bottom mounted rear disk brakes, why do we still have them.
epz
PostPosted: 05:34 - 24 May 2005    Post subject: bottom mounted rear disk brakes, why do we still have them. Reply with quote
ive seen several bikes with the rear brake caliper mounted above the swingarm so it requires less parts to fit and doesnt get hit with so much crap off the road, anyone know why plenty of new expensive bikes havent followed this idea.
california_rookie
PostPosted: 05:54 - 24 May 2005    Post subject: Reply with quote
Lower center of gravity? Thinking
https://www.bikepics.com/members/californiarookie/04gsxr600/
https://www.myspace.com/spapadillion
https://steamcommunity.com/id/spapadillion
Claud 14.7 to 1
PostPosted: 08:45 - 24 May 2005    Post subject: Reply with quote
Which bikes?
Most bikes now have followed this idea. Honda had them from early on, even my one has it. Surprised
ZX-R and GSXR used to have it, now they've changed to the "above and held on via the swingarm" option. It's lighter, uses less parts and looks better.
mchaggis
PostPosted: 10:47 - 24 May 2005    Post subject: Reply with quote
The reaction arm is easier to set up with the calliper underneath the swingarm. It only has to be in tension like that, whereas if it is above the swingarm, it is in compression. Struts resisting compression are more difficult to design than those in tension.
Mind you, if you can get away with mounting it directly on the swingarm, I think you could get away with a fair deal less other structure.
https://www.ibike.com.hk/01_bike_report/local/bmw/r1150r/brake_rear.jpg
Under swingarm
https://www.bmw-motorrad.co.uk/com/_common/img/services/vis_techniquedetail_paralever.gif
Paralever above swingarm
https://www.cmgonline.com/articles/CMG03/bikes/Yamaha/WR450/TestRide/BigP/WR_rear_wheel_bg.jpg
On swingarm.
See the difference in the reaction arms between the under and over the swingarm.
I must not be a troll...
Mmmm, Guinness
PostPosted: 11:27 - 24 May 2005    Post subject: Reply with quote
Can think of a few reasons.
With the disk mounted under the arm the mount is under tension and is not attempting to bend the swinging arm. Also if you do mount the caliper off the swinging arm on the top then the mount will be attempting to twist the caliper. Mounted under the arm with a mount under tension, it is easy to have the mount coming back to the centre line of the caliper so greatly reduce the tendency for it to twist.
Also results in a lower centre of gravity (slightly).
There are also down sides. Caliper gets covered in crud and it is difficult to bleed.
iCraig
PostPosted: 11:31 - 24 May 2005    Post subject: Reply with quote
It can't be down to cost really as the GS500 (a really cheap bike) has it mounted above the swing arm.
https://www.craiggiles2.f2s.com/brksuz.JPG
Kris
PostPosted: 11:48 - 24 May 2005    Post subject: Reply with quote
Also steel is crap in compression but very good in tension so the 'pulling' effect by placing the caliper underneath allows easier design.
www.prisonplanet.com
The last post was made 21 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.31 - MySQL Queries: 16 - Page Size: 56.34 Kb
