Rapid Battery Drain
Bunzena
PostPosted: 11:36 - 28 Sep 2026    Post subject: Rapid Battery Drain Reply with quote
Hi. Have fitted a brand new battery as bike wouldn't start.
Voltage showing on dash as 11.9 - and this corresponded to a multimeter reading too. Was original battery - 5 years old. Always been on a tender - but ho hum.
New battery [which has been fully charged] shows initial voltage [with ignition on] as 12.6 - and bike starts. However after 5-10 minutes voltage has dropped to around 12.0 volts and bike won't turn over. Crying or Very sad
There's no apparent heavy or even parasitic drain other than the LED lights. But can't see how these would have an impact in such a short time.
My suspicion is that the Regulator/Rectifier may be kapput?
Bike is a 5 year old NC750X - low mileage.
Any thoughts on what could be happening?
Rob W
PostPosted: 13:07 - 28 Sep 2026    Post subject: Reply with quote
What does the multimeter say when the bike is running?
Bunzena
PostPosted: 13:36 - 28 Sep 2026    Post subject: Reply with quote
Thanks for response/question.
Registers around 14.4v steady.
So seems to be charging.
Haven't pulled the Reg/Rec out of the bike yet [it's in an awkward location] - so haven't tested it.
But suspicion is that the diode may have failed?
A100man
PostPosted: 15:37 - 28 Sep 2026    Post subject: Reply with quote
could be a duff new battery - does it charge off the bike?
Bunzena
PostPosted: 16:33 - 28 Sep 2026    Post subject: Reply with quote
I did think it might be the new battery - but the retailer [who was very pro-active] sent a new one I fitted this morning [after charging].
Had exactly the same issue.
When newly fitted and charged - showed a static 12.6v
After 30 minutes had fallen to 12.3v - now [6 hours later] at 12.1v
So there's a significant drain. I have heated grips and fog lights [using factory harness] - but they've been onboard for a while. The bike is garaged and has no corrosion. Earths look good.
So - and I'm guessing - the Reg/Rec may be playing up. Dodgy diode.
The Reg/Rec an absolute pig to get at. Petrol tank has to come out, rear mudguard, brake light, and multiple body panels off. Previous nakeds have always had the Reg/Rec in the airstream. Embarassed
Easy-X
PostPosted: 16:59 - 28 Sep 2026    Post subject: Reply with quote
Do you have a multimeter with a current setting? A decent one can handle 10amps but with ignition off I'd only expect 10 to 100mA. Be interesting to see what the drain is just sitting there. Also try disconnecting the reg/rec and see if it affects things.
Bunzena
PostPosted: 17:31 - 28 Sep 2026    Post subject: Reply with quote
Thanks Easy-X
My multimeter does have a current setting. But I'm not sure it's working.
With the ignition off it's not registering any drain at all.
I guess that's possible?
Getting to the Reg/Rec is a shocker - been at it an hour or so - and still not able to get access to it.
A100man
PostPosted: 18:02 - 28 Sep 2026    Post subject: Reply with quote
Bunzena wrote:
Thanks Easy-X
Not likely on a modern bike I'd think - clocks and computers need to be kept awake, no?
Can you try pulling fuses in turn to see if it helps? Those electrons must be going somewhere!
Bunzena
PostPosted: 18:55 - 28 Sep 2026    Post subject: Reply with quote
Good thinking A100man.
I have a more modern multimeter on the way that might reveal more.
In the morning - I shall start pulling fuses... Very Happy
jeffyjeff
PostPosted: 22:42 - 28 Sep 2026    Post subject: Reply with quote
Don't forget to check the fuses in your multimeter. Contacting the leads to a live circuit with the meter set to measure Amperes will blow the meter fuse instantly. As far as I know, most multimeters will not indicate a blown fuse on the meter display, and a blown fuse will prevent the meter from measuring current.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.35 - MySQL Queries: 16 - Page Size: 65.66 Kb
