Down-gearing the Hornet
Milo
PostPosted: 09:44 - 19 May 2005    Post subject: Down-gearing the Hornet Reply with quote
It's got plenty of low down power and considering my general acceleration involves two or even three up changes before accelerating again why not up-gear it?
I was thinking of going up by two on the front, though any ideas how much this would bugger the speedo up by and if that can be circumvented?
Shaft drives rule. Razz
Method
PostPosted: 09:46 - 19 May 2005    Post subject: Reply with quote
Going up two on the front could actually make quite a large difference aswell mate.. Could be more than you expected..
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
8316
PostPosted: 13:53 - 19 May 2005    Post subject: Reply with quote
oh man.
ive only heard of people down gearing for more squirt, not going up!! Rolling Eyes
why not just downgrade to a smaller bike then? like a hornet 250....
Now own a Fireblade!! Speed Limits? Bah!
Milo
PostPosted: 13:57 - 19 May 2005    Post subject: Reply with quote
Meh - you crazy hooligan wheelie kids! Laughing
I love the Hornet so far...though the tank range isn't that great.
A smaller bike won't do what I want it to do...plus I've only just got it!
If I'm only using it to get about and for fun, then why don't I just get a bus pass and a skateboard? Rolling Eyes
Frost
PostPosted: 14:00 - 19 May 2005    Post subject: Reply with quote
2 up onthe front is rather alot.
1 up ont he front, 2 down on the rear sounds a better bet.
Milo
PostPosted: 14:04 - 19 May 2005    Post subject: Reply with quote
Anyone know of a good supplier for front sprockets - I'm obviously after the rarer larger front ones/smaller rear ones.
Surely 1 up on the front and 2 down on the rear is virtually identical - using the 1 on the front equals 3 on the back guide?
8316
PostPosted: 14:09 - 19 May 2005    Post subject: Reply with quote
ok-ill try to stay calm
looking at the positive side, you'll get more mpg out of your bike which will help compensate for the poor tank range, especially if you go up TWO on the front.
ok with that now milo? Laughing
R6Armadillo
PostPosted: 14:26 - 19 May 2005    Post subject: Reply with quote
www.bandcexpress.co.uk is a good place to try for sprockets. Lokks like they have a 2down rear but no smaller front for the 600 and 1 down rear 1up front for the 900.
When Eric eats a banana, an amazing transformation occurs. Eric is Bananaman. Ever alert for the call to action.
johnsilva
PostPosted: 16:38 - 19 May 2005    Post subject: Reply with quote
i honestly dont understand why on earth you want to gear up? it sounds flipping wierd!
Why would you want to make your bike accelerate slower? Its crazy!
John
Current Bikes: ZX7R P5; KR1S C2; GPX250R F3
Previously: CBR400RR-R; YQ50 Aerox
Jon
Anyone for donuts?
PostPosted: 16:59 - 19 May 2005    Post subject: Reply with quote
That's more or less the same as going 2 up on the front
mchaggis
PostPosted: 17:15 - 19 May 2005    Post subject: Reply with quote
Because the bike only did 50 in top otherwise. Confused
I must not be a troll...
Mmmm, Guinness
jay12329
Dr. Evil
PostPosted: 17:49 - 19 May 2005    Post subject: Reply with quote
The hornet doesnt have enought power to hit the red line in top, thats why people genrally down gear, gives it more go but doesnt hugely affect the top end. Upgearing would be stupid, it would take you a year to get anyware.
J
Milo
PostPosted: 17:53 - 19 May 2005    Post subject: Reply with quote
J
Means I get more out of the tank, won't need to shift as much around town and maybe even increase chain/sprocket life...though I'm not worried about that.
Not worried about top speed...but if I want to go all the way then there's always 5th gear if it can't make it in 6th you know...
Milo
PostPosted: 09:50 - 23 May 2005    Post subject: Reply with quote
Maybe you'd answer my questions if I asked about down-gearing it?!
Would it bugger the speedo up by much if I downgeared it, and is there a way to get around this?
Would changing the gearing on the front sprocket keep the speedo in sync?
cheers
Bendy
Mrs Sensible
PostPosted: 10:55 - 23 May 2005    Post subject: Reply with quote
www.speedohealer.com is what you'll need. Changing the front sprocket won't work, the speedo is set up for the default sprocket ratio.
When you downgear, your speedo over-reads, when you upgear it'll under-read. If it's only a little and you've worked out in your head what the true speeds are, you could just leave it.
Milo
PostPosted: 23:54 - 23 May 2005    Post subject: Reply with quote
Cheers. Any idea where I can buy non-standard sprockets?
Will probably have to get one specially ordered I assume which is a bit annoying.
Just went into reserve at 119 miles! Crying or Very sad
bish777
PostPosted: 00:02 - 24 May 2005    Post subject: Reply with quote
id advise caution and just take 1 off the front as going too far can murder accelleration.
Not to mention chain length issues when fartingaround with rear sprockets.
GSXR1100J
Dr Nick
Dont do it dont do it!
I downgeared my hornet last year, it made the front come up too easy in 1st and 2nd and made it drink loads more petrol, and eat more tyres and chain and sprockets. Since recently upgearing it the bike feels faster overall!, not just top end, and i can pull longer higher wheelies on it for some reason now.
I went 2 down on the front basically
standard gearing is 15/42
i went down to 14/45
is that it
bish777
PostPosted: 00:27 - 24 May 2005    Post subject: Reply with quote
oops meant UP one tooth on the front...
GSXR1100J
Milo
PostPosted: 11:34 - 24 May 2005    Post subject: Reply with quote
I actually want to upgear it, but I changed the topic title as my questions weren't being answered when I was asking about larger front sprockets/smaller rear sprockets.
Bendy
Mrs Sensible
PostPosted: 11:45 - 24 May 2005    Post subject: Reply with quote
Demon Tweeks and pretty much every bike parts place.
Dr Nick
PostPosted: 12:29 - 24 May 2005    Post subject: Reply with quote
Demon Tweeks = RipOff merchants
www.bandcexpress.co.uk for sprockets mate, official importer or renthan sprockets etc, very good service, delivered next day too Thumbs Up
is that it
PostPosted: 13:11 - 24 May 2005    Post subject: Reply with quote
Up gearing by 2 teeth will make a hell of a different to the bike. The speedo will under read by about 13% (which could be a really bad idea near a speed trap). You might also have issues with physically fitting that large a sprocket into the space available.
Initial acceleration will suffer, as will top gear roll on acceleration. However in top gear you can just knock it down a gear for the same effect as down gearing (or just sit one gear lower).
It might well help fuel consumption. With the 1200 Bandit going down 1 tooth on the front knocked 5mpg off the fuel consumption.
Cruising is quite possibly going to be a lot more relaxing, knocking about 700rpm off the revs for the same speed in top gear.
The only real down side is initial acceleration, and it might be a bit of a pain doing fully laden hill starts. Probably not worth doing if you are riding round town a lot.
If you are thinking of it then I would start by just going up one tooth at the front. However a quick look in the Demon Tweeks catalgue reveals no alternative larger front sprockets for the Hornet, and the only option is to go down 2 teeth on the back (only save you around 300rpm at 70mph).
Milo
PostPosted: 14:28 - 24 May 2005    Post subject: Reply with quote
Cheers for the info.
I meant a non standard sprocket as if in by going in the gearing direction I want to instead of the normal down-gearing.
I'll give the rear sprocket a try, though it seems a bit pointless and may well not affect the fuel economy enough to warrant the purchase.
I'm fully aware of what goingup two teeth on the front will do to the performance, but quite frankly it's a strong enough engine low down for it not to impact day to day riding too much.
I'll check out the sprocket surroundings and see if there's space. If there is would it be possible to get a sprocket custom made?
PostPosted: 14:34 - 24 May 2005    Post subject: Reply with quote
Probably possible, but I would be temtped to just try what is easily available (ie, the smaller rear sprocket).
The last post was made 21 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.16 - MySQL Queries: 16 - Page Size: 136.31 Kb
