ZX6R J1 (year 2000) fork oil change - Haynes manual fail
Fullers1845
PostPosted: 16:12 - 01 Jun 2023    Post subject: ZX6R J1 (year 2000) fork oil change - Haynes manual fail Reply with quote
I'm in the process of getting my wife's uncle's ZX6R back on the road.
But in the routine servicing bit of the Haynes manual, for fork oil change it says 'refer to suspension/bodywork chapter 6 blah blah', which when you look at, unhelpfully states 'refer to chapter 1 routine servicing... Middle Finger
So assuming the seals are still ok (can't see any evidence they are not) it's basically a case of removing each leg, tipping the oil out then refilling to the specified level?
WD Forte
PostPosted: 16:21 - 01 Jun 2023    Post subject: Reply with quote
This page says add 500ml per leg if changing the oil
or 588ml per leg after rebuild
https://www.whitedogbikes.com/whitedogblog/zx6r-ninja-g-specs/
bikers smell of wee
Fullers1845
PostPosted: 16:43 - 01 Jun 2023    Post subject: Reply with quote
Ah, makes sense, shame the bloody Haynes doesn't have the procedure. I assume it's just the case of removing top seal and pouring the stuff out, as there isn't a drain plug anywhere.
Kawasaki Jimbo
PostPosted: 17:44 - 01 Jun 2023    Post subject: Reply with quote
https://www.kawiforums.com/threads/fork-seal-replacement.99425/
https://www.bennetts.co.uk/bikesocial/news-and-views/advice/bike-maintenance/replace-fork-seals-oil-bushes-diy-motorcycle-maintenance
jeffyjeff
PostPosted: 20:07 - 01 Jun 2023    Post subject: Reply with quote
If you've never changed fork oil before, don't be shocked at how nasty the oil looks that comes out of your forks. Dark color with micro metallic sheen is normal, and it gets that way in short order. Personally, I prefer to flush out all the old stuff as best I can. Fork oil is expensive. I've used ATF as an inexpensive flushing fluid without adverse effect. Hang the forks upside down overnight to completely drain all the fluid before filling. Use new o-rings on the fork caps, if available.
to v or not to v
PostPosted: 18:55 - 02 Jun 2023    Post subject: Reply with quote
the old oil has quite an interesting odour too.
Moto Guzzi V7.
PostPosted: 21:22 - 02 Jun 2023    Post subject: Reply with quote
Oh god, yes it does. I'd forgotten that as it's so long since I'd done the job.
Triumph Trophy Launch Edition
Fullers1845
PostPosted: 12:28 - 05 Jun 2023    Post subject: Reply with quote
Cheers guys, I'll let you know how it goes.
Currently refurbishing the horrible 6 pot calipers...
The last post was made 3 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.05 - MySQL Queries: 16 - Page Size: 58.74 Kb
