Recommend me a dash cam?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3
BenR
PostPosted: 23:03 - 27 Mar 2023    Post subject: Reply with quote
Just as an update the seller was very quick to respond. Apparently the DVR only records in a loop (I quote) "This function ensures that the memory card will never be full and will not cause the recording to fail. Loop recording is also used to protect the performance of the camera".
TravisBickle
Formerly known as
DUCAUDI
PostPosted: 08:21 - 28 Mar 2023    Post subject: Reply with quote
One of us would have pointed this out to you sooner, but you said you got a 256GB SD card?
Yes dash cams are, unlike action cams, designed to record continually in a loop, once the card is full it will constantly overwrite the oldest file as you go along to ensure recording is never interrupted. The idea is that 99% of the footage you capture is going to be binned, so you only save/lock the relevant file(s) after an incident or pull the card.
But you also said your rides weren't being captured in full. A 256GB SD card should be enough for in excess of 24 hours of recording. Are you sure you haven't got a duff/fake SD card?
I done a lot of research into this and without question, this is currently hands down the best SD card for dash cams and it's not expensive:
https://www.amazon.co.uk/dp/B0B1J75QW2?psc=1&ref=ppx_yo2ov_dt_b_product_details
They do smaller capacities - you need to check with your device what the maximum capacity card it will support.
Bear in mind that SD cards gradually wear out over time with constant rewriting to the card. It's wise to use a high endurance model specifically designed for CCTV / dashcam use.
2007 Yamaha FZ1 S Fazer
2021 Honda CMX500 Rebel S
2016 Triumph Tiger 1050 Sport
BenR
PostPosted: 23:05 - 29 Mar 2023    Post subject: Reply with quote
Hi thanks the card is a genuine Sandisk one I got it in Currys. How often do you replace yours? Thanks for the help.
TravisBickle
Formerly known as
DUCAUDI
PostPosted: 06:38 - 30 Mar 2023    Post subject: Reply with quote
The heavy duty / endurance Samsung I've got in mine is guaranteed for 140,000 hours of continuous recording. So that's 16 years. So the answer to your question is - probably never!
They tend to only quote that figure on endurance cards and it's impossible to get that data on standard duty cards however even if it was only one 10th you'd expect it to last at least a year and a half!
Have you got the correct speed class for the resolution you're recording at?
Hong Kong Phooey
PostPosted: 13:58 - 30 Mar 2023    Post subject: Reply with quote
I suspect the loop recording limit is 10 min. So a 2GB card would be plenty.
Some support loop until full card, but the generic Chinese ones tend to loop the same file.
TravisBickle
Formerly known as
DUCAUDI
PostPosted: 18:43 - 30 Mar 2023    Post subject: Reply with quote
I've never seen a dashcam that just does a loop recording over the same file. In my experience they've always filled the card up and then continually record over the oldest file.
I've looked up the make and model website and it says it does loop recording and supports up to 256GB cards:
https://blueskysea-inc.com/dv988-p00102p1.html
However it doesn't go into details about what write speed is required of the SD card.
Like I said before - if you're not getting a complete ride saved on a 256GB card, there's definitely something wrong somewhere!
Assuming the hardware isn't faulty my guess would be (as we've established it's not a fake card) that maybe the card does not meet the required record speed for the device, or is maybe on the cusp of what the card can handle and is tripping out occasionally and powering the unit down if it's trying to write to the card and the card cannot keep up intermittently once the cache is saturated (if, indeed, SD cards even have a cache, I'm not sure they do)?
Your model has front and rear 1080P @ 30fps. Anyone in here know what write speed is required for dual 1080P/30?
Does your SD card have any of the following markings on it?
C2
C4
C6
C10
U1
U3
V6
V10
V30
V60
V90
Hong Kong Phooey
PostPosted: 15:02 - 04 Apr 2023    Post subject: Reply with quote
If it can save one file, the card should be fine. I think it's a setting, or purchased the wrong cam. Unless the card is a 1GB faked up to be 256GB.
There's a free tool to check SD card true capacity vs the reported/labelled capacity, fakes are prolific on ebay.
E.g. H2TESTW
https://www.maketecheasier.com/check-sd-card-speed-capacity/
BenR
PostPosted: 00:33 - 17 Apr 2023    Post subject: Reply with quote
C2
C4
C6
C10
U1
U3
V6
V10
V30
V60
V90
Sorry for the late response. I'll get it out tomorrow & check for those numbers you posted. The thing that's confusing me is that when I first installed the card it worked/recorded fine the only thing I've changed is the amount of time on the loop, 1min to 10 min. Again thanks for the help.
The last post was made 1 year, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.67 - MySQL Queries: 17 - Page Size: 63.1 Kb
