Author |
Maffsticky |
Maffsticky L Plate Warrior
Back to top |
Nobby the Bastard |
Back to top |
Pete. |
Pete. Super Spammer
Back to top |
Nobby the Bastard |
Back to top |
stinkwheel |
Back to top |
Islander |
Islander World Chat Champion
Back to top |
jeffyjeff |
jeffyjeff World Chat Champion
Back to top |
Maffsticky |
Back to top |
Maffsticky |
Back to top |
stinkwheel |
Posted: 00:24 - 26 Oct 2022 Post subject: |
Maffsticky wrote: | Islander wrote: | Float valves not sealing could dump fuel into the sump - that would pressurise things too. If it's oil and fuel that's where I'd be looking. |
If it’s the float valves would this be able to cause all this pressure and every time u rev it hard it gushes Through the air box |
If the sump of your engine is full of petrol, yes. If the level of fluid in the crankcase is too high, when the pistons go down, they either lock and break the conrod because you can't compress liquid or force the fluid out through any holes or gaps, such as the breather.
You should not have petrol coming through a crankcase breather hose, there shouldn't be petrol in the part of the engine it is connected to.
So, yes, check the oil level, make sure there isn't petrol in the oil. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
ThunderGuts |
ThunderGuts World Chat Champion
Back to top |
A100man |
A100man World Chat Champion
Posted: 11:55 - 26 Oct 2022 Post subject: Re: Oil and fuel filling air box up through breathing pipe |
Maffsticky wrote: | Hi all I finally got my bandit 600 to run today but while it was running I was reving it quit hard and all of a sudden there was oil and fuel gushing out the air box so I whipped cover of the box and started it bk up again to find when reved it shoots loads of oil and fuel out through the breather pipe coming from the top of the head can someone please shed a little light on what it could be thanks maff |
Is this the one, centre of pic - looks like it's breathing via the cam-chain tunnel?
If so the suggestion that it is over filled with leaked petrol/oil seem likely. what's it smell like if you put your nose to the oil filler hole.
https://i.ebayimg.com/images/g/AVYAAOSwCh5hlahv/s-l1600.jpg ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
Back to top |
The last post was made 1 year, 176 days ago. Instead of replying here, would creating a new thread be more useful? |
