| PotatoHead202... |
 PotatoHead202... Scooby Slapper
| Nobby the Bastard |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 18:35 - 10 May 2023 Post subject: |
Ok, there's rather more to it that a Japanese bike clutch. As you know, you have a semi-automatic clutch release which from your picture looks pretty close to properly set-up.
https://lh3.googleusercontent.com/pw/AJFCJaW6kqUILsZX4_n4Dul6JXnMYYoPpLl-apWRR9rjkfZzEEdvRecAwUGNnl9v_XwX8nsKw0TfNKruRKmSZL-UwjddUKXP2EUZ1fOkt_qQ3913_upqgJQeU8snNUdWdWWoK-9AxUGA9F1G3qsiKrdO_u8f=w1060-h678-s-no
You need to set the gear lever actuated portion of it first so the end of the mechanism is evenly in the notch on the end of the gear change shaft and starts moving a similar amount if the gear shift is moved up and down and has enough tension on the pushrod to fully disengage the clutch at the maximum travel of the gearshift.
Once you have that set, you then set the tension in the cable so it has the requisite level of slack. This can be a fiddle because it uses a solderless nipple at the engine end. They are prone to slipping and if it was pinched in a certain place for a long time, it has a tendancy to slip back there. They are also prone to breaking/fraying at that nipple.
So if that was all set up properly, the first thing I'd check is if it's crabbing when you use the clutch via the gear lever as well as when you use the hand lever by keeping your foot fully up or down on the gearshift after selecting a gear. This should do the same job as holding the clutch in.
If it's not crabbing when using the foot clutch, the problem is clutch cable tension usually due to slipping or fraying at the bottom nipple.
If it is crabbing when using the foot clutch, the problem is either adjustment at the outer clutch mechanism or expansion of the clutch stack or just plain ordinary bedding-in. If the plates were dry for a long period, they could well have expanded once properly soaked in oil again. In any case, I'd probably just readjust the mechanism before diving in further. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| PotatoHead202... |
 Posted: 11:37 - 12 May 2023 Post subject: |
| stinkwheel wrote: | Ok, there's rather more to it that a Japanese bike clutch. As you know, you have a semi-automatic clutch release which from your picture looks pretty close to properly set-up.
If it is crabbing when using the foot clutch, the problem is either adjustment at the outer clutch mechanism or expansion of the clutch stack or just plain ordinary bedding-in. If the plates were dry for a long period, they could well have expanded once properly soaked in oil again. In any case, I'd probably just readjust the mechanism before diving in further. |
Thank you.
Yes, that makes sense now. So effectively (without the cable being used) when the gear lever is pressed fully down it will engage 1st gear but fully disengage the clutch? When the lever is returned to it's central position the clutch will be engaged?
THEN adjust the clutch cable? Yes, it seems like it's slipping in it's socket. Just a bloody screw to hold it in place. ____________________ Suzuki V Strom 1050XT, Honda CBF500 ABS, |
| PotatoHead202... |
 Posted: 16:08 - 16 May 2023 Post subject: |
The clutch cable on my Jawa used to break regularly but it's not so much of a pest because of the gear lever clutch mechanism. With practice, you can ride it without touching the clutch lever at all leaving your left hand free to scratch your arse with. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 3 years, 38 days ago. Instead of replying here, would creating a new thread be more useful? |
