What have you done to your bike today?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 42, 43, 44 ... 57, 58, 59  Next
Nobby the Bastard
Harley Gaydar
PostPosted: 12:30 - 19 Aug 2023    Post subject: Reply with quote
if it was a piston, use it as an ashtray. Gudgen pins can make a nice keyring.
Chains (cam and starter) can make interesting jewellrey.
I'd probably sling the stator straight in the recycling.
Triumph Sprint ST 1050
hellkat
PostPosted: 12:40 - 19 Aug 2023    Post subject: Reply with quote
yeah I had a smashed-piston ashtray - that was my first bike misdemeanour way back in 1998-ish Laughing I am a long-standing member of the Piston Broke Club Laughing
PostPosted: 14:17 - 19 Aug 2023    Post subject: Reply with quote
hellkat wrote:
Well I picked the Suzuki up, chatted with a few old coots whilst waiting for the MOT, nothing remotely marriageworthy, although their guy that does Harleys is a Kiwi (!) so I had a bit of a nag with him, but he's going home soon Rolling Eyes ...
Anyway its so sunny I am tempted to go straight back out for a ride. Thinking
The old unworthy stator (which was returned to me) was all black and grim-looking, the mechanic says its *supposed* to be a sort of goldish colour. At least now I know what one looks like Rolling Eyes
What do you guys do with old parts when you get given them back by the garage?
Throw them in the grage's wheelie bin on the way out Smile
He's right though the coils in the stator should be golden cloured, it's the colour of the 'varnish' they use to coat the coils so the little wires don't rub together and short out. If they were black/burnt/dull grey then the stator is shorted internally.
A100man
PostPosted: 08:59 - 20 Aug 2023    Post subject: Reply with quote
Unwind the copper and smelt it down to make earrings - although it will turn your skin green.
that or the bin
A100man
PostPosted: 09:00 - 20 Aug 2023    Post subject: Reply with quote
stinkwheel wrote:
A100man wrote:
Shocked Indian Balls?
SKF from simply bearings. Done about 6,000 miles on them.
Blimey..
Easy-X
PostPosted: 14:35 - 20 Aug 2023    Post subject: Reply with quote
Update on the R125, took the top end off today...
https://i.imgur.com/L9K1SjH.jpg
Buff out? And the piston might need new rings...
https://i.imgur.com/Kq4kk2N.jpg
Haven't done a leak test but the top end will probably clean up okay:
https://i.imgur.com/1o6Z6t7.jpg
New barrel + piston set made out of finest Chinesium is ~£80. Probably good enough to rinse a few more miles out of the bike till the kid does his A2.
A100man
PostPosted: 13:26 - 21 Aug 2023    Post subject: Reply with quote
Errm - you might want to take care not to let any more crap fall into the crankcase..
blurredman
PostPosted: 14:56 - 21 Aug 2023    Post subject: Reply with quote
https://scontent-lhr8-1.xx.fbcdn.net/v/t1.15752-9/365899193_2722637431212226_3356389977042070576_n.jpg?_nc_cat=107&ccb=1-7&_nc_sid=ae9488&_nc_ohc=OXbrWUQnT4YAX_rMtki&_nc_ht=scontent-lhr8-1.xx&oh=03_AdT4vXYs4Pd1N4GehNJ2qlqexNhFf_MnbqdFVVNVGQK-6A&oe=650AFEFD
Got my brother's TS250 engine in for re-build. Been off the road since late 90's due to a big end failure. Pretty much was all original except one mains bearing was a koyo and a seal was replaced. This is putting it back together somewhat after crankshaft rebuild. Just needs a rebore though and we can install onto the bike - gearbox teeth mint!
We did have to lap in a replacement clutch side taper though with valve grinding paste and using blue dye to determine full coverage. The one on the engine was not at all trustworthy.
He only bought it to get around ULEZ. Probably will keep it though.
Easy-X
PostPosted: 21:20 - 22 Aug 2023    Post subject: Reply with quote
Some good news on the abused R125. If you recall the bottom engine mounting bolt would not budge so we ended up cutting the ends off to drop the engine out of the frame.
I reasoned that most likely corrosion starts from the outside and works its way along the bolt so the old fella drilled out just an inch of the bolt from either side, hit it with a drift and it pinged out Smile
A100man
PostPosted: 09:50 - 23 Aug 2023    Post subject: Reply with quote
amazing that still no-one bothers to copperslip these bolts on initial assembly
Kawasaki Jimbo
PostPosted: 17:33 - 25 Aug 2023    Post subject: Reply with quote
Years ago I replaced the R1’s boring black hugger with a cheap blue version. The colour was never quite right and it then faded unevenly, so today I’ve resprayed it. Like previous attempts at painting, the lacquering stage seems to be the most tricky. I guess being the final stage, it would be. However, I cannot get a deep, smooth shine. I recall that when I supplied RS Bike Paints products to a local sprayer who did my Kawasaki’s wheels and swingarm he didn’t approve, saying it was going on ‘like wood lacquer’. I took him to mean it was too thick but I don’t know for sure. In the end he used his own. Today I ignored the advice to apply ‘light coats’ and made the last one a thickie, although maybe my interpretation had been too literal. Anyhow, this will do. It has a slightly grainy texture but that might be because I sprayed a base primer over the existing paint and did no sanding. It’s much better than it was.
https://i.postimg.cc/SR3XznTy/IMG-1116.jpg
https://i.postimg.cc/NMjnMW8B/IMG-1119.jpg
https://i.postimg.cc/MTd20HCQ/IMG-1126.jpg
that_impulse_guy
PostPosted: 13:24 - 27 Aug 2023    Post subject: Reply with quote
not today, but this friday sent bike for new tyres and MOT...the first MOT this century...passed!
got on bike and drove straight to ULEZ testing centre for tailpipe emissions test...passed..0.13NOX...
that makes it euro3 compliant, and ULEZ compliant.
my 1987 4pot 4stroke.
was only able to get this all done because passed mod2 on tuesday.
Its been a busy week.
Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R
hellkat
PostPosted: 18:15 - 28 Aug 2023    Post subject: Reply with quote
Now that it has a fresh MOT I took the Suzuki out for a stonking great ride down to Wiltshire for the weekend, including a little pootle alongside the Avon through "the Woodfords" into Wilton. Cool
My mate helped me get it onto the centre stand and patiently oiled the chain with a brush Laughing
Came home back down the M3 this arvo, bit of weaving and dodging through traffic but it hadn't built up at that point ... stopped off once on the A316 to visit the inlaws at Twickenham Cemetery and then straight across town to home, hardly any traffic in town too. Yay!
Pushed it well beyond 7500 revs i.e., very fast (for me, LOL) with no effort at all on its part or mine.
Blinding. Goes like shit off the proverbial shovel. Mr. Green Thumbs Up
Robby
Dirty Old Man
PostPosted: 19:35 - 28 Aug 2023    Post subject: Reply with quote
I took the 250 out for it's first ride of the year.
It's quite slow.
Easy-X
PostPosted: 22:36 - 28 Aug 2023    Post subject: Reply with quote
How's that route for average speed cams these days?
hellkat
PostPosted: 18:31 - 29 Aug 2023    Post subject: Reply with quote
Erm ...
Yeah I think there's a few here and there Shifty
... one might think I was going too fast to notice the signs ...
... but I am so ridiculously familiar with the A316, having ploughed it for many years when I lived in Fulham, that I'm very conscious you have to go really fuckin slowly or you could lose your licence within a couple of roundabouts Laughing
Kawasaki Jimbo
PostPosted: 19:08 - 29 Aug 2023    Post subject: Reply with quote
Not the same route (probably O/T in fact) but on dual carriageways I’m noticing less respect for my superior speed and race face Very Happy whereby cagers are happy to sit in the outside lane instead of moving left. At the weekend some fool in a white Audi eventually moved over only to tempt me into accelerating past a speed camera. I knew the road so didn’t, and said fool pulled out again. I’m cautiously undertaking more these days Embarassed but no one seems to mind, they’re so wedded to Lane 2 where the ‘alphas’ live.* But yeah, while I suspect most average speed cameras are inoperative the zones are the work of the devil thanks to bunching traffic. Meanwhile back in rural England I witnessed another dawdler wholly oblivious to people waiting to cross a zebra crossing but hey, we must assume their low speed would make up for lack of awareness and reaction times in the event of an incident. They’ll never be photographed or stopped.
* Also people who plan to turn right in 3 miles, and people who need to keep sight of the kerb whizzing past their right elbow to stay in lane, the left kerb being too distant to track comfortably.
Skudd
PostPosted: 07:50 - 30 Aug 2023    Post subject: Reply with quote
Downloaded loads more music onto my sat-nav for my riding entertainment.
grr666
PostPosted: 09:26 - 30 Aug 2023    Post subject: Reply with quote
I'll sit there behind to give them an opportunity to move over but if they miss a gap and want to be a rolling roadblock,
I fvck right past them on the inside through that same gap at warp 10 before they even realise I'm doing it. Got to be
some advantage to riding a litre bike. For the most part though, people do move across when they notice me. I think
some like it when a bike blasts past, I know I do when I'm out in the car. I've had a few drivers give me the Thumbs Up as I
blast by or maybe it's a Middle Finger ? Who knows? Laughing
I try not to be a dick about it but when I encounter Nigel McRoadcaptain thinking he's some kind of self appointed enforcer
of the posted limit in his Vauxhall (it's usually pretty obvious when it's one of those) then I get by sharpish in case they
start with the brake checking. The odd one can be quite aggressive if given the chance.
Easy-X
PostPosted: 10:29 - 30 Aug 2023    Post subject: Reply with quote
The worst is some NSL country road with a dick doing 40mph. Hit a village with a 30mph limit? Still doing 40mph. Dual carriageway? Suddenly turns into Stirling Moss Sad
bacon
PostPosted: 10:54 - 30 Aug 2023    Post subject: Reply with quote
Fork seals on the 00 VFR800fi, left seal blew the other week, leaving me with no transport to work, well, I rode in on it a few times out of necessity, but I was expecting oil at any time to be dumped on my caliper, managed to work from home for a couple of days and got them sorted.
LH leg went well (the one with the blown seal), minus a very siezed in oil seal, the oil was filthy, bike is on 39k, unsure when they were last serviced as nothing regarding fork servicing in my mountan of history, but I did find Eiback linear 0.95N/mm springs installed, so must have been open once upon a time.
RH leg however was a royal pain in my arris, the damper bolt was spinning.
I didn't have a 1/2" to 3/8" adapter to use my electric rattle gun, had to improvise and found a solution using my battery drill. Upon removal it seems that the damper leg itself spinning wasn't the problem, but the compression valve at the bottom spinning within the leg. This made tightening the bolt impossible, despite running the bolt through a die, I couldn't get a tap to clear the female thread, due to the valve spinning...
The solution was to add a "spacer" along the damper rod and tighten the cap nut down into it to add tension, this pulled the compression valve against a circlip within the cartidge...
Once I did this the assembly was a piece of cake.
Also did a quick oil change, new brake pads should be here tomorrow and will give the calipers a good clean out again while im in there.
Brake fluid and clutch fluid next, which will be fun with the combined brake system.
Then when I get time I will replace the coolant hoses, I had one let fluid past during one of our hot days last month, believe it was the hose connecting to the top of the LH rad (one with the fan on it) going by the staining to the fan...
Easy-X
PostPosted: 12:53 - 03 Sep 2023    Post subject: Reply with quote
R125 - went to help the old fella put the new cylinder and piston on. "Did you check the ring-gaps?" Nope! Hoping the guys in the Chinese factory were on the ball that day Neutral
Took a couple of attempts - 125 pistons are small and fiddly - "hang on, is this [bottom] gasket the right way round?!" ffs... Rolling Eyes And of course we tore the gasket before getting it off. Probably for the best though as it was about as thick as tissue paper. BTW note in the instructions suggests one might need 2 or 3 gaskets if there's valve/piston interference not that there's any spares supplied with the kit. Apart from "don't buy cheap Chinese shite" I would suggest getting a proper gasket kit. Oh well, Take 2 next week I suppose.
Vitpilen 401 - fitted paddock stand bobbins, any generic M10 ones are fine. There were also exposed mounting holes from removal of the original tyre hugger number plate which I filled with some M8 dome headed bolts. Same deal with where the stock mirrors go and again just need generic bungs, both thread directions clockwise and anti-clockwise. Put back the stock foot pegs instead of the cheesy aftermarket alloy ones. Time to get the fucker on the road! And...
...I went round the block and came straight home! Shocked
Initial impressions of the Vitpilen: small, light, easy to move around by hand - exactly what I wanted. Even so I'm probably gonna put back the grab handle behind the seat. The pegs are set back quite a bit compared to my XSR but somehow my feet naturally gravitated to them so that's fine. Transmission is light, maybe too light as neutral's quite hard to find. (Never even got as far as testing the quickshifter.) Engine is nowhere near as vibey as I thought a thumper would be and seems quite reasonable and sedate. Apparently the ECU has been retuned for the exhaust so maybe that makes a difference. But unfortunately:
Clip-on handle bars
https://media0.giphy.com/media/v1.Y2lkPTc5MGI3NjExZnZ4dTRqbGw2NjlvZ25sMnN3NmdwaHBzbnBhajIxYjhzZWdldHpnZCZlcD12MV9pbnRlcm5hbF9naWZfYnlfaWQmY3Q9Zw/vyTnNTrs3wqQ0UIvwE/giphy.gif
I thought I'd try 'em for a week or so but I do not like them one bit. My arms ache just thinking about clip-ons and I only went half a mile! Yet again a reinforcement of the "I'll make this into a café-racer by adding clip-ons" makes you a special type of c*nt Sad The bar-end mirrors are also flipped down and I can see the sum total of fuck all. I had the same with the XSR and changed them to the upright position.
Anyhoo, I expected and planned for this eventuality. Vitpilens, even new ones, are regularly sold for a bag less than the Svartpilens. However, Husqvarna sell a kit for conventional handlebars - essentially converting a Vitpilen to a Svartpilen (minus the knobbly tyres) - with all one would need including new yoke, cables, brake-pipe, switches, etc. They don't sell the opposite kit, to fit clip-ons to a Svartpilen, funny that Thinking
Villers
PostPosted: 17:25 - 03 Sep 2023    Post subject: Reply with quote
We get those, I call them the 'omni speeders', essentially one speed no matter where they are, usually 40mph through the 60 and the 30 and then back to 60. Everyone else is a maniac etc... Absolutely clueless and a danger!
MercurialWarc...
PostPosted: 22:31 - 04 Sep 2023    Post subject: Reply with quote
The Triumph was running poorly when hot, so I spent last week investigating:
Checked the valve clearances, and 3/6 exhausts were a smidgen tight and 1 intake was a smidge loose.
Managed to swap a couple around so only needed to order 2 new ones, which are now fitted and all valves are now within clearance Thumbs Up
Then to balance the throttle bodies - a bit more fiddly than the twin-cylindered engines I'm used to, but managed to get all 3 pretty close to each other (that photo was taken during the adjustment procedure btw, they weren't that far apart once I'd finished Laughing ).
Result is that the bike runs beautifully now - took it out today, had the engine working hard in this heat and not a hint of any issue, so I'm a happy boy Dance!
bacon
PostPosted: 21:59 - 05 Sep 2023    Post subject: Reply with quote
Vfr800fi again, changed front pads to some new EBC HH, cleaned up the calipers, red rubber greased the pistons before pushing them home, renewed the front brake fluid, renewed the clutch fluid, both were rather brown!
Need some assistance from the wife though in order to bleed the LH front caliper centre piston with the rear brake circuit. I can't reach it with my foot on the rear brake pedal (no vac bleeder).
Rear brake next when I can find an hour.
Been trying to sort a dodgy neutral dash light. I had hoped it would be something simple, I pulled the neutral switch on the crank case and replaced it with a new OEM part , no change. Removed the front cowl and changed the bulb, no change... I've got continuity between the switch terminal and the crank case. So it must be the wiring. Eurgh.... That will have to wait until the weekend.
The last post was made 2 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Page 43 of 59
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 142.75 Kb
