HELP!! APRILIA RS 125 ELECTRICS
ben_121_uk
PostPosted: 20:15 - 01 Jul 2005    Post subject: HELP!! APRILIA RS 125 ELECTRICS Reply with quote
I've changed a faulty horn on my RS125 and didn't realise i had left the ignition switched on during the change. When i had put it back i found i had no electrics everything is dead Dash lights, starter everything. Battery is fine all fuses that i can find are fine (3 just under left of fuel tank) and starter relay is fine. Anyone got any ideas?? Crying or Very sad
www.beckpowersports.co.uk
PostPosted: 20:59 - 01 Jul 2005    Post subject: Reply with quote
Double check the fuses. You would need to leave the ignition on for ages to totally wipe out the battery. Also check that both the battery terminals are still connected, and also that you have not disconnected the earth line from the frame.
ben_121_uk
PostPosted: 23:06 - 01 Jul 2005    Post subject: Reply with quote
Thanks Keith, i've tried that and still no good. Its very frustrating i think i've explored about every option that i can think of.
loply
PostPosted: 14:42 - 02 Jul 2005    Post subject: Reply with quote
To offer some reassurance, when changing the brake light switch on my bike I left the ignition on and ended up causing sparks and smoke, and after letting it cool down and checking all the joints it fired back up...
So I doubt your ECU is written off or anything =)
Yamaha SZR660 Caution to the wind, the throttle pinned!
Thet2
PostPosted: 16:34 - 02 Jul 2005    Post subject: Reply with quote
u still get spark on spark plug? if not check the 7.5 amp fuse, also, you tried bumbing it to see if it starts?
PostPosted: 20:11 - 02 Jul 2005    Post subject: Reply with quote
Whereabouts in the West Midlands are you. Possibly someone can pop along and have a look?
ben_121_uk
PostPosted: 21:25 - 02 Jul 2005    Post subject: Reply with quote
Tipton near Dudley
PostPosted: 22:22 - 02 Jul 2005    Post subject: Reply with quote
Think the best thing to do is go over the bike with a multimeter and find where the power stops.
I work in Kingswinford. I can probably pop round one evening next week to have a quick look if you cannot get it sorted by then.
ben_121_uk
PostPosted: 00:35 - 03 Jul 2005    Post subject: Reply with quote
Cheers Keith, That would be good i'll keep you informed. I'm going to get the multimeter on it tomorrow. Fingers crossed.
Warren
ben_121_uk
PostPosted: 00:29 - 04 Jul 2005    Post subject: Reply with quote
Still no good come on everyone keep the suggestions coming i'm willing to give anything a try. Are there any Aprilia mechanics or bike electricians out there?
Rs-Sean
PostPosted: 01:45 - 04 Jul 2005    Post subject: Reply with quote
Hi there mate from what it sounds like you have more than likely blow yor 20amp fuse triple check it as iv looked at fuses and for they ok but there arent so have a go at that and you say you fitted a new horn check that you have connected the 2 wire to the right polarity eg +to+ -to- If not stick the key in turn it on a bump start it if it fires up check all the wires on your ignition barrel i had a friend with the earth from the igniton barrel come out and everything went dead! Good luck anyway
ben_121_uk
PostPosted: 08:55 - 04 Jul 2005    Post subject: Reply with quote
If the offer still stands i need all the help i can get. This one has me stumped!!
PM me or contact me through the website below.
Thanks
Warren
ben_121_uk
PostPosted: 00:27 - 09 Jul 2005    Post subject: Reply with quote
What can i say "Kickstart is a genius!!" came round tonight and sorted my problem so another big thank you to Keith!!
rizo9
PostPosted: 01:57 - 10 Jul 2005    Post subject: Reply with quote
what was up with it?
New bike Very Happy https://www.bikepics.com/members/rizo9/01rs125/
PostPosted: 12:52 - 10 Jul 2005    Post subject: Reply with quote
I will let Warren tell you that one..
ben_121_uk
PostPosted: 14:23 - 10 Jul 2005    Post subject: Reply with quote
Well it was quite technical really, it was a very difficult one to fix.....until Keith found I'd put one of the wires on the wrong terminal in about 5 minutes of him being there!!! hahaha I admit i'm a dick!! Once again thanks Keith!! Laughing
The last post was made 21 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.36 - MySQL Queries: 16 - Page Size: 96.34 Kb
