Ambulance conversion conundrums
A100man
PostPosted: 12:56 - 28 May 2024    Post subject: Ambulance conversion conundrums Reply with quote
See post below about camper base..
https://www.bikechatforums.com/viewtopic.php?t=335821&start=0&postdays=0&postorder=asc&highlight=
So I did buy, without sufficient fore-thought, a 2012 Merc Sprinter based passenger ambulance which I've started stripping out so, far so good. BUT reality bites when you have to register and classify the darned thing.
At some point I'd like to 'down-plate' it as currently it has a GVW (aka revenue weight) of 3.88 tons which means a lower-rate VED
but (much) higher charges if stumble into clean air zone, and 60mph top speed and you have to have C1 licence (which I do cos old).
However before I do that I need to change the Taxation Class and Body Type (both of which are currentle 'Ambulance') . Internet warns that Campervan class is virtually impossible to achieve cos DVLA aren't playing nicely and so most end up as a PLG and 'Van with Windows'.
Has anyone done this? Is it just a case of changing the V5 and send off? The downplating I know is more involved and requires weighbridge certs..
Cheers chaps - 'you are my rock etc..'
A100man
PostPosted: 13:01 - 28 May 2024    Post subject: Reply with quote
Rule #1 Google first.. Rolling Eyes
This is helpful but not up to date..
https://www.motorhomefun.co.uk/forum/threads/when-is-an-ambulance-not-dvla.167539/#:
MCN
PostPosted: 19:11 - 28 May 2024    Post subject: Reply with quote
Remember:
Campervans require thick Insulation for comfortable Masterbation.
Sides, floor and roof.
But campervans are the dogs Haw-Maws for real.
A100man
PostPosted: 22:50 - 28 May 2024    Post subject: Reply with quote
MCN wrote:
Remember:
The amberlance is already lined with a convenient wipe-clean surface Shifty
A100man
PostPosted: 19:45 - 25 Jun 2024    Post subject: Reply with quote
The Amberlance is now a 'Van with side windows..' but still registered at 3.88T and is apparently now a Private-HGV..
There is a 'downplating' excercise you can follow to reduce it to 3.5T but that may or may not require a DVSA VTG10 form..
Has anyne done this and lived to tell the tale?
The last post was made 2 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 44.78 Kb
