What have you done to your bike today?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 11, 12, 13 ... 46, 47, 48  Next
ThatDippyTwat
PostPosted: 18:48 - 04 Nov 2021    Post subject: Reply with quote
Finally managed to line up the high level link ppe and Remus Viper I had welded up a few weeks back. It just clears the tyre, but a miss is as good as a mile.
https://i.imgur.com/DMaI1Ybl.jpg
Big question is, do I leave it on the 4th gen, or put it on the 3rd gen that arrives next week.
https://i.imgur.com/voK4atbl.jpg
Bhud
PostPosted: 21:47 - 05 Nov 2021    Post subject: Reply with quote
I got tired of the My Little Pony saddle bag containing my tool kit, so I fitted an ammo tin instead. No modifications made to the bike - it fits where the handle rail used to be. It seems robust enough, but I can't declare it a resounding success yet, as it does vibrate a lot. It's attached by means of 2 sections of square-section steel tubing, with very large washer sandwiches at each end (rubber in between 2 steel washers). One bolt is 6mm and the other 8mm. I'll need to ride around with this for a bit and see if it works out. If not, I can always strengthen it by reinforcing the hidden side with sections of flat iron.
https://i.ibb.co/0Qj97CL/IMG-20211105-151744.jpg
https://i.ibb.co/RDYWSCC/IMG-20211105-151753.jpg
Easy-X
PostPosted: 22:38 - 05 Nov 2021    Post subject: Reply with quote
I'm building up a little toolkit at the moment, what's in yours?
Nobby the Bastard
Harley Gaydar
PostPosted: 22:41 - 05 Nov 2021    Post subject: Reply with quote
A phone and the number for recovery that I pay for.
Sprint ST 1050
Bhud
PostPosted: 23:42 - 05 Nov 2021    Post subject: Reply with quote
Fuses (glass), spark plugs, 2 x CO2 canisters, can of Tyre Weld (as this bike uses tubed tyres), 2 x Allen keys, cheap but strong multitool with screwdrivers and pliers and blades which I don't mind abusing (I keep my Gerber at home), adjustable wrench (standard type), adjustable wrench (6-sided 2-ended type), normal posidrive screwdriver, bag of cable ties, electrical tape, test light screwdriver, assorted open-ended spanners in small sizes (10mm to 16mm). I'm not carrying anything half-decent in there, in case I want to leave the bike somewhere unattended.
I have a padlock on its way to me, but if someone is determined to get into that, they will. It's better than a soft bag though.
Kawasaki Jimbo
PostPosted: 00:31 - 06 Nov 2021    Post subject: Reply with quote
Punctures notwithstanding, what kind of breakdown do you envisage that lot being useful for?
Bhud
PostPosted: 01:01 - 06 Nov 2021    Post subject: Reply with quote
I hope that one day I'll trust the bike enough that I'll be able to just keep that thing empty and use it just for holding ale bottles. I believe the bike is fully sorted. It doesn't give me any hint or sign of trouble. It's a real delight. However, getting it to work has been an interesting road. Many times this year, I thought it was OK but it needed another look. Do I trust it? I suppose I should do so. A lot has been renewed on this bike. Not everything is wired or cabled up as standard. I just enjoy riding it more knowing that I've got the kitchen sink with me. I do have a full nationwide recovery policy. I suppose the tool kit is a bit OTT but I want to put a few thousand miles on it before I go without.
Kawasaki Jimbo
PostPosted: 01:05 - 06 Nov 2021    Post subject: Reply with quote
Bhud wrote:
holding ale bottles… I just enjoy riding it more knowing that I've got the kitchen sink with me. I suppose the tool kit is a bit OTT but I want to put a few thousand miles on it before I go without.
Good points. I get that.
Easy-X
PostPosted: 01:31 - 06 Nov 2021    Post subject: Reply with quote
Fuses are a good shout. I've got most of the other things you've mentioned. I found a multimeter for about £4 instead of a test light, I like multimeters Smile
trevor saxe-coburg-gotha
PostPosted: 06:54 - 06 Nov 2021    Post subject: Reply with quote
bought it
hellkat
PostPosted: 15:38 - 06 Nov 2021    Post subject: Reply with quote
Bought the Snarley a new V5 Rolling Eyes
Lost the old one Rolling Eyes Rolling Eyes
And also taxed it for a year.
Hong Kong Phooey
PostPosted: 15:44 - 06 Nov 2021    Post subject: Reply with quote
MOT pass on the CBR, handling is sweet with the new headstock bearings.
Easy-X
PostPosted: 17:22 - 06 Nov 2021    Post subject: Reply with quote
Put a tracker on the Kwacker Laughing
Bhud
PostPosted: 18:13 - 07 Nov 2021    Post subject: Reply with quote
What kind of system did you choose?
hellkat
PostPosted: 21:10 - 07 Nov 2021    Post subject: Reply with quote
I posed around town on it last night Wink
Was quite fun.
Easy-X
PostPosted: 22:32 - 07 Nov 2021    Post subject: Reply with quote
Hand rolled, I have mentioned it in the techie section.
Easy-X
PostPosted: 22:42 - 07 Nov 2021    Post subject: Reply with quote
Was quite fun.
Hackney's hardly high-class, hipsters habituate. Horrifying!
UncleFester
PostPosted: 07:33 - 08 Nov 2021    Post subject: Reply with quote
Right bike for the area then Very Happy
Module 1 and 2 passed - October 2014. Happy owner of a 2017 Z1000SX, ex owner of a YBR125 / CB500 / VFR800.
ThunderGuts
PostPosted: 09:09 - 08 Nov 2021    Post subject: Reply with quote
This involves taking the right side engine cover off and the centrifuge cover, so plenty of messing around removing old gaskets from the casings. Oh fun
It did at least all go to plan and it was done and dusted in a few hours. The centrifugal oil cleaner was actually cleaner than expected, a small amount of crud (circled in red) but not as much as I thought.
This lot pretty much exploded when I took it apart (despite leaning the bike over at 45 degrees for the procedure), with springs and various other bits flying everywhere. Fortunately it wasn't rocket science to work out how it all went back together.
TG.
ThatDippyTwat
PostPosted: 17:15 - 10 Nov 2021    Post subject: Reply with quote
Got it home.
1991 VFR750, 43K miles. Used to be red, but I like the colour she is now. Lots of work already done, wavy discs up front, calipers look new, braided lines all round, very new Avon Storm 3D's on both ends... someone put effort into her. Plan is to chuck a battery on her, fuel in the tank, then wash and MOT her.
https://i.imgur.com/oDlCNwHl.jpg
hellkat
PostPosted: 22:20 - 10 Nov 2021    Post subject: Reply with quote
The hipsters were the ones who dress like Bodie and that guy from Oasis Laughing
Aside from them, the bar I was in was mostly goth.
They had what I think was the remaining Halloween decorations up, but probably everybody didn't want them taken down anyway.
I don't mind the odd hipster.
They give the place a bit of colour.
Fresh-faced little sausages, they are.
PostPosted: 22:54 - 10 Nov 2021    Post subject: Reply with quote
Dropped it off for its mid run-in service.
Easy-X
PostPosted: 14:49 - 11 Nov 2021    Post subject: Reply with quote
XSR700 MoT today... FAIL* Shocked
Forgot to put the pillion pegs back on, idiot Brick Wall Still, it was probably the loveliest November morning, sunny and warm(ish), to be riding about.
Bonus: it was damp out this morning, last night's rain still sitting on the bike cover. Took it off to reveal a bone-dry bike, glad I binned the old cover Smile
*BTW a reminder that if a bike fails and even though your last MoT hasn't yet expired you're not meant to ride the bike unless you've got a properly booked in re-test.
hellkat
PostPosted: 23:01 - 11 Nov 2021    Post subject: Reply with quote
https://www.youtube.com/watch?v=-gA7qq7Ja4U
Skudd
PostPosted: 08:57 - 12 Nov 2021    Post subject: Reply with quote
New W5W light bulb (what is the point of them?) New battery in the tyre pressure sensor.
I now have zero fault lights on the bike................... until the next one.
The last post was made 2 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Page 12 of 48
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.48 - MySQL Queries: 17 - Page Size: 136.88 Kb
