Ninja 250R chain adjustment
CarlW12
PostPosted: 10:40 - 20 Apr 2023    Post subject: Ninja 250R chain adjustment Reply with quote
Hi All,
Recently purchased a 2011 Ninja 250R which I’m loving at the moment. I’ve noticed my chain is slightly slack so wanted to have a go at adjusting it
However, after removing the pin, I can’t seem to loosen the axel nut. It seems as though it budged slightly but won’t seem to give. No idea if the previous owner has overtightened it slightly or not..
I used a torque wrench to check the toque was correct just in case, and then decided to leave it to ask for advice here first
Is there any specific tools that are best for loosening axle nuts I should look at? I was just attempting to use a spanner which I’m assuming might be wrong Confused Laughing
Many thanks
Carl
Carl
A2 Licence Holder
Previous bikes: YBR; GPZ500S; Kawasaki Ninja 250R
Evil Hans
PostPosted: 10:53 - 20 Apr 2023    Post subject: Reply with quote
You might need a socket with a fairly long breaker bar, and just hold the other side with a spanner
https://youtu.be/PxZCoYq2j5w
doggone
PostPosted: 11:32 - 20 Apr 2023    Post subject: Reply with quote
Usually the rather crappy ring spanner and extension tube(?) included in tool kit - if present - is just about adequate for tightening and undoing if they haven't overdone it.
Much better to use your own socket or good ring spanner if you have them.
grr666
PostPosted: 11:46 - 20 Apr 2023    Post subject: Reply with quote
It is supposed to be slightly slack to allow for suspension movement. How slack are we talking?
CarlW12
PostPosted: 18:42 - 20 Apr 2023    Post subject: Reply with quote
Thanks for your responses. I think that getting my own sockets etc will be best for the job by the looks of it then Thumbs Up
The slack is only slightly over, nothing too crazy. I could leave it a little longer before adjusting which would give me time to get some tools etc together. I’m fairly new to bike mechanics so just learning the ropes with the manual at the moment - want to take good care of my bike and make sure she rides well!
Just hoping that the old owners haven’t tightened the nut too much that I’ll struggle to loosen it off.. fingers crossed
Carl
A2 Licence Holder
Nobby the Bastard
Harley Gaydar
PostPosted: 18:58 - 20 Apr 2023    Post subject: Reply with quote
You do know the difference between righty-tighty and lefty-loosey don't you?
Only asking cause you just admitted to having no tools...
CarlW12
PostPosted: 19:27 - 20 Apr 2023    Post subject: Reply with quote
Yep, was definitely trying to loosen it correctly Thumbs Up
Carl
A2 Licence Holder
PostPosted: 19:57 - 20 Apr 2023    Post subject: Reply with quote
I'd be using a 1/2" drive breaker bar and socket or a big ring spanner. I think they'll be 24mm.
You can buy big ring spanners with 22 and 24mm on opposite ends which should be good for both the front and rear wheel nuts. I've seen me slide a bit of pipe over the end to get more leverage if required.
I'd go with a 6-sided socket or ring if you can.
EDIT: If you have a torque wrench, you must already have the socket so I'd be buying a breaker bar. Use the torque wrench to put the nut back on again, do not use it to undo the nut, that's not what they are for.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:20 - 20 Apr 2023    Post subject: Reply with quote
There's no point trying to use a torque wrench to check it's done up to the correct torque when its so tight the damn thing will click because its already too tight.
CarlW12
PostPosted: 21:47 - 20 Apr 2023    Post subject: Reply with quote
Ok, I’ll have a look around for a big 6 sided spanner or breaker bar then to use for the future. In hindsight, the spanner I was trying to use didn’t seem to have enough grip and was smaller in size… no wonder it wasn’t loosening Laughing
Carl
A2 Licence Holder
Bhud
PostPosted: 22:33 - 20 Apr 2023    Post subject: Reply with quote
You need a good quality 6-sided socket of the correct size, plus a breaker bar. The breaker bar doesn't matter but the sockets to buy are Halfords Advanced, Bahco, etc. On a Japanese bike it will be a 27mm or 30mm or 32mm or something equally odd. You only need to buy that socket once.
In a pinch, you can get away with alternative tools, but these may chew up your nut, so you use them in an emergency only (I've got something like that as a part of my emergency/shakedown toolkit).
In general, you do not need to spin off an axle nut with an impact driver. It won't have that much torque. A very ancient swingarm spindle nut may need an impact driver. Same with an old front sprocket. But an axle nut, you just need to have a reasonable length breaker bar, or go to the gym.
MCN
PostPosted: 22:36 - 20 Apr 2023    Post subject: Reply with quote
I disagree.
If you have already bought one, lose it and then have to buy another. Embarassed
redeem ouzzer
PostPosted: 11:39 - 21 Apr 2023    Post subject: Reply with quote
Ha ha ha at your age son I was rebuilding race bike engines in my shed, not messing around trying to adjust the chain on a 250.
Kids eh? Rolling Eyes
Be a REAL MAN!
Easy-X
PostPosted: 21:41 - 21 Apr 2023    Post subject: Reply with quote
Hah! You think chain slack is tricky try getting the correct tension on a belt drive.
CarlW12
PostPosted: 23:24 - 21 Apr 2023    Post subject: Reply with quote
That’s great to know pal, but I’m not a kid, I’m 25… I came here looking for genuine advice, not to be belitted. We all start somewhere…
Thanks to those who gave decent advice anyway Thumbs Up
Carl
A2 Licence Holder
MCN
PostPosted: 23:28 - 21 Apr 2023    Post subject: Reply with quote
I beg your pudding Sir.
It is customary to be belittled on BCF whether you are six or sixty.
CarlW12
PostPosted: 23:37 - 21 Apr 2023    Post subject: Reply with quote
I’m beginning to notice that Laughing
Carl
A2 Licence Holder
Robby
Dirty Old Man
PostPosted: 08:50 - 22 Apr 2023    Post subject: Reply with quote
The right way to undo it is with a breaker bar.
The wrong (but satisfying) way to undo it is with an 18v impact driver.
This is a great excuse to buy an impact driver. If you do a lot of DIY, you'll be glad to have one. Nothing like it for driving screws into walls.
If, after you tension the chain, the gearchange feels very tight and hard - like it's going to bruise your toes on upshifts - the chain is too tight. A little loose is better than a little tight.
MCN
PostPosted: 18:33 - 22 Apr 2023    Post subject: Reply with quote
I just tweeked the chain slack on my S1000RR. The axle bolt has flat's on the head on the RH end and the nut is on the LH side. There is a torque for the nut which seems low for the dimension of the axle/bolt (19-20mm) but OEM requires the nut to have medium strength Loctite Thread Lock applied to the thread before making it up. Then torque to 100nm.
I did it this way everytime I adjust the chain.
My point, the nut is always ridiculously Tight AF to loosen on the next adjustment adventure.
Maybe someone applied thread lo Wink ck.
MCN
PostPosted: 19:39 - 23 Apr 2023    Post subject: Reply with quote
No post exits.
Mad
The last post was made 2 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.99 - MySQL Queries: 16 - Page Size: 109.59 Kb
