So... What oiled your gears today?
Bike Chat Forums Index -> Random Banter Goto page Previous  1, 2, 3 ... 75, 76, 77 ... 101, 102, 103  Next
BanditsHigh
Worse than a woman
PostPosted: 17:34 - 07 Feb 2023    Post subject: Reply with quote
Looking for a 47kg propane bottle for a project, checked on Gumtree and found a few ... contacted one selling at £35 before then finding three at £10 each!!
I got a cryptic message about possibly buying something on Gumtree ... long story short, they wouldn't say who they were or what they were selling ... told them they had lost sale and blocked number ... seems like it was the £35 for one bottle so no loss!
Went to see the other person today, three 47kg propane bottles secured for £30 ... and picked up/delivered by a friend ... result Thumbs Up
hellkat
PostPosted: 23:30 - 07 Feb 2023    Post subject: Reply with quote
A couple of my orchids are about to provide floral satisfaction.
They sit there looking funky but pointless with no flowers for so fucking long ... and then they do the biz and you remember why you bothered to keep them Wub
PostPosted: 01:16 - 08 Feb 2023    Post subject: Reply with quote
Huge ones! You making a stove? You know the butane ones are made of thicker metal because they go in those inside gas fires where the bottle is very close to the burner?
BanditsHigh
Worse than a woman
PostPosted: 09:40 - 08 Feb 2023    Post subject: Reply with quote
Two possible projects ... both to do with wood turning and bubbles in resin ... the reason for the 47kg one is the diameter, it's the biggest available (375mm externally).
Vacuum pot
Simple to make and relatively safe.
This sucks all of the bubbles out of the resin, but tends to foam up so needs to be repeated a few times.
To make ... polycarbonate sheet for the lid and a rubber seal of some sort to go round the edge (so one can monitor what's going on inside) ... add a pressure gauge and two valves (air in and air out).
Pressure pot
More difficult to make and a potential bomb!!!
Squeezes the bubbles down to a size where the human eye cannot actually see them and only needs to be pressurised once (between 40-60 psi).
Using the bottom and top parts of the cylinder, thicken and therefore strength the cut rim of each ... get each as flat as possible and add a big gasket between then ... then large clamps fitted round edge to clamp the two bits together ... usual air in/out valves and a pressure gauge and pressure safety valve.
Why make ...
I can make either with an internal diameter of around 365mm and say 500mm tall ... a 300mm diameter / 300m tall pressure pot is around £240.
So, if I fabricate the extra bits for a pressure pot (rim and clamps) and then get a coded welder to weld it all together, I reckon I'd get a far bigger pot and cheaper as well Thumbs Up
All the best ... Barry
recman
PostPosted: 22:54 - 11 Feb 2023    Post subject: Reply with quote
All this week at work I R been doing taste tests.
Specifically supermarket own brand tinned tomato soup.
I was going to do a list and give ratings but they're all the bloody same as Heinze.
Gears oiled because the Bramwells Aldi brand at 57p is every bit as good as Heinze at £1.70.
B1N
PostPosted: 12:33 - 12 Feb 2023    Post subject: Reply with quote
My Wifey said 'did you originaly receive them as Valentine gifts?'
She has one that flowers on her birthday. Wub
to v or not to v
PostPosted: 00:05 - 13 Feb 2023    Post subject: Reply with quote
cheaper food products often have far less healthy ingredients i believe.
its old and fat, but its a damned good ride. the bikes not bad either.
hellkat
PostPosted: 02:15 - 13 Feb 2023    Post subject: Reply with quote
How lovely Cool
Easy-X
PostPosted: 18:44 - 13 Feb 2023    Post subject: Reply with quote
Egg on toast for tea Drooling
Ribenapigeon
PostPosted: 18:31 - 14 Feb 2023    Post subject: Reply with quote
Someone else has noticed the Grammys is s#1te https://youtu.be/1Ga6L_VJrBY
Ribenapigeon
PostPosted: 18:37 - 14 Feb 2023    Post subject: Reply with quote
BanditsHigh wrote:
Bloke project
To make a decent vaccum flask then a good stock pot with the handles removed would probably do. Its getting a thick bit of pilycarbonate thats the tricky part.
Im curious, are you one of these retired dudes who takes up wood turning and spends the whole year making Christmas presents?
BanditsHigh
Worse than a woman
PostPosted: 21:11 - 15 Feb 2023    Post subject: Reply with quote
Ribenapigeon wrote:
BanditsHigh wrote:
Bloke project
To make a decent vaccum flask then a good stock pot with the handles removed would probably do. Its getting a thick bit of polycarbonate that's the tricky part.
I'm curious, are you one of these retired dudes who takes up wood turning and spends the whole year making Christmas presents?
Bought the lathe about 8 years ago, not done a lot of work so far ... but that all changes this year as I love doing it and it'll be a way of making a little extra cash (once I'm good enough).
With regards vacuum pot (a flask is for keeping liquids warm or cold Wink) ...
BUY ... Vevor (stainless) / 280mm diameter by 300mm tall (external) / 19L volume / cost £95
MAKE ... 47kg propane tank (steel) £10 / 375mm diameter by 500mm tall (external) / 55L volume / cost around £100-£150 (depending on cost of polycarbonate or acrylic sheet).
Same height as the Vevor would be 33L, but the 375mm diameter compared to 280mm allows me to do larger pieces Twisted Evil
P.S. Can get a 400mm by 400mm by 10mm thick piece of PC for £27
Ribenapigeon
PostPosted: 21:53 - 15 Feb 2023    Post subject: Reply with quote
Good luck. Personally I have left a trail of unfinished and not even started projects behind me in life. For instance I made a really cracking solid wood working bench a few years ago which is now what looks like the last resting place for the half dismantled remains of a PUCH five speed i started renovating during lock down.
Easy-X
PostPosted: 00:51 - 16 Feb 2023    Post subject: Reply with quote
I have a few like that. Thankfully I don't get round to them as paying jobs get in the way Smile I've a new bridge for my electric ukulele I've been meaning to fit for.... uumm... the last year Shifty
BanditsHigh
Worse than a woman
PostPosted: 07:14 - 16 Feb 2023    Post subject: Reply with quote
Pft ... amateurs ...
1) Garage, built about 15 years ago ... still haven't finished off edge of roof or fitted guttering and still no power to it (cable is there, just not connected at either end), no sockets etc.
2) Central heating boiler removed about 13 years ago, new boiler bought about 3 years ago ... still in box!
3) Homemade 18" bandsaw ... started 6 years ago ... still to make guides, fit table properly etc (still not in use) .... may not finish it as I have a better design!
4) Bathroom taken apart about 3 years ago (back to bare brick) ... new floor installed and two walls plastered, loo flushed with bucket ... in the process of doing it now (steampunk'ish look) Thumbs Up
5) Stepper motors and drivers bought about 6 years ago to build CNC mill, a couple of years ago a spindle and VFD ... just bought a shed load of extrusion, guide rails etc so will be building this year (as well as making it a mill/laser combo).
I now have lots of spare time, so hopefully will get at least some of them done Laughing
pepperami
PostPosted: 09:43 - 17 Feb 2023    Post subject: Reply with quote
It’s a funny thing?
It almost went into “What Grinds My Gears”.
My I-pad threw a wobbly yesterday Mad and refused to start up when I switched it on.
All I could get was a black screen with a tiny spinning whirly icon in the centre.
No matter how many times I tried to turn it off again, it stayed black with the spinning icon.
I tried pressing all sorts of buttons, nothing happened?.
This went on from seven in the morning until eleven at night when it finally appeared to have run out of battery charge.
More out of desperation than anything else, I plugged it in to recharge.
At last something happened, I got a charging icon and an Apple icon.
Lo & behold, this morning my I-pad appears to have righted itself.
And added a few updates?
I’m just glad to have my I-pad working again. Smile
Ribenapigeon
PostPosted: 17:42 - 17 Feb 2023    Post subject: Reply with quote
Or, give up.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:20 - 18 Feb 2023    Post subject: Reply with quote
Got reminded of this.
https://www.youtube.com/shorts/F6a2M2dY3BA
Sprint ST 1050
Nobby the Bastard
Harley Gaydar
PostPosted: 21:56 - 18 Feb 2023    Post subject: Reply with quote
Boring for that? You really are an obnoxious wanker, Dave.
Sprint ST 1050
Easy-X
PostPosted: 23:51 - 18 Feb 2023    Post subject: Reply with quote
Nobby the Bastard wrote:
Only kids of a certain age laugh like that Smile
Easy-X
PostPosted: 13:26 - 19 Feb 2023    Post subject: Reply with quote
Driving my car...
Red line is around 5,500~6000rpm whereas my bike's just getting going at that point! I checked and my Fabia has identical (on paper) bhp to the XSR Thinking But that's pretty much "this orange is the same diameter as that apple" given the errr.... slight difference in torque Smile
to v or not to v
PostPosted: 20:19 - 20 Feb 2023    Post subject: Reply with quote
used Merekat site for insurance quotes and received one for about half the price of my latest ins quote Thumbs Up
£100 compared to £197.
quite a shocking margin really.
Ribenapigeon
PostPosted: 20:23 - 20 Feb 2023    Post subject: Reply with quote
I just used go compare and got about the same quote for the coming year as last year but with parking on the street rather than on my own property and yet much less secure. I really wonder if its all just made up anyway.
Easy-X
PostPosted: 09:27 - 21 Feb 2023    Post subject: Reply with quote
We'd have to hear from an an underwriter but I would imagine if they had a book to fill up their initial appetite for risk is higher. Swing round to the next year and they start handing out obnoxious quotes to the fringe punters.
to v or not to v
PostPosted: 23:15 - 24 Feb 2023    Post subject: Reply with quote
tonight its Baileys Irish cream.
The last post was made 1 year, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Page 76 of 103
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.59 - MySQL Queries: 17 - Page Size: 142.55 Kb
