Author |
EDBANGER |
EDBANGER World Chat Champion
Back to top |
Git |
Git Brolly Dolly
Posted: 18:15 - 05 May 2005 Post subject: |
Bikes jumping out of gear, at first thought I'm thinking damaged selector fork. For this it's an engine strip job.
Hello and welcome |
Back to top |
tatters |
tatters Exxon Valdez
Posted: 18:21 - 05 May 2005 Post subject: |
ZZR400/600,s are know for having a problem with the 2nd gear when they are getting old. replacment enigne £150-250 or a bottom end strip down. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650 Present:G650XC,C12,KZ750,1190ADV |
Back to top |
Scotsman37 |
Scotsman37 World Chat Champion
Back to top |
EDBANGER |
Back to top |
EDBANGER |
Back to top |
Guest |
Guest Brolly Dolly
Posted: 20:29 - 05 May 2005 Post subject: |
If you're not bothered about out-and-out performance then I'd run it into the ground, or strip it and repair and probably learn a lot along the way. You could short-shift through 2nd into 3rd and just lose a little acceleration.
What usually happens is the dogs on 2nd gear wear smooth so they don't stick into the slots in the next gear properly, so it jumps out of 2nd under load. Mainly caused by clumsy shifting - crashing it through the box doing drag starts. It's not usually caused by bits breaking off so there's no worries about debris floating round the engine.
My bike is renowned for the same thing, but in 40,000 miles of careful use and regular oil changes (using 'car' 10/40) it shows no sign of appearing.
A second hand engine could be well on the way down the same road and you have the disadvatage of not hearing it before you buy.
If you don't have the time, space or inclination to strip and fix it then breaking it is a good idea, I'm sure you could make most of your money back, particularly on the plastics and electrical fittings.
Good luck with it anyway |
Back to top |
EDBANGER |
Back to top |
Guest |
Guest Brolly Dolly
Posted: 22:18 - 05 May 2005 Post subject: |
It's a full engine strip to get at it but they're not rocket science. On most bikes you can up-end the engine and just remove the bottom case without disturbing the heads and barrels and the gearbox is laid out in front of you
You'd need to check this is the case on the ZZ. On Suzukis you need to take the clutch basket off as there's a bearing retainer plate behind it that's bolted across both case halves, also one behind the water pump.
You need to talk to somebody who's actually done a ZZ to be sure what's there.
New parts would be best, no idea of the price though sorry |
Back to top |
EDBANGER |
Back to top |
Scotsman37 |
Back to top |
EDBANGER |
Back to top |
Guest |
Guest Brolly Dolly
Posted: 16:03 - 06 May 2005 Post subject: |
By all means spend £30 on oil every oil change, on a bike engine that was desinged before the 'motorcycle specific' con was dreamed up
I run mine on £8 a gallon 'car' oil changed every 3000 miles with a filter every other change. No problems with gears or clutch slippage since new.
It's the same oil I used to run in the company Vectra (integral gearbox but dry clutch) and the service intervals for that were 20,000 miles |
Back to top |
Scotsman37 |
Back to top |
Kickstart |
Posted: 18:22 - 06 May 2005 Post subject: |
Scotsman37 wrote: | Yeah, but what make & model is your bike because he has got a a very fast bike and wants to look after it. |
I have used car oil in all sorts of bikes with no real problems, including a 1200 Bandit, FZR600, GPZ500, XJ600 and FZ750.
Only one that has shown any signs of clutch slip was the Bandit, but then that was with a tuned engine (no sign before the engine was tuned), and the clutch also slipped with fresh bike specific oil and new clutch plates (what stopped it was Barnett clutch plates and springs).
There are arguments about using car oils in gearboxes, but then Honda specify normal 10W40 engine oil in the boxes in a lot of their cars.
In this case he has a bike that he paid £250 and pretty much intends to run into the ground. At £30 a shot he will rapidly spend more on oil changes than the bike is worth, and highly unlikely that it will help the gearbox problem or prevent any engine problems until long after the gearbox becomes terminal.
Back to top |
Guest |
Guest Brolly Dolly
Back to top |
gsxrpeak |
gsxrpeak Trackday Trickster
Back to top |
The last post was made 18 years, 360 days ago. Instead of replying here, would creating a new thread be more useful? |
