Author |
A100man |
![](images/spacer.gif) A100man World Chat Champion
![](images/avatars/1652104702547c811d3c10a.png)
Joined: 19 Aug 2013 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_8.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 11:08 - 21 Jun 2023 Post subject: |
![](images/spacer.gif) |
My (bodgers) course of action would be as follows.
Remove piston from con rod.
Measure piston clearance, if OK (in spec) rub off any high spots on the piston with wt and dry
Buy new rings and gap them correctly
Fit new rings and button it up
Run carefully for a couple of hundred miles before I tries to wring the neck of the blighter. ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
Back to top |
You must be logged in to rate posts![](images/spacer.gif) |
![](templates/standard/images/spacer.gif) |
MCN |
![](images/spacer.gif) MCN Super Spammer
![](images/avatars/3860443645614045a93bd7.jpg)
Joined: 22 Jul 2015 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_1.gif)
Back to top |
jeffyjeff |
![](images/spacer.gif) jeffyjeff World Chat Champion
![](images/avatars/22722826049103edcd73.jpg)
Joined: 02 May 2020 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_7.gif)
Back to top |
A100man |
Back to top |
stinkwheel |
![](images/spacer.gif) stinkwheel Bovine Proctologist
![](images/avatars/505686820530d1f8090151.png)
Joined: 12 Jul 2004 Karma : ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_2.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 12:47 - 21 Jun 2023 Post subject: |
As I remember there was an issue just after you built this engine too with an exhaust leak, shitty fuel in the tank and a leak at the inlet manifold where it was popping, backfiring and stuttering after a cold start.
Bet that's when this happened. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
PotatoHead202... |
![](images/spacer.gif) PotatoHead202... Scooby Slapper
Joined: 10 Feb 2020 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_0.gif)
Back to top |
PotatoHead202... |
Back to top |
Nobby the Bastard |
![](images/spacer.gif) Nobby the Bastard Harley Gaydar
![](images/avatars/181183627654e6302043e79.jpg)
Joined: 16 Aug 2013 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_8.gif)
Back to top |
PotatoHead202... |
Back to top |
PotatoHead202... |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 20:39 - 21 Jun 2023 Post subject: |
jeffyjeff wrote: | A100man wrote: | My (bodgers) course of action would be as follows.
Run carefully for a couple of hundred miles before I tries to wring the neck of the blighter. |
+1 here.
The condition of your cylinder kit is likely the result of ham-fisted throttle control during break in. Two stroke engines run much hotter cylinder temperatures than four strokes, and it is generally advisable to intersperse cool-down periods between intervals of full throttle operation during break in.
The piston comes to a dead-stop at TDC and BDC. Under prolonged full load operation, the rings can get so hot that at TDC during the momentary stop between compression and power, the rings momentarily weld to the cylinder wall. Flywheel momentum breaks the weld, and the resulting damage scores the piston and cylinder wall releasing more debris to accelerate the damage. The piston does not need to "seize" in the bore for the damage to occur.
The scored piston rings clearly indicate that this has happened.
Personally, I think that A100man is dead on. Clean up the piston with 240 grit wet-dry sandpaper, fit new rings, and run in at 25:1 petrol-oil ratio. Use the best quality two stroke oil you can find. Oil formulated for chainsaws and outboard motors may not stand up to the rigors of your CZ175 at full load. |
Last time I ran one in was 15 years ago on an RS125 without any issue. Could this be a result of timing slipping and poor running in? Yet I'm also getting mixed messages with many saying 33:1..... ____________________ Suzuki V Strom 1050XT, Honda CBF500 ABS, |
Back to top |
Nobby the Bastard |
Back to top |
stinkwheel |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 21:08 - 21 Jun 2023 Post subject: |
If it has low compression, it's not going to suck fuel in properly, or transfer that fuel into the combustion chamber. If it wont blow your thumb off the sparkplug hole, it wont suck petrol in. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
PotatoHead202... |
Back to top |
Robby |
![](images/spacer.gif) Robby Dirty Old Man
![](images/avatars/5106db863f1f21bddb59d.jpg)
Joined: 16 May 2002 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_8.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 14:37 - 22 Jun 2023 Post subject: |
oh, it's another thread where the full story gets drip-fed.
If you ask for help diagnosing a thing, people are going to concentrate on the thing and assume that everything else works. In this case, I would assume that the fuelling and timing is OK, so the problem has come from the rebuild.
From your new information, the only thing to say for sure is that your engine got hot. It could be a problem inside the carb, it could be an air leak, it could be parts that don't fit, it could be timing going all over the place.
Also, 25:1 sounds like too much oil to me. Best to look around some model specific forums to find out what people are using with modern oil. Too much 2-stroke oil means less petrol, which can lean it off a touch. Not enough to cause the damage here, but simply adding more oil for peace of mind is not a great tactic. |
Back to top |
PotatoHead202... |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 16:10 - 22 Jun 2023 Post subject: |
Robby wrote: | oh, it's another thread where the full story gets drip-fed.
Fuck me, I found this out yesterday so updated the thread yesterday - what do you want me to do?
No wonder this forum is as dead as the bike currently is. ____________________ Suzuki V Strom 1050XT, Honda CBF500 ABS, |
Back to top |
Easy-X |
![](images/spacer.gif) Easy-X Super Spammer
![](images/avatars/1682206356567bfbe6b584.jpg)
Joined: 08 Mar 2019 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_3.gif)
Back to top |
Bhud |
![](images/spacer.gif) Bhud World Chat Champion
Joined: 11 Oct 2018 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif)
Back to top |
A100man |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 23:28 - 22 Jun 2023 Post subject: |
Easy-X wrote: | You'd probably go for a higher oil to petrol ratio breaking in a new piston/barrel like wot this was. |
Not a good idea, Robby makes a fair point that to much oil will lean out the fuel/air mixture an lead to hotter running. Just stick to manufacturers guide ____________________ Now: A100, GT250A, XJ598, FZ750
Back to top |
stinkwheel |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 08:18 - 23 Jun 2023 Post subject: |
Does it not have an oil measure cup in the fuel cap with the ratios stamped on?
As above, I think the piston is saveable, the rings seem shot. Bore probably just needs a hone.
Although what it almost certainly actually needs is the barrel and piston taking to someone who does rebores and the bore checking to make sure it's a) Round. b) Paralell and c) The correct diameter all the way along. Prior experience tells me it could be oval and/or tapered and/or the wrong diameter.
You can kind of do a lot of this with feeler guages and measuring ring end gaps at different points but it's much better done with a bore-guage. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
stinkwheel |
Back to top |
lingeringstin... |
![](images/spacer.gif) lingeringstin... Spanner Monkey
Joined: 01 May 2014 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_1.gif)
Back to top |
Easy-X |
Back to top |
stinkwheel |
Back to top |
PotatoHead202... |
Back to top |
