C110 clutch having great problems fitting back to engine
Bossboy
PostPosted: 15:58 - 30 Dec 2025    Post subject: C110 clutch having great problems fitting back to engine Reply with quote
Hi All,
Forgive me for asking questions
I have rebuilt the clutch with new friction disc and pressure plate, should i be able to push and compress it when i hold it in my hands, its solid att he moment.
Further questions if i may, i have put clutch hub and drive gear, clutch centre guide bak, when i offer up clutch backet there is barely enoughthreadto geta full nut on, let alone,the locking tab.
I would really appreciate anyones help, i was pleased i rebuilt the clutch, but now a little cheesed off
I have done clutches on cars but never a motorcyle, i so want to get this engine running properly
PostPosted: 22:51 - 30 Dec 2025    Post subject: Reply with quote
I have no experience of getting this deep into one of those but looking at the witness marks on the centre of picture "clutch 2", are you sure that's where it goes?
There looks like a very specific shape of discoloured metal where that's been resting against something which doesn't seem to correspond with the surface it's bearing against in your picture.
As an aside, all of your parts look very dirty for engine internals, there looks to be a lot of particles/dust/grime/hairs/swarf hanging about. All that is going to end up in your engine oil and from there, inside bearings, oil passageways and journals. All those parts should be spotlessly clean.
blurredman
PostPosted: 09:50 - 31 Dec 2025    Post subject: Reply with quote
You sure the inner gear is engaging with the clutch plate inner spline? Probably be easier to put the gear in the clutch first, then put it on the shaft?
Bossboy
PostPosted: 14:24 - 31 Dec 2025    Post subject: Reply with quote
tahnks, i have a brand new clutch basket, i will use that
forgive me, a learner, pic clutch 1, showing clutch hub and drive gear, is this as it sould be sitting on engine, then basket fits onto this ?
Bossboy
PostPosted: 14:26 - 31 Dec 2025    Post subject: Reply with quote
Iam dubious about this, i offer it up to clutch basket off engine and does not appear to slot in, i will recheck, is there a way of making sure everything is centralised in basket other than eyeballing it
thanks
Bossboy
PostPosted: 10:57 - 02 Jan 2026    Post subject: Reply with quote
Bossboy
PostPosted: 17:44 - 02 Jan 2026    Post subject: Reply with quote
Thanks for your help
All done now, i am relieved, i can move oto my next parts
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.82 - MySQL Queries: 13 - Page Size: 56.05 Kb
