benelli bn 125 starting problems
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2
Nobby the Bastard
Harley Gaydar
PostPosted: 18:04 - 16 Nov 2022    Post subject: Reply with quote
Your inlet gap is nearly a millimetre? I would expect exhaust to be .2 and inlet .1 when cold.
Sprint ST 1050
WD Forte
PostPosted: 01:27 - 17 Nov 2022    Post subject: Re: benelli cutting out Reply with quote
adywood45 wrote:
What code reader did you get as im having the same problem i think as my reader says theres no codes stored in the ecu yet if i hold the throttle at a steady 3000 rpm it will surge 3000 to 3500 then return to 3000 rpm if i go out on the bike the eml light will come on and the engine will cut out it will re start runs really rough couple of revs it clears it's self then of you go again until the eml light comes on again and the engine just cuts out again iv'e checked valve clearances and there 0.10 ex 0.8 inlet any one got any ideas what it could be.
yes
bikers smell of wee
adywood45
PostPosted: 04:23 - 17 Nov 2022    Post subject: Reply with quote
Yes to what ? And Nobby thats the clearances it gives in the service manual online when i checked them they were less than that inlet was at 0.06 ex was 0.08 i put them at the specs of the manual and it didn't make a shits worth of difference to my cutting out problem and surging rpm at a constant throttle position of 3000 rpm it was a tad more rattley so ill put the tappet clearance back to how it was.
adywood45
PostPosted: 04:39 - 17 Nov 2022    Post subject: Reply with quote
Valve clearance( Cold engine )IN: 0.06 ~ 0.08 ex That's what it gives in the service manual for the valve clearances on the Benelli BN 125 2019 EFI model
Nobby the Bastard
Harley Gaydar
PostPosted: 09:03 - 17 Nov 2022    Post subject: Re: benelli cutting out Reply with quote
You said 0.8, not 0.08. There's a fuck load of difference.
Sprint ST 1050
WD Forte
PostPosted: 11:46 - 17 Nov 2022    Post subject: Re: benelli cutting out Reply with quote
10 times in fact, the difference between (approx) 3 and 30 thou
It may seem pedantic but when diagnosing faults,describing them and testing/observing, a certain amount pedantry is a good thing.
BTW, 0.08mm inlet and 0.1mm exhaust ( 3 and 4 thou respectively) is the same spec as a YBR 125
Whatever, unless the valve clearances are wildly out of spec
it's all got feck all to do with the actual problem.
bikers smell of wee
adywood45
PostPosted: 17:56 - 18 Nov 2022    Post subject: Reply with quote
Nbby
I'm bad lol i knew what i meant i was reading my feeler gauges and they don't have the 0.08 just 0.8 i wouldn't use a spade to set the gaps at 30 Thou lol. I've tried getting the settings from 3 benelli dealers and they all came back saying they don't 'know i then watched a vid on you tube and the lad set his to 0.06 inlet 0.08 exhaust iv'e checked mine and there at 0.06 inlet is tight but i can push the feeler gauge into the gap exhaust is the same tight at 0.08 i will adjust them so the feeler gauge is a sliding fit .But this isn't the problem I'm chasing and my code reader is about as much use as a chocolate fire guard as thats saying there isn't any codes stored in the ecu which is why i was asking what code reader 777 used.
adywood45
PostPosted: 20:49 - 20 Nov 2022    Post subject: Reply with quote
adywood45 wrote:
Nbby
I'm bad lol i knew what i meant i was reading my feeler gauges and they don't have the 0.08 just 0.8 i wouldn't use a spade to set the gaps at 30 Thou lol. and i haven't said it 10 times either. I've tried getting the settings from 3 benelli dealers and they all came back saying they don't 'know i then watched a vid on you tube and the lad set his to 0.06 inlet 0.08 exhaust iv'e checked mine and there at 0.06 inlet is tight but i can push the feeler gauge into the gap exhaust is the same tight at 0.08 i will adjust them so the feeler gauge is a sliding fit .But this isn't the problem I'm chasing and my code reader is about as much use as a chocolate fire guard as thats saying there isn't any codes stored in the ecu which is why i was asking what code reader 777 used.
adywood45
PostPosted: 11:43 - 26 Nov 2022    Post subject: Reply with quote
It turned out to be the same issue as 777 had head temp sensor i also had a code for the petrol vapour canister so i changed that as well . I found a code reader that would read the codes. I got a OBD2 Code Reader - MS309 for Universal Motorcycles from cmpo chinese motorcycles and the Benelli OBD2 Plug Adaptor (Delphi ECU) from
www.lonelec.com. And i set my valve clearances to 0.06 in 0.08 ex i've done about 100 mile on Ben so far with out it randomly cutting out so i've sorted it at last.Hope that might help some one out.Ady
WD Forte
PostPosted: 19:38 - 26 Nov 2022    Post subject: Reply with quote
Interesting to know it uses a Delphi ecu
I'd read a lot of chinese bikes use that
I don't have a bike to test this for myself but I also read if you turn the ignition on, then off, then back on and wait,
many Delphi ecus will flash out error codes
Edit:
Correction
I have found the file and it says to switch the ignition
on-off on-off-on in rapid succession
and the ECU will flash out a 4 digit code
ten flashes for zero, the rest as you'd assume
You want to try that?
if may help others if this is true
bikers smell of wee
The last post was made 1 year, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.1 - MySQL Queries: 17 - Page Size: 68.25 Kb
