Author |
blurredman |
Posted: 10:05 - 10 May 2022 Post subject: |
After picking up replacement coil on Sunday from a friend at the MZ club meet local to me, I installed it last night and went for a quick 10 mile ride. There were absolutely no problems.
I've taken the bike to work today and all is happy. Idling well, lights 'n all!
Success so far it seems. Some more riding, then I can swap the condensors back to their original bikes. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Past: 1991 Honda CG125BR-J, 1992 (1980) Honda XL125S, 1996 Kawasaki GPZ500S.
Current: 1973 MZ ES250/2 - 17k, 1979 Suzuki TS185ER - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k. |
Back to top |
Easy-X |
Easy-X Super Spammer
Posted: 21:32 - 11 May 2022 Post subject: |
Wiring on the ol' Triumph is almost finished. I'm waiting on a nice STOP engine button and I need to rewire the rear light...
It's an el-cheapo design. Brake is all the LEDs and Running is via a resistor. Unfortunately activating the brakes feeds back into the running light circuit which probably wouldn't be a problem on a modern bike (with the lights always on) but on this thing we have an on/off switch just to stop the lights depriving the coils and plugs of power when kicking it over. I don't think it'll make much odds but my father-in-law is adamant he wants the lights switchable.
Anyhoo, I'm thinking a couple of rectifier diodes might be the simplest solution to stop the two circuits from feeding into each other.
Apart from that I mixed up a red/green wire with a brown/green wire but otherwise all went well, the latching relays for the indicators and main beam seem particularly clever now it's all wired in
And as a bonus we tried kicking it over a few times and we have spark! probably no timing but... we have spark! ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
B1N |
B1N Scooby Slapper
Posted: 23:36 - 11 May 2022 Post subject: |
Easy-X wrote: | Wiring on the ol' Triumph is almost finished. I'm waiting on a nice STOP engine button and I need to rewire the rear light...
And as a bonus we tried kicking it over a few times and we have spark! probably no timing but... we have spark! |
Sounds like it's coming on great.
Check your chassis/ ground wires are secure on those light circuits. |
Back to top |
virus |
virus World Chat Champion
Back to top |
Easy-X |
Posted: 22:55 - 12 May 2022 Post subject: |
There's that motogadget thing for $£€ouch! money but I've never really liked the contortion of button holds and presses. I'd probably hand-roll an Arduino if I was so inclined I like the "plausible deniability" switch idea though
Apart from the terrible design (or lack thereof) of old Triumphs in general if I was going with a "garage queen" show stopper I'd be looking at routing cables through the handlebars and frame. Tricky on a T140 given the oil reservoir, maybe on the next bike...
I said something along those lines not long ago to the old fella and he said "no, not doing another one." Technically correct if you say a Triumph isn't an old Harley in need of TLC which is what he's eyeing up at the moment. FFS we haven't finished this one yet! ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
Bhud |
Bhud World Chat Champion
Posted: 18:14 - 13 May 2022 Post subject: |
Can't keep this old bike completely original - the old speedo wasn't accurate above 50-ish mph, and the spindle-driven tachometer has been hopelessly inaccurate since I bought it, and an annoyance (it works by creating an electromagnetic field to move the needle by the action of the tacho cable inside a permanent magnetic field). However, I've kept the old stuff, so this is a reversible mod. I didn't want to buy anything or use anything from Ebay.
Removed the tachometer and tach cable, and the spindle which is driven from the camshaft. Replaced the speedo with an old (and quite large!) Yamaha speedo I had lying around and which I like. Relocated idiot lights to the right with the help of a piece of steel (now I've got to find a way to colour them green, orange and red). Relocated the ignition barrel elsewhere, with some minor fabrication work using a piece of angle iron.
https://i.ibb.co/RYVNtv3/speedoreplace.jpg |
Back to top |
virus |
Back to top |
to v or not to v |
to v or not to v World Chat Champion
Back to top |
redeem ouzzer |
Posted: 21:43 - 13 May 2022 Post subject: |
Got my GSXR1100 back after a long spell in dock to fix a rapidly worsening oil leak (front recirc tube o-rings pissing out).
Also got the dying standard CDI replaced with an Ignitech and had some mapping done on ye olde dyno.
It's amazing how soft the standard ignition curves on a lot of bikes are. Peak was fixed at 120bhp regardless of what level of advance was dialled in, so it's safe to assume that this is set in stone by mechanical factors, most likely cams and exhaust. However considering the rest of the bike is bone standard and 32 years old, it's more than acceptable. What is more impressive is the low and mid gains achieved by live mapping.
https://live.staticflickr.com/65535/52071758690_46622fc614_b.jpg
Almost a 20bhp gain at 4000rpm and has an advantage over the standard ignition till just passed 7000rpm (which coincides with the rev range where the bike spends most time on the road). As I said, couldn't get any gains at peak but did manage to flatten the curve so it holds peak power a bit longer and doesn't die off so quick. Very pleased at the improvement considering it's achieved purely via black box and laptop fiddling. ____________________ Be a REAL MAN! |
Back to top |
Easy-X |
Posted: 19:46 - 14 May 2022 Post subject: |
Was going to start the ol' Triumph today but got as far as filling the gearbox and frame with oil but then did so many odds and sods it was soon beer o'clock and the cup final
Did manage to relocate a bundle of wires from behind the headlight to inside the bucket so looks really tidy now ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
Bhud |
Posted: 20:20 - 14 May 2022 Post subject: |
I discovered a minor oil leak a couple of days ago, when I saw that some oil had burned on the exhaust. Opening it up, I saw that the clutch pushrod oil seal wasn't sealing, so I found and bought a NOS one.
Replacing this today didn't take long - I'd say just an hour from start to finish, including sprocket removal and putting everything back. You can see the old one weeping slightly in the photo to the left. Couple of odd things: someone had been at it before, and damaged engine case slightly. That actually helped when removing the circlip. More interestingly, the seal I removed was not the proper Kawasaki one. It was a cheap-looking surrogate, probably meant for a different bike. This is probably why it was leaking. The replacement seal is a NOS Kawasaki seal, and is superbly designed. The entire body of the seal exploits the spring pressure of the metal from which it's made (it exerts a radiating pressure to its outer circumference), and the outermost lip crushes inward slightly as it's driven into the seat.
https://i.ibb.co/pJc2F6K/clutchpushrodsealreplacement-small.png |
Back to top |
blurredman |
Posted: 11:16 - 18 May 2022 Post subject: |
Bought and installed last night replacement clutch springs for my '87 MZ ETZ 250 after messing around for too long with 'used' original springs and also shitty aftermarket springs both of which I can compress fully fairly easily between both thumbs and index fingers as one press. The shitty aftermarket springs are sometimes at or 1mm below the free length minimum specified in the repair manual! (I know that pressure is obviously better measurement of a springs worth, but out of the box having the length wrong foremost is pretty poor).
Have also tried different oils, some of which helped with clutch slip but ultimately didn't resolve it fully.
I didn't really want to have to change plates because I had already done so recently to try and fix the problem (put in replacement used, but good thickness plates), and it's a hassle really on these bikes. Though it was a possibility the plates could be a little impregnated with incorrect oil from the past or glazed (more likely). So I thought i'd have a go at finding thicker and taller springs.
So In the end I went with Springs designed for Suzuki GS400 from the 70's/80's (according to the aftermarket company document) - I only bought them on e-Bay based off the dimensions I required.
But it was a success, at least so far as I can tell on the way to work. As with last time I tested with a different oil, TESTING for slip got nothing, but just riding and not looking for the problem had it come forth, so will have to just ride and see whether it continues to be a problem or not. May or may not buy a 2nd set of these same springs for the '90 MZ, which also has a slight very minor slipping clutch (but no where near as bad as this '87). ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Back to top |
Easy-X |
Posted: 18:41 - 18 May 2022 Post subject: |
Still waiting on the tank but fuck it...
https://youtu.be/yiNnnpYFY60
Started off with "I tried kicking it over... nuffink" Errm... have you tried the kill switch
After that it spluttered a bit. Gave it a bit more air (idle adjust) and it started fine Actually that was a red herring and adjusting the timing got better results and we could dial the idle adjust right back.
Have we got the right pilot or main jets? Fuck knows. Are these flat slide "dirt bike" carbs going to do the job? No idea. I suspect it's running rich as no choke is required from cold and it'll fall flat on its face if we attempt to take it down the road but it kicks over easy and that's a start ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
to v or not to v |
Back to top |
Jayy |
Jayy Mr. Ponzi
Posted: 13:21 - 20 May 2022 Post subject: |
Back to top |
Rob W |
Rob W World Chat Champion
Back to top |
Easy-X |
Back to top |
pepperami |
pepperami Super Spammer
Posted: 12:54 - 23 May 2022 Post subject: |
Happy Pepperami is happy!
‘Project Scrappy Hyosung’ has taken a small but significant step forward..
I know fk-all about electronicals, but I do know to replace broken stuff if it looks broken.
The left hand controls were fooked, and I found a good replacement.
After much swearing and sweating the replacement has been fitted.
Not as straightforward as you might think.
I can now operate the choke and thus start the engine .
The engine runs fine and revs throughout it’s range, just a little bit quick on tick-over.
I now have indicators also ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
Back to top |
Bhud |
Posted: 18:30 - 23 May 2022 Post subject: |
Just in the nick of time, before the rain, I got this done. The long overdue replacement of starter clutch springs and rollers.
This was a messy, annoying job. I've been putting it off for quite a while. But, one in every 5 times I tried to start it, the bike would clatter horribly. A noise that would give a bad impression. An outsider might at first think "nice bike", but then think "what an old junker" once they heard that noise. Glad I got it done, but, as always, I hope I did it right... All buttoned back up and complete, with a new Athena gasket - hope it doesn't leak.
https://i.ibb.co/pxbBtWZ/starterclutchrepair.png |
Back to top |
Easy-X |
Posted: 18:56 - 25 May 2022 Post subject: |
All the wires are now stuffed in the headlamp bucket:
https://i.imgur.com/XnM4W61.jpg?1
Oh, and the braided HT leads are on. Looking very tidy at the back:
https://i.imgur.com/zMWKnGh.jpg?1
Might put a bit of tape around those wires though.
Just for a bit of fun we checked the compression. ~100 and ~110 and the spec is 121psi so nothing worth worrying about. Still left to do: check valve clearances, fit the Amal Mk2 carbs, tank and panels still at the coachworks.
Fucker better be rideable after all this ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
Ariel Badger |
Ariel Badger Super Spammer
Back to top |
Skudd |
Skudd Super Spammer
Back to top |
B1N |
B1N Scooby Slapper
Back to top |
Easy-X |
Posted: 22:21 - 28 May 2022 Post subject: |
2nd engine test of the T140E project:
https://i.imgur.com/uJra5vl.jpg?1
This time with the Amal Mk2 carbs:
https://i.imgur.com/IkzawAj.jpg?1
Started on the second kick and given these are a left hand / right hand pair took about 5mins to adjust the idle and mixture screws. The bike certainly seems to like "proper" carbs a lot more than the £15 eBay specials
We had a good feeling until we stopped for a cup of tea and went to start it again. Fuck all - not even a splutter Upon examination of the plugs 'twas revealed they were bone dry. I suspect the converted spray-gun tank arrangement has a blockage but we may as well wait till the real tank comes back from the painters before trying again as the old fella is desperate for a road trial. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
B1N |
B1N Scooby Slapper
Back to top |
The last post was made 1 year, 352 days ago. Instead of replying here, would creating a new thread be more useful? |
