Extra horses hiding in the engine
hellkat
PostPosted: 22:46 - 28 Sep 2022    Post subject: Extra horses hiding in the engine Reply with quote
Would someone kindly explain the concept in words I can understand.
Brick Wall
TL;DR - The GSX got fettled for various problems that I thought were minor but apparently not.
And now they tell me that it has gone from 47 hp to 70 hp, an increase of 23 hp.
So that was nice.
I am looking forward to getting it back so that I can rag it about the place. Twisted Evil
But *where* did the extra horses come from?
Please keep your explanations to nursery level. Laughing
Nobby the Bastard
Harley Gaydar
PostPosted: 22:50 - 28 Sep 2022    Post subject: Reply with quote
Thats massive for an oil change.
Sounds like restricted for a learner.
Usually a limit on the throttle cable movement which is easy to remove.
Sprint ST 1050
hellkat
PostPosted: 23:20 - 28 Sep 2022    Post subject: Reply with quote
I don't think it was restricted Thinking
The guy I bought it off had just taken it round Europe, two-up with his bird, and it was immaculately tuned when I rode it back from Milan - it certainly had plenty of go in it, as I proper caned it back across France Cool (rare for me)
But then sitting about unridden for a few years hasn't done it any favours: old petrol, dust and shite etc., so maybe it lost some vroom at some point and now they found it again?
I dunno, is that a likely thing?
WD Forte
PostPosted: 23:51 - 28 Sep 2022    Post subject: Reply with quote
Impossible to be specific at a distance, only the fettler would have
some detailed of what he found and what he did.
Sounds like it could be stuff like gummy/sticky old petrol,
oxidisation on electrical contacts, stiffness on things what
didn't ought be be stiff and general neglect.
So, when it finally got some tlc it kinda brought it back to life,
which isn't an unusual occurrence.
bikers smell of wee
A classic is that the holes in the carburettor jets wear over time and can become larger and oval, delivering the wrong mix of fuel and air. They probably fitted new jets among other things.
Bhud
PostPosted: 00:19 - 29 Sep 2022    Post subject: Reply with quote
Did they measure before and after, on the dyno? Have you got a printout?
PostPosted: 00:20 - 29 Sep 2022    Post subject: Reply with quote
I presume they put it on a dyno before and after or is this just an 'estimated' power increase due to their wonderful administrations?
Personally I'd like the before and after dynos and a detailed list of the work done. It's certainly a fair request and even if you don't understand them, put it up on here and someone will tell you exactly waht you want to know. In girly language as well Wink Laughing
Triumph Trophy Launch Edition
hellkat
PostPosted: 00:40 - 29 Sep 2022    Post subject: Reply with quote
Yes it was done before and after the dyno.
One of the fettles was to get it shipshape to pass a ULEZ test, so (once my V5 comes back Rolling Eyes ) that box will also be ticked, and I can menace people in central London again Dance!
I will be asking for the paperwork/printouts which I am sure they will be happy to provide.
Bhud
PostPosted: 00:43 - 29 Sep 2022    Post subject: Reply with quote
That's one hell of a tune-up / service.
Pete.
PostPosted: 06:40 - 29 Sep 2022    Post subject: Reply with quote
If it was apparently running on all cylinders and not missing badly then I would say blocked air filter. I have seen bikes (my mate's 900 hornet for one) that would not even rev out with no load on it because the air filter was clogged up.
If it's done a lot of touring miles up to its service then it's very much a possibility.
a.k.a 'Geri'
A100man
PostPosted: 11:47 - 29 Sep 2022    Post subject: Reply with quote
I'll throw in - stuck rings unsticking after being given some stick..and/or poor valve clearance adjustment.
ThunderGuts
PostPosted: 12:27 - 29 Sep 2022    Post subject: Reply with quote
I tend to think the term of finding horses is reserved for restoring power lost from the expected output, rather than enhancement, so suggests poor running (as above) or other related issues. In theory, even something as mundane as low tyre pressures, stiff chain links or rough bearings could all drain wheel power without the engine missing a beat.
TG.
Robby
Dirty Old Man
PostPosted: 13:01 - 29 Sep 2022    Post subject: Reply with quote
Seeing as it was trying to get sorted for the ULEZ, I would assume it had a full service, where air filter is the big thing that can lose lots of power. Quite possibly new, or even different jetting. In this case, making it a bit leaner to reduce certain emissions may increase power. They may also have advanced the timing a bit.
It's quite possible to be significantly down on power from a number of small things, but not really feel it. It will feel a lot sharper now.
jeffyjeff
PostPosted: 11:38 - 30 Sep 2022    Post subject: Reply with quote
In simplest terms, all horses come from the energy contained in the fuel.
Engine air and fuel systems are designed to burn the fuel at the optimum fuel/air ratio, but running time tends to alter mechanical clearances in the engine as parts wear. Periodic tune-ups restore the clearances back to optimum. As a rule, air system problems result in low power with elevated exhaust smoke; insufficient fuel results in low power with no smoke, and could result from fuel degradation over an extended storage period. Those horses hiding in your engine are certainly a function of fuel delivery, and could be the result of something as simple as a loose throttle cable, or a throttle position sensor out of calibration. If the carburetor slide can only open to 80%, your engine can only make 80% power, even if the throttle is pinned. If you have electronic fuel injection, the ecm will only command 100% power if it senses 100% throttle on the throttle position sensor.
History shows again and again how nature points out the folly of men - BOC
Nobby the Bastard
Harley Gaydar
PostPosted: 12:30 - 30 Sep 2022    Post subject: Reply with quote
It's a carbed bike....
Sprint ST 1050
MCN
PostPosted: 14:10 - 30 Sep 2022    Post subject: Reply with quote
As WD suggests, most probable Dirty Lectrics, gummy petrol things.
Enjoy your revealed Horses Ma'am.
PostPosted: 15:27 - 30 Sep 2022    Post subject: Reply with quote
Coked up valves can cause something like that. Loose or tight valve clearances, blocked air filter, blocked fuel filter.... tonnes of stuff.
yen_powell
PostPosted: 15:49 - 30 Sep 2022    Post subject: Reply with quote
Measured at the back wheel? Rear brake freed up/serviced?
XT1200Z and a DR350 in bits
Pete.
PostPosted: 17:33 - 30 Sep 2022    Post subject: Reply with quote
If the brake disc was dragging to the tune of 23hp it would be glowing like a light bulb.
a.k.a 'Geri'
jeffyjeff
PostPosted: 19:59 - 30 Sep 2022    Post subject: Reply with quote
https://live.staticflickr.com/65535/52395570044_c2f2d5503e.jpg
The last post was made 1 year, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.93 - MySQL Queries: 17 - Page Size: 110.11 Kb
