M1ke Ped Boi
Posted: 17:48 - 01 Jan 2003 Post subject: coolant expansion tank |
I was just poking around under the fuel tank and noticed that the coolant tank thing (wrapped around the battery) is completely empty! I dont even know what is meant to be in there, can some one tell me what to fill it with please?
cheers
newbie |
M1ke Ped Boi
Posted: 19:35 - 01 Jan 2003 Post subject: |
Any bike or car shop will have antifreeze (not the screen was stuff). You want a mixture with water (pure anti freeze and the bike will overheat)
If you run it without any coolant it will overheat. This will probably result in it seizing or warping the head. However, there is a fair amount in the system. The stuff in the header tank is really a "reserve tank", but it isnt a good idea to run with it too empty.
If you use just water as a coolant then it will start to corrode the alloy in the engine, and if it freezes then it is likely to crack various parts of the engine.
