whats wrong with my carbs?
to v or not to v
PostPosted: 14:28 - 30 Jul 2022    Post subject: whats wrong with my carbs? Reply with quote
trying to balance carbs.
1+2 and 3+4 are balanced as pairs, then the 2 pairs are balanced.
i backed the screw all the way out of 1+2 carbs trying to adjust them with a cheap gauge and finally managed to get the screw back in today, i superglued it to the screwdriver to get it started off!
the problem im having is the adjustment screw is having no effect on 1+2 carbs.
carb 1 is on the bottom of the scale(Morgan carbtune) and carb 2 is on the top. and turning the screw is having no affect.
what have i cocked up?
Moto Guzzi V7.
Nutty
PostPosted: 16:31 - 30 Jul 2022    Post subject: Reply with quote
Maybe try to gently "bottom" all the Pilot Screws and then bring them out 2 1/2 turns each and take it from there, that should be standard measurement, then carry on with the balancing
Nobby the Bastard
Harley Gaydar
PostPosted: 17:23 - 30 Jul 2022    Post subject: Reply with quote
Are you sure you don't have a leaky rubber or two? 8tll make it almost impossible to balance them.
Triumph Sprint ST 1050
Islander
PostPosted: 17:56 - 30 Jul 2022    Post subject: Reply with quote
That^^
Check for leaks.
PostPosted: 18:31 - 30 Jul 2022    Post subject: Reply with quote
If the butterfly spindle is worn it'll leak air through the bushes but that will be obvious.
Have you done the vales and compression check? If one cylinder is low on compression or has tight valves it won't be firing as well as the next and if it's not firing as wll it will be producing less vacuum.
to v or not to v
PostPosted: 18:58 - 30 Jul 2022    Post subject: Reply with quote
not done any of that Confused
Moto Guzzi V7.
to v or not to v
PostPosted: 19:00 - 30 Jul 2022    Post subject: Reply with quote
how do i go about checking for air leaks?
Moto Guzzi V7.
PostPosted: 20:56 - 30 Jul 2022    Post subject: Reply with quote
Get a mapp gas torch and turn the gas on low but not lit. Wave it around the carb inlets. If the engine note changes (increases, probably) then it's breathing in combustible gas. Obvously, keep away from any air intake.
to v or not to v
PostPosted: 13:36 - 31 Jul 2022    Post subject: Reply with quote
i think ive isolated the problem. the butterfly valve on cylinder 1 is not closing fully. im able to push it down about 1mm when it should be fully seated Sad
does anyone have an idea as to what could be causing this? i cant see any obvious debris.
Moto Guzzi V7.
PostPosted: 15:41 - 31 Jul 2022    Post subject: Reply with quote
Is there still a little free play onthe throttle cable or do you need to back it off a touch? Or back off the idle adjuster?
to v or not to v
PostPosted: 17:45 - 31 Jul 2022    Post subject: Reply with quote
have just checked the cables and there is free play on both.
Moto Guzzi V7.
PostPosted: 19:22 - 31 Jul 2022    Post subject: Reply with quote
My next step would be to pull the carbs and sort them on the bench. Get the carbs off, cables disconnected etc. Wedge up the four plungers (or if you're brave pull the tops and extract them). Hold all four up to the light and see if you can adjust them so that the crescent of light under each butterfly is equal.
If you're lucky all that's wrong is that you've got the adjusters too far out of whack. Set all of the balance screws to the tabs are dead centred between the two springs and go from there.
to v or not to v
PostPosted: 20:24 - 31 Jul 2022    Post subject: Reply with quote
removing the carbs from the bike is a scary thought, im worried ill do even more harm.
looking at the manual it seems quite involved. the coolant has to be drained before you can even start.
Moto Guzzi V7.
Islander
PostPosted: 19:32 - 01 Aug 2022    Post subject: Reply with quote
Access is usually quite tight hence the need to remove or move a lot of stuff. Be methodical, take loads of photos from many angles before you disassemble each sage and keep fasteners grouped together based on where they came from. Make notes if it helps.
It's not hard to do, it just needs a bit of care and attention. Thumbs Up
Nobby the Bastard
Harley Gaydar
PostPosted: 19:52 - 01 Aug 2022    Post subject: Reply with quote
If thats scary don't ever try and reshim a genesis engine....
PostPosted: 20:15 - 01 Aug 2022    Post subject: Reply with quote
Then do your best with a torch and mirror or whatever. You need to find out what's holding that butterfly open.
Bhud
PostPosted: 20:17 - 01 Aug 2022    Post subject: Reply with quote
Bite the bullet and do it properly. Thumbs Up Thumbs Up
Start from scratch. Carbs off the bike, valve clearances DO, renew any dodgy carb-to-engine rubbers (replace fuel line and any vacuum line at the same time, regardless of whether it's needed), then go through carbs and get them done. Valve shims first though.
1) Carbs clean and all passages that you can reach: clean.
2) Do you need to split carbs? Check by blowing down the fuel line tube while tilting it, for blockages (there will be resistance if there's dirt). If not, then leave it and don't split (more trouble than it's worth sometimes).
3) Float levels reset to factory spec.
4) Check jets and emulsion tubes are clean, especially pilot jets.
5) CV carbs: check diaphragms carefully, and replace where there are any tears.
6) Are your slides scored and are they sticking because of this? First things first: blast all your springs with carb cleaner, because return springs get clogged with dirt. After that, they should return smoothly. If not, then you MUST check if your main needle is bent. It should drop straight back into the main circuit. Is that OK? Then I (personally) don't have much of a problem with a dab of oil on the slides. See if that makes a difference. Beware though, that if it's wear in the throttle bodies (carb barrels) you will need new ones, or the problem will reappear in the winter.
7) Bench sync of carb bank.
8) Reinstall carb bank, get engine warm, then properly sync.
May take a bit of work but once it's done it's done. Just one of those things with bikes: a bodge/fix will do most of the time but not all the time. Sometimes you've got to go right through it. Good luck.
to v or not to v
PostPosted: 21:40 - 01 Aug 2022    Post subject: Reply with quote
would love to do the valve clearances Bhud, but thats way beyond my capabilities Shocked
Moto Guzzi V7.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:45 - 01 Aug 2022    Post subject: Reply with quote
Erm.
He didn't mention valve clearances.
Zen Dog
PostPosted: 21:58 - 01 Aug 2022    Post subject: Reply with quote
Nobby the Bastard
Harley Gaydar
PostPosted: 22:11 - 01 Aug 2022    Post subject: Reply with quote
His fault for not adding it to his numerical list.
Kawasaki Jimbo
PostPosted: 22:26 - 01 Aug 2022    Post subject: Reply with quote
You’ll surprise yourself. I have. Any job will take at least three times as long as you think it will, but do your research (forums, service manuals, parts microfiches), take photos of every little thing from different angles, make mental notes of the disassembly process and know it’s just a collection of bits bolted together in groups.
Having the right tools for the job helps, eg. Japanese Industry Standard (JIS) screwdrivers. Not all cross-heads are the same. Also a garage or roomy shed where you can abandon the job and come back to it after tea, or tomorrow.
The hardest part is the old connectors which won’t release, the corroded bolt/screw heads which round out, and the hardened rubber boots which won’t release and then wont accept the reinstallation. There’s always a way though. Also don’t over-tighten stuff. Lacking ‘feel’ I rely on torque wrenches.
It helps that I have two bikes so I can afford to take one off the road for an extended period and still ride. So get a second bike! Very Happy
I figure if it all goes wrong I’ll get my friendly local bike shop to pick the bike up and fix it, after all it’s already part-disassembled, but so far it hasn’t been necessary.
Fizzer Thou
PostPosted: 23:43 - 01 Aug 2022    Post subject: Reply with quote
You will not need to drain the coolant so as to remove the carbs.
I found it easier to leave the throttle cables attached to the carbs.Just take the throttle apart at the handlebar and unthread the cables through the frame.You will thank me when you do this as the cables are a b'stard to reattach otherwise.
When removing the cam cover to check the valve clearances I found it a lot easier to drain the coolant so as to pull the radiator forward for better access to the cams,which need to be removed as and when the shims need to be changed.
The cost of doing shims on an engine like this will be upwards of £350-£500 if taking to a shop to be done.If you choose to go that route then remove as much of the bodywork as possible as you will be charged for this.
I have seen the post on the exup1000.co.uk forum Thumbs Up
I am on there as YAMAEXUP Wink
Always have a 'Plan B'
PostPosted: 06:52 - 02 Aug 2022    Post subject: Re: whats wrong with my carbs? Reply with quote
Just thinking more about this. I don't suppose there's a chance that you've lost the spring from under the tab that the balancing screw pushes on? Or perhaps it came out and you put it back in the wrong side of the tab?
If you look at this pic:
https://i.ebayimg.com/images/g/EDQAAOSwRrFhcsS1/s-l1600.jpg
You see two springs. The tab goes between the end of the screw and the smaller spring on the right. If that spring on the right is missing or in wrong that might give you the effect you're seeing.
This first pic here shows it quite well:
https://www.xjrider.com/viewtopic.php?t=672
to v or not to v
PostPosted: 21:35 - 02 Aug 2022    Post subject: Re: whats wrong with my carbs? Reply with quote
nope everything is present. i think im getting closer to the problem...
watching videos of people bench setting carbs last night, it seems that the idle adjuster (mine was backed all the way out)is used to adjust the butterfly on carb 2, then the adjuster screw is used to sync carb one to two. my adjuster screw is currently out of the bike so creating the gap in no1 butterfly i guess?
now im having the problem that when i put the adjuster screw back in
it wont go in far enough in to start making any adjustment, after a couple of turns it goes stiff Sad
the thread looks ok on the screw, but ive ordered a couple of m4 screws off the bay to see if they will screw in ok.
i really should learn to leave well enough alone!
Moto Guzzi V7.
The last post was made 3 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 3.13 - MySQL Queries: 16 - Page Size: 140.76 Kb
