| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
 Posted: 09:25 - 18 Feb 2022 Post subject: Garage security |
As my new house will be coming with a garage, just wondering what others do to help keep their kit secure?
Already planning on putting a camera at the back of the garage on the inside, probably with motion sensor lights (more for convenience than security but hey). Will be putting a ground anchor in the floor for the chain. Any good tips on security for the door itself? Was thinking something along the lines of a Garage Defender...
https://www.screwfix.com/p/squire-ga4-garage-defender/79478
Anything else worth considering? ____________________ DILLIGAF |
| rpsmith79 |
 rpsmith79 World Chat Champion
| Ste |
 Ste Not Work Safe
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 10:59 - 18 Feb 2022 Post subject: |
My old garage originally had just a single point locking mechanism at the top that could be popped with a screwdriver, so I replaced it with what I was told was a much more secure 4 point locking door. The bastards just folded the door at the bottom, popped it of its rails and took both bikes anyway.
I replaced that with the same type, but with a garage defender after that. Much more secure, but it was a pain in the arse to have to sod about with every time I wanted to get something from the garage, let alone take the bike out.
The area in front of the garage was just compacted earth, so dug part of that out to extend the concrete base enough to fit the base plate to. the surrounding earth meant that whenever it rained the bottom of the garage door would get splattered with mud, right where the padlock was, so you'd be fighting against gritty sludge when trying to unlock it.
Glad I've moved  ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| xX-Alex-Xx |
 Posted: 11:12 - 18 Feb 2022 Post subject: |
| rpsmith79 wrote: | Does the garage have windows, if so i bought a pack of "glass beak sensors" for my garage windows, battery powered, but makes a right old racket when you bang on the glass
Garage door defender is a good plan, i had one at my old house that had a detached garage, but my current house has a integrated garage, and i could find any that could be undone from the inside, and i don't like the added faff of having to go outside just to open my garage door |
No windows fortunately. Camera with motion detection should be enough, long as they don't knock out the internet first
| Ste wrote: | Standard cheap up and over garage doors are flimsy and weak so upgrading the door will make your garage slightly more Fort Knox. |
| The Shaggy D.A. wrote: | My old garage originally had just a single point locking mechanism at the top that could be popped with a screwdriver, so I replaced it with what I was told was a much more secure 4 point locking door. The bastards just folded the door at the bottom, popped it of its rails and took both bikes anyway. |
Depending on the quality of the door I might add a bit of extra cross-bracing, don't know if it would make any difference... Hopefully the additional visible security on the outside might put off at least a %age of TWOCing bastards ____________________ DILLIGAF |
| Fat Angry Scotsman |
 Fat Angry Scotsman World Chat Champion
 Posted: 11:26 - 18 Feb 2022 Post subject: |
When I get a garage, I am only going to put one of these behind the door:
https://image4security.com/collections/guardsman-garage-security-barrier
and have a RoadLok on the front wheel as my next big bike is going to have radial calipers:
https://roadlok.com/will-it-fit
Done. Anything more will only be an extra hinderance to myself.
RoadLok:
1. Cut through the bolts (2 cuts), then,
2. Cut through the brake disc (2 cuts).
Guardsman Barrier:
3. Cut through the tube (2 cuts if only 1 thief, 1 cut if there is two with enough strength to produce enough bending moment to yield the tube to the side enough to drag the bike through).
If they don't want to cut anything then good luck to the team of guys having to lift the bike over the barrier. ____________________ PRESENT: 2018 BMW S1000XR SE Sport.
PAST: 2009 Kawasaki ER-6F. 2021 Zontes ZT-125U. |
| xX-Alex-Xx |
 Posted: 12:23 - 18 Feb 2022 Post subject: |
| Fat Angry Scotsman wrote: | |
Looks ok, but it'll not stop them taking all the tools and other kit from the garage. Good solution for vehicles-only garages though. ____________________ DILLIGAF |
 Posted: 12:54 - 18 Feb 2022 Post subject: |
| xX-Alex-Xx wrote: | | Fat Angry Scotsman wrote: | |
Looks ok, but it'll not stop them taking all the tools and other kit from the garage. Good solution for vehicles-only garages though. |
You over-estimate the value of my tools  ____________________ PRESENT: 2018 BMW S1000XR SE Sport.
| ThunderGuts |
 ThunderGuts World Chat Champion
 Posted: 13:06 - 18 Feb 2022 Post subject: |
The idea of a physical barrier across I like if the garage had that purpose only, but I use mine as a workshop, it has a (beer) fridge in it, washing machine etc.. but is still detached so trying to get past a literal barrier like that would be a pain.
Defenders are good - they hardly make it impossible, but they make it harder. Ground anchor - check the floor is genuinely solid concrete. Sometimes it's a thin skim. Don't skimp on the garage anchor - once it's there, it's there - worth getting a heavy duty one. Just check exactly where you want it and try (as best you can) to envisage how other future bikes may sit in relation to it (e.g. current bike you might get a chain through the frame, next bike it might have to be the rear wheel etc..).
Nice powerful PIR floodlight out front. Try to reduce "peep holes" around the garage, so shim/fill any gaps as much as possible so people can't peer in to see what's inside.
Ideally connect up to a house alarm, or an alarm of some sort.
Whatever the measures, any garage is infinitely better than being outside.  ____________________ TG. |
| pepperami |
 pepperami Super Spammer
| ThunderGuts |
| Robby |
 Robby Dirty Old Man
| rpsmith79 |
| Robby |
 Robby Dirty Old Man
The last post was made 4 years, 176 days ago. Instead of replying here, would creating a new thread be more useful? |
