oil with Mid SAPS-Level, intended for use as catalyst compatible Oil at extended Drain Intervals in Vehicles with all Types of modern Aftertreatment Systems and High Performance Passenger Car & Light Duty Van Gasoline & DI Diesel Engines that are designed to be capable of using Low Viscosity Oils with a minimum HTHS Viscosity of 2.9 mPa*s.
ACEA C3 Stable, stay-in-grade Engine Oil with Mid SAPS-Level, intended for use as catalyst compatible Oil at extended Drain Intervals in Vehicles with all Types of modern Aftertreatment Systems and High Performance Passenger Car & Light Duty Van Gasoline & DI Diesel Engines that are designed to be capable of using Oils with a minimum HTHS Viscosity of 3.5 mPa*s.
ACEA C4 Stable, stay-in-grade Engine Oil with Low SAPS-Level, intended for use as catalyst compatible Oil at extended Drain Intervals in Vehicles with all Types of modern Aftertreatment Systems and High Performance Passenger Car & Light Duty Van Gasoline & DI Diesel Engines that are designed to be capable of using Oils with a minimum HTHS Viscosity of 3.5 mPa*s.".
It doesn't mean motorbike engine oils are a rip-off / not worth it. But doesn't mean car oils are inherently worse either.
I've had clutch slip off a 70bhp bike with Castrol Racing fully-synth 10w-40. That was "fixed" (hidden for another 12 months) from using a car 10w-40 largely because it had higher Viscosity and Viscosity Index.
I've done 10k miles with car oil on a 182bhp bike that would happily lift the front at 90mph. Zero clutch slip up in motion or off the standing 1/4.
One anecdotal story doesn't necessarily mean shit of course.
Not saying all bike oil is a ripoff, or all car oil is better. Don't know enough about it and the additive pack on each oil isn't always known to public.
But there is info in the standards, info from people doing Virgin Oil Analysis (VOA) and Used Oil Analysis (UOA) you can start to build a picture. How much of that is based in reality or fiction...... its a punt. But it can at least be a semi informed punt.
The one guy (thirdgenlxi) who jumps out from memory was the dude who ran 300k miles on his CBR600 using primarily Shell Rotella T6, a "5W-40 synthetic heavy duty engine oil"
Even accounting for American's being limp right wristed, thats decent miles.
Can't find his proper thread on it, but various posts. Again, could be marketing BS, but didn't jump out as such.
Again, two stories don't mean anything.
Weasley wrote: | In truth very few OEMs demand "synthetic" or "semi-synthetic" or whatever - they usually ask for a viscosity grade |
Just as a side, this reminds me, 7 years ago I emailed 4-6 of the largest motor oil producers in Europe / USA asking about the additive packs and suitable applications. Hoping maybe I got a different response from Europe to USA where the companies matched.
Was completely stonewalled in their uninformative generic PR responses. Hit by corporate BS folk who had never seen oil before unless it was drizzled on their garlic bread.
But Fuchs Silkolene were different, incredible. They put me on to their chemist who seemed happy to chat through the formulae / application of their engine oils. Genuinely by far the most helpful reaction I got from any oil company.
Weasley wrote: |
I use a full-synthetic oil in mine because to get a 10W-50 with the performance needed that's what it takes
The $1m question. What is the 10w50 that you use and why?
Back to top |
weasley |
Posted: 11:58 - 16 Aug 2021 Post subject: |
Pigeon wrote: | OIL THREAD!!!!
arry wrote: |
That would be Weasley; legend, might have a man crush |
Oh you.....
Pigeon wrote: | Simon13245 wrote: |
[Lots of good JASO/JAMA/JALOS, API, ACEA guff...]
[....snip....]
Was completely stonewalled in their uninformative generic PR responses. Hit by corporate BS folk who had never seen oil before unless it was drizzled on their garlic bread....
Well in essence you're getting an inside line from me, but presented as my personal POV rather than on behalf of a major oil supplier.
The car vs bike oil thing just goes on and on. Bike oil is developed for bikes, which have gearboxes and clutches to lubricate (as well as the engine) hence needing careful control over the friction. Car oils may incidentally have frictional properties that don't mess up the clutch but this is largely a serendipitous accident, but one which many people happily exploit with no issues.
The Americans love to use Rotella in pretty much anything - old car? "Rotella", modern bike? "Rotella", lawn mower? "Rotella". They probably also use it in commercial trucks as well.
Pigeon wrote: |
Weasley wrote: |
What's in my bike at the moment is Motorex because that's what KTM use and I CBA to take my own oil for the service last time it got done (and the Motorex stuff appears to be decent enough). Given time to get my shit together I'd use Castrol Power1 Racing 4T 10W-50. ____________________
Yamaha XJ600 | Yamaha YZF600R Thundercat | KTM 990 SMT | BMW F900XR TE |
Back to top |
MCN |
MCN Super Spammer
Posted: 10:24 - 17 Aug 2021 Post subject: |
Muricans also swear by: Sea Foam, Dawn (dish soap) Soaking siezed mechanisms in Diesel to free/fix them, Southern Fried Chicken, Gumbo, Blue-Grass Cuntry Moozak, Pick-Up trucks, Budweiser beer, Guns, Hunting big game, deer/bears/cougar cats, making America bitter.
____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Back to top |
xX-Alex-Xx |
xX-Alex-Xx World Chat Champion
Posted: 10:39 - 17 Aug 2021 Post subject: |
MCN wrote: | Muricans also swear by: Sea Foam, Dawn (dish soap) Soaking siezed mechanisms in Diesel to free/fix them, Southern Fried Chicken, Gumbo, Blue-Grass Cuntry Moozak, Pick-Up trucks, Budweiser beer, Guns, Hunting big game, deer/bears/cougar cats, making America bitter.
Yeah but you can turn right on a red light. Pretty sure that’s their only contribution to society though. ____________________ DILLIGAF |
Back to top |
jimster |
jimster Spanner Monkey
Back to top |
arry |
arry Super Spammer
Back to top |
jimster |
Back to top |
weasley |
Back to top |
jimster |
Back to top |
blurredman |
Posted: 09:04 - 24 Aug 2021 Post subject: |
Try it.. If the clutch slips, drain it immediately (to save the clutch) and filter the oil through some coffee filters, and put it in another vehicle of yours (if you have a pre-variable valve car?) when that needs it. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Past: 1991 Honda CG125BR-J, 1992 (1980) Honda XL125S, 1996 Kawasaki GPZ500S.
Current: 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (bored to 295cc) - 38k, 1989 MZ ETZ251 - 49k, 1979 Suzuki TS185ER - 9k, 1973 MZ ES250/2 - 17k. |
Back to top |
jimster |
Back to top |
The last post was made 2 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
