99 Suzuki RF600 Air Box
Lilgem
PostPosted: 15:15 - 05 Jul 2024    Post subject: 99 Suzuki RF600 Air Box Reply with quote
Hi all, just after some tech advice on the following if someone has this knowledge please.
I have a 99 Suzuki RF600 engine going into a custom racing rideon lawnmower build just for shits and giggles but the air filter box is too tall and odd shaped to fit under the bonnet. Was informed that these carbs vacuum slides are partially controlled by the air filter box volume etc and that fitting 4 pod filters it would become temperamental and untenable? If this is the case can I make a custom air filter box with the same volume, same size air filter area, same intake to air box size and vac hoses fitted to the same areas of the air box would this work?
Easy-X
PostPosted: 15:29 - 05 Jul 2024    Post subject: Reply with quote
The main thing an airbox needs to do is distribute air evenly across the cylinders. Pod filters have a couple of inherent drawbacks: inner cylinders (3/4 piston engines) won't get the same air flow and the air flow isn't as consistent across the rev range as the stock airbox. Something to bear in mind.
That being said if it's just a fun project it wouldn't hurt to try a set of pod filters. Worst ways the airflow is poor and you don't get the best performance.
PostPosted: 18:24 - 05 Jul 2024    Post subject: Reply with quote
I think Suzukis are less tempremental than most when it comes to pods. You certainly get a lot of them converted to pods.
In the 90's they did a lot of work using pressure wave harmonics to get more power out of sportsbike engines so if it had been a kawasaki, I'd have said don't even go there. A suzuki, more possible because they are based on a really old engine design anyway and so are less fussy.
The ideal, which is what people did back in the day if they knew what they were doing is to fit a stage 3 dynojet kit to the carbs if you're running pods. Most of them contain a set of differently profiled needles, different main jets, different springs and sometimes a drill bit with instructions to drill a hole in the throttle slide in a particular place. Then they'll run acceptably well on pods.
A quick search shows dynojet don't list a stage 3 kit for the RF though. A company called 6 sigma do, not sure if they ship to the Uk though.
Lilgem
PostPosted: 02:29 - 08 Jul 2024    Post subject: Reply with quote
Thanks for the info but what about the question of making my own air box with all the same volume, air flow and area as the original, would that work?
jeffyjeff
PostPosted: 04:59 - 08 Jul 2024    Post subject: Reply with quote
Of course it would work! The hard part is constructing an airbox with the same air flow characteristics that is not identical to the OE airbox. How do you intend to go about that? Trial and error would be my guess. If you had the knowledge and skills to engineer an airbox that would achieve similar air flow characteristics, you wouldn't be asking the question. Sounds like a fun project, good luck. Here's wishing you all success, (meaning more trial and less error.) Wink
Lilgem
PostPosted: 05:30 - 08 Jul 2024    Post subject: Reply with quote
Yip got the skills and equipment avail to make something as similar as possible so will give it a go, thanks.
Nobby the Bastard
Harley Gaydar
PostPosted: 07:40 - 08 Jul 2024    Post subject: Reply with quote
Surely if you are going to have to replicate the airbox in dimention etc. It would be far simpler just to use the original airbox.
Triumph Sprint ST 1050
PostPosted: 09:06 - 08 Jul 2024    Post subject: Reply with quote
I think he's more talking about the mathematics needed to try to replicate the resonance of an OEM airbox... Some airboxes are specifically designed for shape as well as volume, and so you may find that the engine runs weirdly unless it's on a OEM airbox. I have studied mechanical and aeronautical engineering and I doubt I could do the maths to make it work, I suspect you need a computational fluid dynamics package to do it properly. That being said, it's still going to be more powerful than a standard lawnmower engine isn't it?
jeffyjeff
PostPosted: 13:23 - 08 Jul 2024    Post subject: Reply with quote
Probably easier to redesign the bonnet (and use the OE airbox) than to engineer an airbox to fit under the existing one. For a racing lawnmower, I'd toss the bonnet altogether if it meant winning races. It's not a beauty contest, you know. Cool
Easy-X
PostPosted: 14:21 - 08 Jul 2024    Post subject: Reply with quote
But! But! Aerodynamics!!! Laughing
jeffyjeff
PostPosted: 17:58 - 08 Jul 2024    Post subject: Reply with quote
Maybe he doesn't want to tip off the competition to what he has done, lest someone take his idea to the next level wit a Hayabusa powered lawn mower.
that_impulse_guy
PostPosted: 20:27 - 08 Jul 2024    Post subject: Reply with quote
not wanting to discuss a percentage of hp here or there, effectively the airbox does two things in cv carbs
1) a volume of air..
2) ....that is still...
if you make a box of roughly the same volume, with a nice inlet of similar size, thats about as good as it needs to be.
Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R
A100man
PostPosted: 11:02 - 10 Jul 2024    Post subject: Reply with quote
I have heard, anecdotally, that retaining the carb > airbox rubbers is beneficial as they often form an important part of the intake tract 'trumpet'. If you can build a new box similar volume and use the rubbers
that may help. Mind you that's only what I've heard.
The last post was made 2 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.94 - MySQL Queries: 16 - Page Size: 80.56 Kb
