What Grinds my gears archive B
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> Dear Auntie BCF... Goto page Previous  1, 2, 3 ... 129, 130, 131 ... 179, 180, 181  Next
PostPosted: 10:14 - 25 Jan 2023    Post subject: Reply with quote
recman wrote:
blurredman wrote:
no posts exist for this topic Rolling Eyes Crying or Very sad
Oh yes they do
https://i.imgur.com/2kgrzYE.png
blurredman
PostPosted: 13:41 - 25 Jan 2023    Post subject: Reply with quote
Ste wrote:
recman wrote:
Oh yes they do
Cool Cool Cool
recman
PostPosted: 13:44 - 25 Jan 2023    Post subject: Reply with quote
blurredman wrote:
No Sad
Yarp, although I will concede this may not be the last post on the subject.
PostPosted: 13:47 - 25 Jan 2023    Post subject: Reply with quote
Ground and oiled in equal measure today.
My 612 bullet just went for its MOT today and passed with no advisories. However they left the ignition on all morning so the battery was flat as a bannock and I had the iniquity of having to ask them for a jump starter pack.
Thinking about it though, I do have a capacitor kicking about somewhere so I might put a doube terminal on the battery connector and leave the cap in the battery box. Then if it happens again, I can hook up the capacitor to get it started... I wonder if I could leave it connected or if it would drain the battery? Sounds like a question for workshop.
Islander
PostPosted: 14:00 - 25 Jan 2023    Post subject: Reply with quote
In theory, once a capacitor is charged, it should remain so until a load causes it to lose the charge. In reality, nothing's perfect and the capacitor will leak - the spec sheet should give you an idea of this. Some capacitors will hold a massive charge for a frightening amount of time (don't ask me how I know this Laughing ).
You could put some sort of management system onto it so that when the charge drops below a certain amount, it reconnects to the battery until charged and then disconnects. You could also use this to regulate the charge rate.
It might be cheaper and easier to get one of those compact jump starter jobs and either carry it around or leave it mounted on the bike isolated until needed. It'd need a charge periodically but still...
MCN
PostPosted: 14:56 - 25 Jan 2023    Post subject: Reply with quote
Capacitors can Assplode Impressively if overfilled with energy/shorted.
There are fancy lectric devices that go between the positive Post and consumer that disconnect power when battery capacity/stored energy drops to 'just enough to start the hoowur'.
Don't axe me where one could procure such an item.
The caveat with this solution is of course, the more things in a system that can fail means there are more things that can fail. Shocked
Maybe this sort of a doofur...
Victron Battery Protect, 12/24V, 65A, Programmable for Mobile Home and Yacht https://amzn.eu/d/1TIqedC
60 amp should be enough to birl a bike engine over.
Islander
PostPosted: 15:57 - 25 Jan 2023    Post subject: Reply with quote
You should see what happens when a pair of high voltage high capacity electrolytics are connected with the polarity reversed on a 350-0-350 DC supply.
Mount Vesuvius has nothing on it. Laughing
Easy-X
PostPosted: 17:45 - 25 Jan 2023    Post subject: Reply with quote
Probably the smallest, cheapest jump pack would actually be woefully inadequate for jumping a car but fine for a bike.
PostPosted: 20:01 - 25 Jan 2023    Post subject: Reply with quote
You can start a bullet on a square pp3 battery as long as you disconnect it quickly before it trys to charge it.
Done exactrly that on my Jawa 350 which had a field coil alternator and a flat battery. Jumped the pp3 battery onto the brushes and fired it up.
MCN
PostPosted: 16:11 - 26 Jan 2023    Post subject: Reply with quote
What does a PP3 and a woman's A-whole have in common?
You know it's wrong but sooner or later you touch it with your tongue.
PostPosted: 17:58 - 26 Jan 2023    Post subject: Reply with quote
Laughing I did chortle.
Triumph Trophy Launch Edition
M.C
PostPosted: 12:24 - 27 Jan 2023    Post subject: Reply with quote
Speeding ticket, 8am on a Sunday morning, within ~100m of a 40 mph sign Rolling Eyes
LustyLew
PostPosted: 12:36 - 27 Jan 2023    Post subject: Reply with quote
First stage of a root canal on a lateral incisor. The first dental procedure I've had done on my "adult" teeth. Not bad for 42.
Now my nose won't stop running. Not uncommon apparently.
Bloody annoying.
Ribenapigeon
PostPosted: 13:35 - 27 Jan 2023    Post subject: Reply with quote
Squeaky and creaky office chairs.
blurredman
PostPosted: 13:41 - 27 Jan 2023    Post subject: Reply with quote
You should have been able to slow down within 100 miles.
M.C
PostPosted: 14:49 - 27 Jan 2023    Post subject: Reply with quote
Unfunny joke aside this is what I meant:
https://www.bikechatforums.com/files/speed_975.jpg
You can see the detection lines at the bottom.
Ribenapigeon
PostPosted: 15:39 - 27 Jan 2023    Post subject: Reply with quote
Your own fault for not being smart enough to blur out your number plate.
PostPosted: 16:35 - 27 Jan 2023    Post subject: Reply with quote
Apparently, you didn't... Or are you telling us you did it on purpose?
hellkat
PostPosted: 18:13 - 27 Jan 2023    Post subject: Reply with quote
The stupid head-cold which kept me in bed for most of last week is nearly done with me, I almost have my voice back.
But on the way out the door it provided me with a nasty maxillo-sinus infection, for which I blagged some antibiotics from the GP.
M.C
PostPosted: 18:49 - 27 Jan 2023    Post subject: Reply with quote
I generally don't drive looking just past the end of my bonnet.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:04 - 27 Jan 2023    Post subject: Reply with quote
And you didn't notice the camera painted yellow at the side of the road?
Triumph Sprint ST 1050
M.C
PostPosted: 19:30 - 27 Jan 2023    Post subject: Reply with quote
A large van was alongside so no.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:38 - 27 Jan 2023    Post subject: Reply with quote
For the whole 200 yards approaching it that they are visible for?
M.C
PostPosted: 19:45 - 27 Jan 2023    Post subject: Reply with quote
Completely unsighted on my dashcam footage, I had to go on street view to see where the camera was.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:11 - 27 Jan 2023    Post subject: Reply with quote
So, is this a road that you normally drive down or were you anticipating a speed limit that you had come across for the first time?
The last post was made 3 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> Dear Auntie BCF... All times are GMT + 1 Hour
Page 130 of 181
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 136.91 Kb
